where to buy lighter fluid?
Discussion in 'Home Repair' started by Nate Nagel, May 10, 2009.
  1. Nate Nagel
    Nate Nagel Guest
    do any drugstore chains still sell lighter fluid? I asked at CVS
    yesterday and they recommended a tobacconist's, but I'm guessing that's
    a waste of time, as wouldn't someone who likes good cigars/pipe tobacco
    be using wood matches rather than a Zippo?
    I'd really just like to have some for cleaning small stains in
    upholstery, but it seems quite hard to find. And I'm guessing that it
    can't be mail ordered :)
    nate
    replace "roosters" with "cox" to reply.
    http://members.cox.net/njnagel
  2. RicodJour
    RicodJour Guest
    Any hardware store will carry it.
    RicodJour, May 10, 2009
  3. fftt
    fftt Guest
    > nate
    > replace "roosters" with "cox" to reply.http://members.cox.net/njnagel
    http://www.zippocasemuseum.com/inde...ctid=416&directoryid= 264&ctrl=productdetails
    they changed the formulation to "reduce odor & lessen possible skin
    irritation", at least that's the party line, who knows? maybe
    the EPA or air pollution considerations
    you could try various naphthas, which are the "catch all name" for a
    general group of different flammable liquid mixtures of hydrocarbons
    lighter ones (lower molecular weight / density) are probably what you
    want....lighter fluids being towards the lighter end and hopefully
    with the fewest impurities
    cheers
    Bob
    fftt, May 10, 2009
  4. dicko
    dicko Guest
    Mineral spirits
    dicko, May 10, 2009
  5. Nate Nagel
    Nate Nagel Guest
    My local hardware store told me to try CVS. CVS told me to try the
    hardware store. I left neither with lighter fluid in my possession.
    nate
  6. Doug Miller
    Doug Miller Guest
    Go back to the hardware store and ask them for naphtha. It's the same thing.
    Doug Miller, May 10, 2009
  7. Oren
    Oren Guest
    On Sun, 10 May 2009 14:27:38 -0400, Nate Nagel <>
    I have a small collection of Zippo lighters. Check out the site for a
    location near you.
    http://www.zippo.com/index.aspx?bhcp=1
    Zippo lighter fluid.
    Oren, May 10, 2009
  8. Red Green <postmaster@127.0.0.1> writes:
    >> You could also use naptha paint thinner. Essentially the same stuff.
    >It's exactly the same as naptha. Look at the contents of a container of
    >lighter fluid - Contents: naptha.
    Yeah, but not all naptha is the same chemically. Naptha isn't a single
    pure substance; it's a soup of several different hydrocarbons that all
    have relatively low boiling points, and come off the distillation column
    in the refinery near each other. If you're just going to burn it, it's
    probably all pretty much equivalent, but if you're using it as a
    solvent, you may care what it is chemically.
    My own experience is that "lighter fluid" naptha and "paint thinner"
    naptha are both pretty good are removing the adhesive from sticky
    labels, while not attacking most plastics (at least over the span of a
    minute or so). While "camping fuel" naptha is a lot more aggressive at
    dissolving some plastics; I don't recommend it for sticky labels.
    When I'm doing something particularly sensitive to contamination, like
    cleaning gunk off a lens when water plus detergent (lens cleaner) and
    alcohol won't touch it, I tend to use Ronsonol lighter fluid. It
    evaporates with no residue.
    You can often buy Xylene from the same shelves as generic "paint
    thinner", and that's a well-defined single chemical compound no matter
    who makes it. But it's a pretty strong solvent, and has a strong smell
    too, so I avoid it when I can.
    Dave
    Dave Martindale, May 11, 2009
  9. Guest
    > nate
    If all else fails...try Coleman stove fuel. But be REAL carefull!!!
    , May 11, 2009
  10. Pat
    Pat Guest
    > nate
    Walmart carries it near the tobacco section. Usually it's by one
    register, down real low at floor level.
    Pat, May 11, 2009
  11. harry k
    harry k Guest
    > > nate
    I always got it at the grocery store. Making a trip there today and
    will look to see if things related to smoking have changed that much.
    Of course the old type lighters using that stuff are probably getting
    pretty rare as the butane ones are so much more convenient.
    I would also suspect that barbecue starter fluid is probably the same
    stuff.
    Harry K
    harry k, May 11, 2009
    #11
  12. K
    K Guest
    >> that's a waste of time, as wouldn't someone who likes good
    >> cigars/pipe tobacco be using wood matches rather than a Zippo?
    >> nate
    K, May 11, 2009
    #12
  13. K
    K Guest
    >> nate
    Supermarkets also sell it - look in the vicinity of the cigarettes.
    K, May 11, 2009
    #13
  14. DerbyDad03
    DerbyDad03 Guest
    > nate
    Despite what others have suggested (hardware stores, supermarkets,
    etc) I too have been finding it harder and harder to find Zippo and
    Rosignol (sp?) in my area. I tried a tobacco shop and the price was
    ridiculous, especially for the amounts I use.
    My last purchase was from the following site. Any order of three or
    more 12oz cans, including shipping, gets the per-ounce price below
    anything I can find locally - and I don't have to drive all over town.
    I'm ready to place my next order...
    http://www.uptownenterprises.com/Zippo-Lighter-Fluid-12-oz-can-P46.aspx?AFID=1
    DerbyDad03, May 12, 2009
    #14
  1. bwell
    down lighter how to wire in
    bwell, Jul 14, 2006, in forum: Misc DIY
    9
    763
    bwell
    Jul 23, 2006
  2. Lobster
    12V car cig lighter adapters - safe?
    Lobster, Jul 28, 2008, in forum: Misc DIY
    119
    2,046
    PCPaul
    Aug 5, 2008
  3. Lobster
    717
    John Henderson
    Sep 7, 2008
  4. Dugie
    509
    Dugie
    Jul 6, 2004
  5. Charlie S.
    Neighbor's Lighter fluid fumes
    Charlie S., Jun 20, 2006, in forum: Misc DIY
    28
    1,136
    Banty
    Jun 21, 2006
