Water Well problems
Discussion in 'Plumbing' started by Rocko, Jul 15, 2006.
  1. Rocko
    Rocko Guest
    I have a drilled water well with a jet pump , July 2 i woke up to no
    water, i checked the pump, it was running, checked the pump discharge,
    it had water there but no out put. I installed a new jet pump, We had
    water for about 1/2 hour, then nothing, checked pipes going down the
    well, they were full as was the pump, it turned but no output. I
    returned the pump to Lowes and got another jet pump , ejector and foot
    valve. Filled all pipes and pump again. Still no output. July 4th i
    pulled every thing out of the hole, Foot valve was setting at 175 ft.
    Water was 42 ft. from the top of the well. I again returned the pump. I
    bought a 1 hp submersible pump , new pipe and pressure switch. The pump
    was set at 200 ft. We had water instantly, but it was real red looking,
    After a few days, i pulled the pipe up and cut 23 ft. off and lowered
    it back down. a day or so later the water cleared up. July 13 I
    watered the garden in the evening, forgetting to shut it off till 4 AM.
    Yesterday July 14 while taking a shower, the water started pulsating,
    hot cold hot cold and turned a reddish tint again. Please any one have
    any ideas or info for me as to what is going on with this well ? I
    have checked the pressure tank pressure it is set to 38 psi, the pump
    kicks on at 40 psi.
    Rocko, Jul 15, 2006
  2. Ned Flanders
    Ned Flanders Guest
    has this well always worked before july 2 ?
    call a well driller he will prob be cheaper than a plumber but he will know
    how to check your well pump.
    "Bob Wheatley" <> wrote in message
    > "Rocko" <> wrote in message
    > news:...
    >> kicks on at 40 psi. >
    > You're not going to like this....
    > but it sounds like you may have to re-drill. If the well is collapsed or
    > the screen stopped up or damaged you will have the conditions you
    > described. With water at 42 feet and the well at over 200 feet that's a
    > reasonable water table (although it seems a bit low) but if the water is
    > having a hard time getting through the screen at the base of the well then
    > the pump simply pushes out that 150' +/- column of water and then there's
    > nothing to pump until it manages to refill. Which could take minutes, or
    > hours, or days.
    > By lowering it you may have found a point low enough that the well could
    > maintain but ending up with water that is coming through a collapse or a
    > damaged screen and not have enough time to settle before being pumped up.
    > Hence the discoloration.
    > I'd get a well man out and get a trained set of eyes on it. It could be
    > something else but to a plumber who has dealt with wells and septic
    > systems for 30 years, it doesn't good.
    > Good luck.
    > Bob Wheatley
    Ned Flanders, Jul 16, 2006
  1. Artesian Well vs. Dug Well
    , May 16, 2006, in forum: Home Repair
    14
    1,130
    Robert Gammon
    May 18, 2006
  2. crenycrew
    water well problems
    crenycrew, Dec 1, 2006, in forum: Home Repair
    204
    crenycrew
    Dec 1, 2006
  3. Replies:
    313
    Michael Strickland
    Jan 9, 2007
  4. Rocko
    Water Well problems
    Rocko, Jul 15, 2006, in forum: Plumbing
    264
    Rocko
    Jul 15, 2006
  5. Rocko
    Water Well problems
    226
    Rocko
    Jul 15, 2006
Share This Page
