Wiring a Carrier Infinity thermostat
Discussion in 'HVAC' started by Bob, Sep 4, 2011.
  1. Bob
    Bob Guest
    power outages cause the thermostat to require configuation...media
    type, humidifier type, etc. If this is not done, the hvac does not
    come on. It just waits for someone to configure the thermostat. The
    tstat does not take a battery. Any ideas?
    Aabob
    Bob, Sep 4, 2011
  2. Sounds like a straight forward job for a HVAC service
    company.
    Christopher A. Young
    Learn more about Jesus
    www.lds.org
    "Bob" <> wrote in message
    does not
    thermostat. The
    Aabob
    Stormin Mormon, Sep 4, 2011
  3. "Bob" <> wrote in message
    > Aabob
    Plug the air handler/furnace into an UPS with external batteries, the APC
    SUA2200XL would work nicely. When the power fails turn off the system ASAP
    to save the battery life then turn it back on afterwards when power is
    restored. This means you still have to fiddle with the T-stat but at least
    it is just "flipping a switch" instead of reprogramming it.
    Daniel who wants to know, Sep 4, 2011
  4. Bob
    HVAC Guest
    On 9/4/2011 3:45 PM, Grumpy wrote:
    > "Bob"<> wrote in message news:...
    > I am sorry that is very hard to swallow
    Ya. That's what *she* said.
    "OK you cunts, let's see what you can do now" -Hit Girl
    http://www.youtube.com/watch?v=CjO7kBqTFqo
    HVAC, Sep 4, 2011
  5. Bob
    Steve Guest
    "Grumpy" <> wrote in message
    > news:...
    Some of the serial controlled controls DO NOT have batteries, they have an
    E-Prom and memory chips that are supposed to remember what all the settings
    are. If it goes to default settings when power is lost, there is an issue
    with either the control itself or one of the other mother baords in the
    system. There is a reason I don't install new systems using the serial
    control wiring.
    Steve, Sep 4, 2011
  6. Bob
    Steve Guest
    <.p.jm.@see_my_sig_for_address.com> wrote in message
    > On Sun, 4 Sep 2011 15:43:45 -0500, "Steve" <>
    >>news:...
    >>> news:...
    >>settings
    >>control wiring.
    > Do they still use that cheesy 3 conductor flat strip
    > bullshit that pushes in to their crap connector slot ?
    Most of them are using pin and socket type connector strips between the
    wall plate and control head.
    Steve, Sep 4, 2011
  7. Bob
    Steve Guest
    > On Sun, 4 Sep 2011 15:57:42 -0500, "Steve" <>
    >>news:...
    >>>>news:...
    >>>>> news:...
    >>>>an
    >>>>settings
    >>>>issue
    >>>>control wiring.
    > And behind that ? They used to use some BS clear flat
    > plastic ribbon crap .....
    They do on the cheap ones folks get from the big box stores, but not on the
    Honeywell controls that I use.
    Steve, Sep 4, 2011
  8. Bob
    PaxPerPoten Guest
    >> news:...
    I thought she said she could only swallow if it was hard.
    It is hardly too strong to say that the Constitution was made to guard
    the people against the dangers of good intentions. There are men in all
    ages who mean to govern well, but *They mean to govern*. They promise to
    be good masters, *but they mean to be masters*. Daniel Webster
    PaxPerPoten, Sep 4, 2011
  9. Bob
    Steve Guest
    "PaxPerPoten" <> wrote in message
    news:j40sl2$3q3$...
    >>> news:...
    *She* told him to spit it out cause it didn't belong to him.
    Steve, Sep 5, 2011
  10. <.p.jm.@see_my_sig_for_address.com> wrote in message
    > Ya beat me to the idea, but you got it wrong. You have to
    > feed just the control circuit, not the rest of the AHU ( like the fan
    > or heat strips )
    > No need for all that - the control circuit doesn't draw that much
    > power.
    I thought about that but wondered if the control board would go into lockout
    mode when nothing responded to its commands, IE the pressure switch on the
    draft inducer. If it did it requires a power cycle of the board and then
    you are back at square 1.
    Daniel who wants to know, Sep 5, 2011
  1. Replies:
    769
  2. Replies:
    21
    1,871
    m Ransley
    Dec 24, 2005
  3. Replies:
    401
  4. PAR
    22
    1,255
    Noon-Air
    Nov 8, 2004
  5. Replies:
    10
    1,027
    Noon-Air
    Dec 18, 2004
