Angle grinder lost flat wrench tool. How to unlock?
L
lbbss
I have a 4" angle grinder that came with a 1/8" open end wrench to
unlock the cutting disk. The regular open end wrench is too thick
(1/4") to fit to my angle grinder. Any ideas what other tool I could
use to unlock it? Any ideas? thanks.
E
Ed Pawlowski
Buy a cheap open end wrench and grind it down to fit.
N
Nate Nagel
Tappet wrench. If that doesn't work, grind it down on your bench
grinder. (I would say an angle grinder would work in a pinch, BUT...)
nate
BobK207
What brand grinder is it?
Does the grinder have a spindle lock?
If so, you can do what I do.......activate the spindle lock & then
grab the grinding or sanding disc to loosen or tighten.
I seldom, if ever, use the wrench.
cheers
Bob
Doug Miller
Use your angle grinder to make a new wrench from a piece of 1/8" steel bar.
Or buy a cheap open-end wrench and grind it thinner.
Note: do this with the power OFF.
Stormin Mormon
A couple decades ago, I had a set of "bicycle wrenches" that
might be some what similar.
Similar to this:
http://www.tias.com/cgi-bin/google.fcgi/itemKey=1922819770
Christopher A. Young
Learn more about Jesus
www.lds.org
wrench to
too thick
tool I could
David Nebenzahl
Similar to this:
AKA "cone wrenches" (so-called because used for turning bearing cones).
Probably a little too light-duty, and they come in weird sizes.
Personally, I like Vista, but I probably won't use it. I like it
because it generates considerable business for me in consulting and
upgrades. As long as there is hardware and software out there that
doesn't work, I stay in business. Incidentally, my company motto is
"If this stuff worked, you wouldn't need me".
- lifted from sci.electronics.repair
Lost my Angle Grinder virginity! 8
Performance Power Tools (angle grinder) spares? 8
Angle Grinder... 2
Angle Grinder! 4
Angle grinder. 2
Angle Grinders ? 23
Angle grinder 13
Finding Lost Tools 60
