What's this fence been painted with?
Discussion in 'Misc DIY' started by mike, Jun 7, 2009.
  1. mike
    mike Guest
    Can anyone identify the finish that's been used on this fence?
    http://i18.photobucket.com/albums/b104/mkpb/fence.jpg
    The pic on the left shows that some of it's developed a sort of
    stringy texture that comes off like dried glue, but in other areas it
    doesn't seem like it'll come off easily at all.
    If I paint over it with some sort of shed and fence treatment, is it
    likely to take?
    Thanks for any advice.
    mike, Jun 7, 2009
  2. mike
    Rod Guest
    > likely to take?
    Looks like common-or-garden modern fence finish - Cuprinol fence paint
    or similar. When applied to smooth surfaces (e.g. planed timber) it does
    tend to come off as you describe. On a good rough surface (old-fashioned
    sawn timber) it adheres quite well.
    Over-painting with similar products, even if you prepare very well, is
    likely to have the same end result.
    If you can put the effort in (and the scale is small enough), maybe
    something like this:
    <http://www.johnstonestrade.com/product-range/product.aspx?product=Quick_Dry_Opaque_Wood_Finish>
    Or various other manufacturers' offerings.
    (I *do* work for a company in the same group as Johnstones but nothing
    to do with paint.)
    Rod
    Hypothyroidism is a seriously debilitating condition with an insidious
    onset.
    Although common it frequently goes undiagnosed.
    <www.thyromind.info> <www.thyroiduk.org> <www.altsupportthyroid.org>
    Rod, Jun 7, 2009
  1. Replies:
    479
    Owain
    Jan 14, 2005
  2. Steven Campbell
    10
    414
    Rob Morley
    Feb 7, 2006
  3. TaraDanielle
    remove wallpaper that has been painted over?
    TaraDanielle, Feb 4, 2004, in forum: Misc DIY
    9
    576
  4. Replies:
    569
    willshak
    Jun 7, 2007
  5. David WE Roberts
    20
    1,167
    David WE Roberts
    Sep 10, 2009
