L
Lobster
Spotted an advert in this morning's paper for a device which purports to
keep your freezer free of ice...
(see http://www.hssantifrostmat.co.uk)
My immediate reaction is that it's total and complete bullshit,
particularly having read the blurb under 'How antifrost mats work':
"An Anti Frost Mat is a specially-coated mat on the bottom of your
freezer is marketed as preventing frost from forming. It also minimizes
blockages in freezer drainage tubes that can lead to "icebergs".
In physics, heat is the transfer of energy from one part of a substance
to another, or from one body to another by virtue of a difference in
temperature. Heat is energy in transit; it always flows from a substance
at a higher temperature to the substance at a lower temperature, raising
the temperature of the latter and lowering that of the former substance,
provided the volume of the bodies remains constant. Heat does not flow
from a lower to a higher temperature unless another form of energy
transfer, work, is also present.
If solid surfaces in contact with the air are chilled below the
deposition point (frost point), then spicules of ice grow out from the
solid surface. The size of the crystals depends on time and the amount
of water vapor available."
So that explains it then... (?!)
Comments?
David
Comments?
David
