Adding window sill after window installation
Mastermech
What should be used to add an exterior window sill after window
installation???
up the junction
Need a little bit more from you, like - will the cill fit under the window (as is usual) and if so how much of a gap is there - what is the external wall made of and how much forward of the external of the window is it - setting/location of the building - planning regs in force etc. etc. o_O
Window sills 6
Window sills 4
window sills 2
Window sills 3
raising window sills 2
Tiled Window Sills 6
Brick window sill 2
Window Sill Construction 0
