Awful Smell Coming from Heating Ducts - Please Help
Brian
We just bought a 1941 home and we recently had the heating ducts
cleaned and sanitized. The brush that the company used however was too
big to snake all the way through our duct system because the size of
some of our ducts is very small. Before and after the cleaning job, we
have had an odor that comes from the heat and appears to be most
pungent when their is rain or snow outside, but that could be a
coincidence.
Can anyone offer us any advice here?
Thanks,
Brian
Stretch
Do you have a heat pump? Or is it a gas furnace. Brand & model # may
help. Need more information. Are ducts sheet metal? Lined or
un-lined? Ductboard? Flex?
How old is your system?
Another unhappy duct cleaning customer. Duct cleaning helps sometimes,
but is often done by hacks and is often overrated. I guess it didn't
fix your problem.
Stretch
robson
coincidence.
Thanks,
Brian
try http://www.nadca.com/consumer_info/consumer_brochure.asp
barry
What kind of pungent? (Give us something to go on, eh!) How about dog
hair in the return? Been there, seen that.
m Ransley
Is it like mold, did anybody check the AC coil, dcondensate tray or
ducts at the furnace, have you had it serviced. how did they clean the
ducts.
T.G. Lambach
If related to precipitation your house must have a moisture leak that
must be located and repaired.
In order of ease of inspection:
Check if the furnace flue is hot and DRY, a too large flue for the
current furnace can get condensation inside it.
Then, the furnace's heat exchanger, especially if it's and old furnace,
ought to be checked for stress cracks - these allow combustion fumes to
enter the ducts - and your lungs. Use a flashlight and small mirror for
a look inside.
You need to inspect all, and not less than all, the ducts, including the
return, for water infiltration and disconnected joints.
Bubba
coincidence.
Thanks,
Brian
Call them back,
You did get a warranty, right?
Bubba
CBHVAC
coincidence.
Duct cleaning, is the single biggest scam, next to mold, in the industry.
Hope they gave you some sort of satisfaction warranty with their work..
If its a heat pump, you prob have one hell of a case of DSS, or Dirty Sock
syndrome.
Matt
coincidence.
I advise you to describe the smell in a way that might be useful to
somebody who might be trying to help you.
E
EXT
Brian must be a female. Women, or those trying to be a woman, tend to
describe things in the abstract, which makes diagnosis so difficult. Males
tend to detail descriptions with similarities so that a comparison can be
made. Unfortunately, the two sexes don't always fit the usual pattern.
BocesLib
I dont know about that... I had mine cleaned and there was 50 years of
shit
in them. I figured its better out than still in the system with me
breathing it
in.
They should really make some sort of filters for the intakes of the
system.
This would prevent so much crap from getting into the system in the
first place...
Tom
CJT
shit
breathing it
in.
You probably should consider using the toilets instead of the ducts
to relieve yourself.
system.
first place...
Golly, maybe they already do. You need to change them occasionally,
though. If you don't realize they're there, you probably don't
change them as you should.
CBHVAC
shit
breathing it
in.
system.
Actually, they do.
And if the filter at the unit, if you have a multiple return system as in
so many older homes, is there, you are not breathing anything that isnt in
your home anyway.
Unless you have UV-C's, and a ventilator, (ERV, or a HRV) the air in your
homes worse than outside anyway...
BocesLib
Intakes where the vents are located in the wall would do it. The
system already
has a good filtration system by the furnace. The bulk of the debree
that was in the system came from the intake side of the system.
