Anti-Rollerblader
Charles Bishop
Not really a home repair question, so if anyone has a better suggestion,
I'm open to it.
A client wants me to put somethng on a concrete curb to keep the
rollerbladers from using it to practice. I found one company on the web -
Champion - that can supply me with some but they will take a while to get
here. Any suggestions for another company or better yet, a way to find
them locally (Bay Area, CA)?
Pete C.
I'm open to it.
Any welding / fab shop should be able to fabricate some suitable bolt on
stainless pieces to do the job. For that matter, the solution could be
as simple as nailing on short lengths of ~3/4"x3/4"x1/8" stainless or
galvanized angle with a powder actuated tool.
Pete C.
Al Bundy
(e-mail address removed) (Charles Bishop) wrote in
net:
suggestion, I'm open to it.
web - Champion - that can supply me with some but they will take a
while to get here. Any suggestions for another company or better yet,
a way to find them locally (Bay Area, CA)?
Razor wire.
steve
Charles,
You could apply an epoxy with a heavy grit non skid like 30 mesh. That
would defet the problem. My shop is in Anahiem, if you email me with a
contact # I can probably hook you up with something. Is it just a
standard curb? If so, how much linear feet are you looking to cover?
Steve (e-mail address removed)
N
nhurst
I'm open to it.
Before you start, I would recommend you make sure the curb isn't in the
public right of way. I'm not sure the local government would like a
private citizen making their curbs all lumpy.
-Nathan
tksirius
Can't you just put a few screws into the concrete?
The stuff wont be smooth anymore and will not
be suitable.
You could just dump sand a gravel on the area.
You could even eqoxy it down so it cant be moved.
Rollerbladers and rocks/sand dont mix well.
Tom
Tom G
I'm open to it.
The device I found on the net looks like a round ball headed bolt you set
into the curb. Seems to me there would be some liability issues if a
skateboarder were to hit one of those, not suspecting they were there and
get hurt in a fall. I don't think it's wise to booby trap what is
essentially an "attractive nuisance" so that a trespasser gets hurt. And if
the curb is at street level where pedestrians walk on or over it, they could
easily trip on one. Now, I'm over 60 so I've never rode one of those
contraptions and never bought one for my kids, either...just so you know I'm
not defending the skateboards. In fact, I've always had the fantasy that it
was legal to shoot skateboarders, graffiti artists, etc. and leave the body
lying around for a week or two as a deterrent to others....note..I did say
fantasy, only.
Tom
Goedjn
Falling is an expected hazard. As long as it's not an impalement
risk.
E
Edwin Pawlowski
risk.
True, but in our courts today, if there is a hint that the curb was changed
just to foil the skating, you'd probably lose.
digitalmaster
I'm open to it.
how about installing some threaded anchors..then screwing carriage bolts in
the anchors to make bumps without an impalement hazard?
E
Edwin Pawlowski
Whatever you do, it must NOT be for the primary purpose of harming people
who have a lawful right to do what they're doing.
Your modification can be decorative or functional, however, with the
downside of "discouraging" roller-bladers.
Bolt-on garden gnomes and Burma-shave signs come to mind.
Something else to consider. Who owns the curb? If it is city or town
property, he can probably do nothing. If it is his own private property, he
can get rid of the skaters by normal means for trespassers.
E
Eigenvector
steve said:
Charles,
Rollerbladers??? Could you explain why they are causing a nuisance to begin
with? It might just me be, but typically they are rolling on past at a
pretty fast clip, gone before they're noticed more often than not. Now
skateboaders I can see, but not rollerbladers.
TheNIGHTCRAWLER
Burma-shave signs?
You must have one foot in the grave and the other on a slippery slope,
gramps.
Charles Bishop
steve said:
Charles,
Thanks,
I've saved your post and when I get back from vacation, I'll let you know.
It's not much, maybe 50' total around several planters. The problem is,
they want the usual metal pieces and I have to ask if the grit would work.
I can do that when I get back.
charles
Charles Bishop
I'm guessing not, since these things are all over the place now. Many
business/park/plaza with concrete structures suitable for boarding or
blading have them. I think there are some at city hall.
Charles Bishop
Bladers and boarders like to grind along a curb, railing or suitable
structure. The wears down the curb and can cause spalling, and also damage
the paint. The owners of the property wish to discourage this.
E
Eigenvector
Well I can understand why you would want to stop it, I guess I've never seen
a rollerblader do that. Doesn't mean they don't just that I'd never seen
that
gfretwell
A deep pattern stamped concrete surface (fake stone) is very roller
blade/board unfriendly but still alliows wheel chair access (another
consideration). It gets down to wheel size.
A lot of shopping malls use this strategy for the "plaza" areas.
J. Clarke
One way would be to put some grooves parallel to the curb and sized just
right to grab and chew up a rollerblade wheel. Make sure to put up a sign
"warning, grooved pavement". If you can do them all the way across the
road you ou can even justify them as improving drainage so as to reduce the
risk of cars hydroplaning.
K
Kyle
Let me reiterate and expand on what some others have said: check with
the county or city highway administration to make sure this curb is not
city, county or state property before making any modifications.
I'm not saying they won't let you make alterations to deter damage to
the curb, only that they would want to know they're being done, what
kind of alterations, and what the potential hazards to the public the
alterations could present.
Anti-condensation coatings 0
Anti static trousers? 11
Anti Vac bottle 1
Anti virus 40
anti-freeze 0
Leaky Anti-Siphon valve 1
Anti-siphon Spigot question 4
Anti WD- 40 21
