Antifreeze - not just for cars
Stormin Mormon
Friend of mine, is acting as caretaker for a family member's
house. The power got shut off, and the house is cold inside.
Down to 37, last he checked. Four burneers on the stove for
an hour raises the temp two entire degrees.
Last night, we put RV antifreeze in the drain traps.
Toilets, sinks, showers. We considered the dishwasher. But
that hadn't run in six month or so, and probably the trap
dried out. Washing machine is in the cellar, and should stay
warmer.
For $3.97 that might be a lot cheaper than replacing a bunch
of broken pipes. I got to thinking. On the way home, I
bought myself a jug of antifreeze. Might never need it. But
it might be cheaper than replacing a bunch of pipes and such
if I need it here, or for a friend some day.
E
EXT
HeyBub said:
I don't understand. How can freezing of water in a p-trap present a
significant problem?
Water will still be in the supply lines, probably even if it is drained, and
can freeze. If the water was not shut off the house could be flooded when
the supply pipe splits.
Stormin Mormon
During the phase change from liquid water to solid ice, the
water (ice) expands. It can easily crack the pipe. So that
when the weather warms up, the drain trap leaks.
Christopher A. Young
Learn more about Jesus
www.lds.org
present a
JoeSpareBedroom
warmer.
Unless the drains were clogged, why would there be any water in them? And
what little is left in the traps would have plenty of room for expansion.
What you need to do is shut off the main water supply valve, and then drain
as much water as you can from the supply pipes by turning on ALL the taps,
especially the one in the laundry sink (in the basement), if there is a tap
down there.
Why is the power off? Reasons beyond the owner's control, or what?
Don Phillipson
This seems unwise, viz. denies power to lamps and burglar/
fire alarms. Many insurance carriers deny coverage when
electricity is shut off. Canadian houses empty for a week to
several months in winter usually maintain elec. connections
and set furnace heat at 45 to 50 deg. Fahr., with an alarm to
report if the electricity should fail.
Don Phillipson
The function of water in a P-trap is to prevent sewer gases
rising into the house. It is cheaper to refill the traps with
non-freezing liquid than to chance months' exposure of
soft furnishings to sewer gases, which is likely to be
incurable.
JoeSpareBedroom
That's true, but not relevant to this situation. Think about it a moment,
then forget about it. It's the least of your problems. The supply pipes are
the main issue.
salty
I'm hoping you bought RV type antifreeze and not automobile type. You
don't want to flush auto stuff down the drains to contaminate the water
supply.
He specifically said it was RV antifreeze.
ransley
warmer.
 www.lds.org
And you drained the pipes, if heat stays off and it gets zero or below
for awile even the HW tank can be at risk, but you have Ng so a gen
can run the heating system
ransley
significant problem?- Hide quoted text -
- Show quoted text -
They can freeze and crack, here it get to -20f, eventualy the roaches
and termites die without heat but the rodents live.
JoeSpareBedroom
Steve Barker said:
the traps WILL break duh.
If I put liquid in a glass jar, but leave enough headroom and don't tighten
the lid, I can put that jar in the freezer and the jar won't break because
there's room for expansion. With me so far?
After I run water in my sink or tub, the pipes end up empty except for a
very small amount in the U-shaped trap. Since there's plenty of room for
expansion (above and below), why should there be a problem? It certainly
couldn't HURT to use the anti-freeze, but the OP didn't mention shutting off
the water and draining the pipes. Seems to me that's where the real problems
will occur, since those pipes are under pressure and sealed (until they
break).
JoeSpareBedroom
Steve Barker said:
why not just turn the heat on?
Because he said the power got shut off. He didn't say why, but based on the
information we have (as opposed to "what if...?"), there is no heat
available.
Stormin Mormon
in them?
CY: The drains would only have waer, if they were horizontal
runs.
And
for expansion.
CY: I think I remember hearing of traps cracking. The ice
expands sideways.
and then drain
ALL the taps,
there is a tap
down there.
CY: Yes, there is a laundry sink. I'm also concerned the
water pipes may have low spots or horizontal runs. Might not
be able to get there with my generator and compressor.
what?
CY: I'm not totally sure. the house is unoccupied, and
beyond that I'm not sure.
Stormin Mormon
I wrote it, meant it, said it, and stand by it. "We put RV
antifreeze...."
www.lds.org
member's
inside.
for
stay
warmer.
bunch
But
such
type. You
supply.
Stormin Mormon
Yeah, the supply pipes have the potential to be a real
issue.
www.lds.org
message That's true, but not relevant to this situation. Think about
it a moment,
supply pipes are
the main issue.
Stormin Mormon
Hint: the furnace requires electricity.
www.lds.org
member's
inside.
Stormin Mormon
Sewage processing plants have to dump the water some where.
Oddly enough, things (like antibiotics, and medications)
have made the full circle from sewer back to domestic water.
Which is why the old "flush pills down the toilet" is poor
advice. Much better they should be wrapped in several layers
of plastic bag, and put in the trash.
www.lds.org
supply.
the drains don't go to the water supply. duh.
Stormin Mormon
I've had glass crack, in the freezer. Many years ago, and my
parents were not pleased. Admittedly it was a full glass
bottle with a cap screwed on. I'm fairly sure ice expands
sidways, so it would crack in any case.
www.lds.org
message
and don't tighten
break because
JoeSpareBedroom
The Ball canning guide says otherwise. Many uncracked jars in my freezer
over the years are also evidence to the contrary. But this doesn't matter.
If you think there is NOT room for expansion in the u-shaped drain traps, I
really want to hear about it. I'm a very curious guy.
JoeSpareBedroom
in them?
runs.
OK. I didn't realize we were talking about incorrectly installed pipes. My
bad.
And
for expansion.
expands sideways.
and then drain
ALL the taps,
there is a tap
down there.
Just shut off the water and then rent a movie, fer cryin' out loud. :)
