wood drill bit versus metal bit
Discussion in 'Misc DIY' started by Henry B., Sep 5, 2003.
  1. Henry B.
    Henry B. Guest
    Ihave inherited a bunch of drill bits. Is there a way to recognize whether a
    bit is capable of piercing thin walled stainless steel versus wood?
    Hank
  2. "Henry B." <> wrote in message
    news:JTR5b.44396$Zw4.32356@lakeread03...
    a
    > Hank
    Most bits are ground for metal drilling. Wood is incidental. For boring
    holes in wood, brad point bits and Forstner bits are the first choice. Brad
    points are sort of flat tipped but have a point in the center.
    When drilling stainless, it is best to spray on some sort of lubricant.
    WD-40 or a light oil will work.
    Ed
    Edwin Pawlowski, Sep 5, 2003
  3. Henry B.
    Dan G Guest
    Look at the shanks. If they are etched or stamped as HSS (high speed
    steel), they are made for drilling metal and can also work in wood.
    Stainless steel is very hard on bits. They will not last long in
    stainless. Sharp bits, slower speed, more pressure - stop and sharpen
    or replace as soon as they quit cutting, once the stainless is turning
    blue it is work hardened and even harder to drill.
    Here are some choices:
    http://www.triumphtwistdrill.com/products/jobber.asp
    Keep the whole world singing. . .
    Dan G
    (remove the 7)
    whether a
    > Hank
    Dan G, Sep 5, 2003
  1. Replies:
    16
    549
    Smitty Two
    Oct 5, 2007
  2. Tony Hwang
    Touhgest drill bit for metal
    Tony Hwang, Nov 19, 2007, in forum: Misc DIY
    12
    681
    Jim Yanik
    Nov 21, 2007
  3. Henry B.
    Metal versus wood drill bit
    Henry B., Sep 5, 2003, in forum: Building Construction
    1,017
    Xilikon
    Sep 5, 2003
  4. mm
    33
    762
  5. Andy
    Metal porch versus wood porch cover
    Andy, Aug 22, 2013, in forum: Home Repair
    20
    552
