When to use plumbers mait/silicone sealant
Discussion in 'Misc DIY' started by AndyP, Oct 18, 2004.
  1. AndyP
    AndyP Guest
    Probably a simple question but:
    When should I be using plumbers mait and when should I use silicone sealant?
    Obviously I use silicone for things like round edge of the bath etc.
    However, on my new bath, the instructions said to use silicone around the
    rim of the waste to seal it to the bath.. I thought I was supposed to use
    plumbers mait. The sealant I got from Wickes (their kitchen and bathroom
    stuff, which says it's suitable for baths, showers, etc) says it's not
    suitable for continual immersion in water, which seems to suggest I
    shouldn't use it for the bath. The bloke in Wickes recommended I use their
    "external leak sealer and jointing compound" round the waste.. I'm a bit
    confused by all this.
    As per another post, I'm also about to put a new tank connector into my cw
    cistern in the loft. If I want to be really paranoid, would putting some
    plumbers mait in there make it less likely to leak, or would it be
    pointless?
    Thanks,
    Andy
    AndyP, Oct 18, 2004
  2. AndyP
    tarquin Guest
    On Mon, 18 Oct 2004 12:59:08 +0000 (UTC), "AndyP"
    >pointless?
    it would probably be counter-productive IMHO,just use the washers as
    supplied with the tank connector fitting.
    joe
    >Thanks,
    >Andy
    tarquin, Oct 18, 2004
  3. AndyP
    Lee Guest
    Use Fernox LS-X it's great for these applications.
    Lee
    Email address is valid, but is unlikely to be read.
    Lee, Oct 18, 2004
  4. AndyP
    AndyP Guest
    "tarquin" <> wrote in message
    cw
    > >pointless?
    Sadly no washers were supplied (tank connector bought from Wickes - they
    sell many different types of washer separately, although it's not obvious
    which sort I should use).
    Cheers,
    Andy
    AndyP, Oct 18, 2004
  5. AndyP
    Al Reynolds Guest
    Almost never.
    Most of the time.
    > [snip]
    > pointless?
    Whenever I've used plumber's mait in any joint, i've ended
    up taking it out, cleaning it all off, and using silicone or the
    correct washer. I reckon you'd be best to start with silicone
    or the correct washer.
    AFAICR, Belfast sink wastes need plumber's mait, but
    I don't have one so I'm not sure about that.
    HTH,
    Al
    Al Reynolds, Oct 18, 2004
  6. AndyP
    AndyP Guest
    "Al Reynolds" <> wrote in message
    news:cl0kiq$smq$...
    > Almost never.
    > Most of the time.
    So is there a brand of silicone suitable for total immersion in water - eg
    round bath waste? As I mentioned, the stuff I've got (from Wickes) says it's
    not suitable for this.
    Thanks,
    Andy
    > > [snip]
    cw
    > > pointless?
    > HTH,
    > Al
    AndyP, Oct 18, 2004
  7. AndyP
    Grunff Guest
    Then it's not silicone. Silicone is always suitable for immersion in water.
    Grunff
    Grunff, Oct 18, 2004
  8. AndyP
    Ed Sirett Guest
    > pointless?
    There are very few places where Mait (stay soft putty) is needed. Basin
    wastes is one. Useful also when ceramic is on ceramic to soften the
    contact, i.e. basin on pedestal, or WC pan on floor tiles.
    Ed Sirett, Oct 18, 2004
  9. AndyP
    Al Reynolds Guest
    "AndyP" <> wrote in message
    news:cl0p8i$eks$...
    > news:cl0kiq$smq$...
    >> Almost never.
    >> Most of the time.
    > it's
    I always use Unibond Sanitary Sealant.
    Never had any problems on wastes etc.
