worcester, pressure gauge high, water low
Discussion in 'UK DIY' started by gavinss, Mar 7, 2005.
  1. gavinss
    gavinss Guest
    hi , the pressure gauge on my worcester heatslave 9.24 rises fast whe
    the heating is on, but the water trickles from the hot water taps.
    Any ideas
    Cheers Gavi
    gavinss
  2. gavinss
    andrewpreece Guest
    "gavinss" <> wrote in message
    > hi , the pressure gauge on my worcester heatslave 9.24 rises fast when
    If the HeatSlave is a combi, the pressure gauge tells you the Central
    Heating
    pressure, nothing to do with the hot water, which is at mains pressure.
    Ignore
    my email if your system is not combi-based.
    Andy.
    > Any ideas
    > Cheers Gavin
    > gavinss
    andrewpreece, Mar 8, 2005
  3. gavinss
    Cuprager Guest
    > news:...
    > Heating
    > Ignore
    > Andy.
    >>Any ideas
    >>Cheers Gavin
    >>gavinss
    I have the same boiler. The pressure sits about 1.25 - 1.5 bar when not
    in use and rises around 1 bar more when the CH is on. Hot water is mains
    pressure so shouldnt be affected by pressure in CH system.
    Does your hot water always trickle or does this only happen when the CH
    is on?
    Cuprager, Mar 8, 2005
  1. ironer
    low water pressure gauge
    ironer, Nov 3, 2006, in forum: UK DIY
    438
    The Natural Philosopher
    Nov 3, 2006
  2. peter
    832
    peter
    Dec 14, 2006
  3. Ignoramus22745
    Low water pressure or low water flow?
    Ignoramus22745, Mar 28, 2006, in forum: Home Repair
    16
    507
    Chris Lewis
    May 1, 2006
  4. Tim S
    12
    674
    Tim S
    Jun 16, 2009
  5. Replies:
    13
    873
    DIMwit
    Aug 16, 2007
