well pump squeal
Discussion in 'Home Repair' started by Mark Sherman, Apr 15, 2006.
  1. Mark Sherman
    Mark Sherman Guest
    My well pump (indoor, on top of the pressure tank) has started to squeal
    when it runs. My gut thoughts are
    1. Pump going bad.
    2. Air getting in the line.
    Any thoughts?
    How to test?
  2. Mark Sherman
    georgie Guest
    "Mark Sherman" <msherm@yahoo_mungemymail.com> wrote in message
    news:32b0g.1979$7w6.387@trnddc02...
    > 1. Pump going bad.
    > Any thoughts?
    > How to test?
    <snip>
    Sound like the motor bearings are going out. Don't know how to test it, but
    our pressure tank pump lasted around a year after it started getting really
    loud.
    g
    georgie, Apr 16, 2006
  3. Mark Sherman
    Guest
    >> 1. Pump going bad.
    >> Any thoughts?
    >> How to test?
    ><snip>
    >loud.
    >g
    Use a long screwdriver and listen for the bad bearing. Hold the tip on
    each end of the pump casting, holding the handle against the bone next
    to your ear. and one will have a grumble if the bearing is going.
    You can usually get the inner impeller housing and pump motor part off
    without disturbing the plumbing by separating the impeller housing.
    You can either replace the bearings yourself or take it to a
    moror/pump shop. If you do it yourself buy a seal kit too. The pump
    should last another 20 years with new bearings and seals..
    , Apr 17, 2006
  1. Martin Hirsch
    Attic fan making a high pictch squeal
    Martin Hirsch, May 10, 2004, in forum: Home Repair
    599
    Michael Nickolas
    May 10, 2004
  2. Jim Witte
    392
    Jim Witte
    Aug 15, 2004
  3. BobN
    578
  4. PHIL
    Window A/C starting to squeal
    PHIL, Jun 14, 2005, in forum: Misc DIY
    13
    456
  5. Boiler squeal
    , Nov 24, 2003, in forum: UK Home Improvement
    646
