Waterside MC250 water softener
Discussion in 'UK DIY' started by NickW, Aug 17, 2005.
  1. NickW
    NickW Guest
    We moved into a house with one of these installed. There were no
    instructions left for it.
    Is it just a case of:
    - making sure the relevant valves are open
    - making sure there is enough salt in there
    - turning it on...?
    We tried this and it continually kicks out water down its waste pipe.
    Is this normal or is something wrong?
    Nick.
    NickW, Aug 17, 2005
  2. Sparks
    Sparks Guest
    "NickW" <> wrote in message
    Yes, usually there are three, one in, one out, and one bypass - the bypass
    valve is situated between the inlet and outlet, before the other valves -
    this should be OFF, the inlet and outlet should be on.
    Yup
    > - turning it on...?
    There are usually two waste pipes, one of them is an overflow, and one is a
    drain - the overflow should not pass any water in normal operation, however,
    if it has been played about with, it might do for the first cycle.
    When you say constantly, how long did you leave it doing it?
    When it is regenerating, ion exchange water softeners throw out water,
    chucking out all the limescale.
    Sparks...
    Sparks, Aug 17, 2005
  3. NickW
    NickW Guest
    Thanks, I hoped it was something like that. I didn't leave it on that
    long, maybe only a minute or probably less.
    Another thing - it asks for the water hardness Clarke number. I guessed
    at 30 because I found something on the web for somewhere near here
    (Suffolk, IP6). Is this crucial? Should I ring the water company to
    find a more precise value?
    Nick
    NickW, Aug 17, 2005
  4. Sparks
    Sparks Guest
    The hardness setting is so it can calculate how much salt it needs, so it is
    best to get it as accurate a possible, or you will either not be softening
    enough, or wasting salt!
    You can buy some tester kits (not sure where though!) that will measure it
    if you can't get the details from the water co (Or want to check it!) my new
    softener came with one, but I have used it now!.
    Looking online, it looks to be a meter based softener, so it will measure
    the water you use, and regenerate when needed (This is the better type!)
    here are some details I found on
    http://www.slough-heating.co.uk/conditioner.htm
    Waterside MC250 Ultra Water Softener
    £430.00
    New improved MC250 Ultra, the most technically advanced Water Softener
    available in the UK.
    - The only UK manufactured vavle
    - Simple to install
    - No complicaed controls to set up
    - No clock setting
    - Low salt level alarm
    - Mini regeneration cycle
    - High softened water capacity 1 to 8 people in one softener
    - Automatic controls for maximum slt and water efficiency
    - Supplied complete with all fittings for a professional installation
    - Size (HxWxD) : 610 x 290 x 495mm
    Sparks...
  5. Sparks
    Sparks Guest
    "Sparks" <> wrote in message
    news:430340c1$0$38037$...
    > news:...
    I have just found the following phone number on a website, you may be able
    to get a manual from them.
    WATERSIDE Telephone 01376 334200
    (From http://www.colemanwater.co.uk/html/comparison.htm)
    Sparks...
  6. Capitol
    Capitol Guest
    > - turning it on...?
    Sounds like the valves are set to the wrong position, or it's in regen
    mode. First check the clock is set to the correct time of day. The
    factory setting regens at 2.00am. Also check that the timer is running!
    There are three water valves connected to the pipework, inlet, ie water
    in from the main, bypass, which allows the unit to be bypassed hence
    water does not flow through the softener, and outlet, water flows to
    the tanks etc. On the back of the unit, there are normally four
    connections. From L to R as viewed from the rear these are, Overflow( at
    a lower level than the other connections), Outlet connection, Drain
    connection( used during regen) and inlet connection. For normal
    operation, inlet valve is open, bypass is closed, outlet is open. I'd
    suggest you talk to Waterside nicely and ask them for the instruction
    leaflet. I have used one of their units for 20 years without any
    problems, but it's a mechanical timer unit.
    Regards
    Capitol
    Capitol, Aug 17, 2005
  7. NickW
    NickW Guest
    Thanks for all the replies. I've tried running it on a setting of 25
    degrees Clarke (I got this number from a neighbour). It shows "r0" on
    the display for a couple of minutes and water is continuously venting
    down the waste pipe.
    However, it continues to vent water and the display changes to "E2" -
    which sounds like an error to me. I let this carry on for a further ten
    minutes with no change. I gave up and turned it off.
    One clue - water vents down the waste pipe even when the unit is not
    switched on... a valve stuck open perhaps?
    I've been trying all day to get through to their helpline but it's
    constantly engaged and ringback doesn't seem to work. Perhaps they have
    it off the hook!
    Anyone know what this "E2" business is about?
    Nick
    NickW, Aug 30, 2005
  8. poopy13pets
    poopy13pets Guest
    > Thanks
    > Nick
    Hi Nick
    I have brought one of these softners, Error E2 was displayed and
    found the nylon cog on the motor was split and so although on power u
    the moter was running the cog stayed still and did not turn the gea
    assembly, I contacted culligan uk who now own waterside and got
    replacement motor which came with a new brass cog.
    Error E2 now gone from the display and it all runs as it should.
    But there still is problems as the machine is not softening the wate
    so maybe the resin is knackered, any advice on this would be great.
    Richar
    poopy13pets
    poopy13pets, May 20, 2007
  1. much_to_do
    51
    1,311
    Andy Hall
    Feb 14, 2004
  2. Cordless Crazy
    Water-king mains water softener/conditioner
    Cordless Crazy, Aug 31, 2005, in forum: UK DIY
    294
    Cordless Crazy
    Aug 31, 2005
  3. Cordless Crazy
    340
    Cordless Crazy
    Aug 31, 2005
  4. bixx
    1,384
  5. Ken Williams
    Waterside question...
    Ken Williams, May 19, 2004, in forum: HVAC
    233
    Ken Williams
    May 21, 2004