    Al
  10. AndyP
    Pete C Guest
    On Mon, 18 Oct 2004 15:59:14 +0000 (UTC), "AndyP"
    If it's cheap stuff maybe it has fillers in. Silicone has long been
    used for holding glass fish tanks together so the proper stuff can be
    used in that way.
    cheers,
    Pete.
    Pete C, Oct 18, 2004
    Silicone sealant is not appropiate for surfaces which need to slide over
    one another to seal - e.g. threads.
    In every other way, its better than sliced bread, except for toast.
    The Natural Philosopher, Oct 19, 2004
    #11
  12. In article <cl0p8i$eks$>,
    > eg round bath waste? As I mentioned, the stuff I've got (from Wickes)
    > says it's not suitable for this.
    Fernox LS-X as already mentioned.
    *Why is the man who invests all your money called a broker?
    Dave Plowman London SW
    Dave Plowman (News), Oct 19, 2004
    #12
  13. AndyP
    Steve Firth Guest
    Not silicone, but Evostick Nail and Seal is suitable for prolonged
    immersion. It's much better than silicone, even the Fernox LS stuff
    which is just the usual piss-poor silicon in a small tube.
    Quanto e quel cane nella vetrina (arf, arf)
    Quello con coda scuotente
    Spero che il cane sia vendita
    Steve Firth, Oct 19, 2004
    #13
  14. AndyP
    AndyP Guest
    "Grunff" <> wrote in message
    eg
    it's
    water.
    > Grunff
    Hmm. Well it definately says it's silicone on the tube. And it definately
    says it's not suitable for continual immersion in water. Sounds like there
    are different "grades" of the stuff with the Wickes variety being down the
    bottom end.
    Cheers,
    Andy
    AndyP, Oct 19, 2004
    #14
  15. AndyP
    Pete C Guest
    On Tue, 19 Oct 2004 07:06:30 +0100, Andy Wade
    <> wrote:
    >... a disaster. AIUI you should _never_ use linseed oil based compounds
    >(such as plumbers' mait or boss white) on plastic fittings.
    >(I'm assuming you mean a plastic cistern, not an old galvanized one.)
    Does the oil affect the plastic in any way?
    cheers,
    Pete.
    Pete C, Oct 19, 2004
    #15
  16. AndyP
    Rob Graham Guest
    Andy Wade <> wrote in message news:<417623df$0$27540$>...
    > I think it can do, with some types of plastic, possibly by a reaction
    > with any plasticiser, causing embrittlement. I first came across the
    > advice in the instructions that came with a Ferham plastic (PVC,
    > probably) cistern and have kept it in mind ever since.
    Ah well, in that case I'm going to have problems sometime in the
    future !! Firm believer in Plumber's Mait for traps and the likes.
    At least I might now have an idea what was the cause.
    As a side question - what is the best way of getting taps to tighten
    properly onto the bath or basin; previously you could rely on the
    stiffness of the copper pipe to help with this but with flexible
    couplings and plastic washers I'm finding it difficult to get taps to
    lock properly to the bath, etc.
    Rob
    Rob Graham, Oct 20, 2004
    #16
  1. hays
    Plumbers Mait ???
    hays, Oct 7, 2003, in forum: Misc DIY
    1,029
    John Stumbles
    Oct 8, 2003
  2. Eric Dockum
    where does your Mait come from?
    Eric Dockum, Jan 7, 2004, in forum: UK DIY
    444
    Andy Dingley
    Jan 10, 2004
  3. Silicone vs silicone
    , Apr 29, 2006, in forum: UK DIY
    398
    Mike Halmarack
    Apr 30, 2006
  4. Walter Cohen
    Silicone sealant vs silicone adhesive?
    Walter Cohen, Oct 30, 2007, in forum: Home Repair
    823
    Walter Cohen
    Oct 31, 2007
  5. george [dicegeorge]
    PTFE plumbers mait etc
    george [dicegeorge], Dec 14, 2010, in forum: UK DIY
    27
    2,697
    Tim Watts
    Dec 26, 2010
