wiring 3 switches in parallel
Discussion in 'Misc DIY' started by hleenhouts@hotmail.com, Mar 3, 2007.
  1. Guest
    Hello,
    I was wondering i f anyone can give me some info as how to go about
    the following. I need to extend an existing circuit with 3 additional
    lights each on a single pole switch. The switches are going to be
    placed in different locations in one room but I would like to wire
    them in parallel, in other words, the source goes to one switch and
    goes on to the following 2, without interrupting the power when I turn
    off one of those lights. A diagram or instreuctions would be great.
    Thanks in advance.
    , Mar 3, 2007
  2. Terry Guest
    On 3 Mar 2007 09:00:40 -0800, wrote:
    >Hello,
    >Thanks in advance.
    Wiring the switches will be the easy part. Installing the boxes and
    getting the wires from box to box will be the problem if you already
    have the sheet rock on the walls.
    http://tpub.com/content/construction/14026/css/14026_155.htm
    Here is a pretty good example. There are hundreds.
    Terry, Mar 3, 2007
  3. RBM Guest
    You would take your feed cable from where you're extending it from, and run
    it to the first switch box. Then you'd run another cable from that switch
    box to the next and so on. In each box, you connect the whites together and
    include the white that is going to the light controlled by that switch. You
    connect the black wires from the feed in and out, together, along with a
    pigtail to the switch that feeds the light in that box
    <> wrote in message
    > Hello,
    > Thanks in advance.
    RBM, Mar 3, 2007
  4. Randy Day Guest
    wrote:
    > Hello,
    > Thanks in advance.
    Is this what you mean? 3 lights, each controlled by a separate
    switch? Or did you mean something else?
    AC in ------------------------
    ( X ) ( X ) ( X ) Lights
    \ o \ o \ o
    \. \. \. on/off switches
    o o o
    (created by AACircuit v1.28 beta 10/06/04 www.tech-chat.de)
    Randy Day, Mar 3, 2007
  5. terry Guest
    On Mar 3, 2:00 pm, wrote:
    > Hello,
    > Thanks in advance.
    If you can't work that out it is respectfully suggested that you get
    someone competent to help.
    Need to ask a question like that perhaps suggests that there are other
    aspects of wiring expertise with which you are not familiar such as
    how to connect the grounds? Connection of wires within the 'octagon'
    boxes etc.
    Switches go in the live lead between the supply and the light. The
    neutrals (in North American practice anyway) are unswitched.
    You have however 'almost' answered your own question.
    As you mention the existing circuit is extended to the first switch
    which switches on the light associated with it. the wiring then goes
    to a second switch which switches/controls its light and so on.
    We presume the existing circuit has the capacity for three more
    lights? Lighting circuits are often not too heavily loaded but it
    should be checked.
    However you may be referring to ceiling wired light fixtures?
    In that case the extended wiring may go to the first ceiling fixture
    box where its live lead (usually black) will go down to a single pole
    wall switch to come back up to switch on that light. The wiring will
    then go to the second ceiling fixture box where the live lead will
    once again go down to a wall switch and come back up to switch on that
    light etc. The third one same way. This is something a handy man could
    do in less than than an hour.
    Colour of wires may be important in some jurisdictions and for
    insurance purposes. For example our inspectors 'prefer' red as
    'switched live' but will allow a white lead to be a 'switched' live,
    provided it is marked.
    I sometimes use red tape or red nail polish to identify a white wire
    which is a switched live although it is usually pretty obvious, in a
    wall switch box, anyway. Otherwise white is generally used for
    neutrals.
    Use proper wiring practice and materials such as 'wire nuts' etc.
    Ground all boxes and ensure ground is continuous from all of them back
    to the supply.
    terry, Mar 4, 2007
  1. Axel G
    1,116
    Axel G
    Apr 26, 2007
  2. Zeb Kagloonpop
    how to trace wiring for mystery switches?
    Zeb Kagloonpop, Aug 11, 2004, in forum: Misc DIY
    416
    Jimmie
    Aug 17, 2004
  3. Adam
    Parallel switches
    Adam, Nov 26, 2005, in forum: Home Repair
    430
  4. Adam
    Parallel switches in AC circuit
    Adam, Nov 26, 2005, in forum: Building Construction
    332
  5. Replies:
    20
    738
