Advice needed on lawn mower issue
N
N Porter
I have a Sears LT 10 lawn tractor. (Older tractor - ran started fine
last year)
As this mowing season has begun I have not had any luck getting it to
start. It does the following: when the key is turned the solenoid
clicks rapidly and once in a while the starter will engage and spin
the fly wheel slowly. The solenoid mostly just clicks.
Any pointers on what is wrong and what I need to do next.
James Nipper
I am not much of a mechanic, but I would check out the battery first.
Does it have a manual pull-start ??
--James--
m Ransley
1st bad battery
charge or replace
2nd bad starter or solenoid .
It sounds like the starter is not getting voltage , if 12 v. a car
will do , but a bad battery may not accept a jump , no circuit
completion. So start with a battery if its 6v.
DR, Bob
check your tire pressure the front left is low causing the wigget to go off
balance. a off balance wigget will cause many problem, the muffler bearings
will seize if ran for more then 5 min. Off balance wigget will also make the
fuel flow reverse causing it to fill the tank instead of the carb. Off
balance wiggets will also make the operater want to go cow tipping at
midnight on clear nights and their freinds go snipe hunting. I once saw a
off balnce wigget make pigs fly but that was an extream case of off balance
wiggetry. What ever you do dont over inflate the tire then the wigget will
go off balance the other way. If that happens make sure you have 3 dead
chickens near by as a worm hole will open up and the creature from "I need
3 dead chicken world " will apear. Dont piss this guy off give him the
chickens. If you dont have 3 dead chickens then all your mirrows in your
home will make any female who looks into them look fat. Then you will then
be put on some horrible diet. Dont worry if this happens you can correct
everything. remove the wigget on a new moon , not a full moon. Put it into a
golden urn and wait for the 3rd sunday of a month. Find a busy church get
a speedo bathing suit , 1 can of beer, and those glasses with a funny
moustach and big nose. Timing on this part is critical you must wait for
chuch to be let out then run to the front steps and open a can of beer pour
the entire can of beer over your head and say "I am a sucker" 3 time while
danceing around frantically around the wigget hat is inside the urn , wave
your arm around like you are chasing bees away from you. then stop and
calmly say to the wigget inside the urn I am sorry grandma it will never
happen again. You must not say anouther word and stand perfectly still,
wait until the police show up. If you can talk you way out of being arrested
and thrown into a rubber room your tractor will work fine for 3 years.
If the tire pressure is proper then the voltage is low at the solinoid.
check for weak battery bad and or connections.
good luck
Stormin Mormon
He's right... happened to my Uncle Jake, back down on the
farm.
Christopher A. Young
Learn more about Jesus
www.lds.org
www.mormons.com
wigget to go off
muffler bearings
will also make the
carb. Off
tipping at
I once saw a
of off balance
the wigget will
have 3 dead
give him the
mirrows in your
you will then
can correct
moon. Put it into a
busy church get
with a funny
must wait for
can of beer pour
the urn , wave
then stop and
it will never
perfectly still,
of being arrested
for 3 years.
the solinoid.
good luck
