Water in AC condensate pan does not drain (drain not clogged)
Discussion in 'HVAC' started by wilcoj@hotmail.com, Jul 7, 2006.
  1. Guest
    I live in an apartment and the AC they have installed has a condensate
    pan below the coils that drip from condensation. The drain for the pan
    is located on the side of the pan towards the bottom but there is a
    slight lip allowing about 1/6" of water to remain in the pan without
    draining. I have been told by the maintenance people that this is
    normal and to be expected, however I am beginning to smell mildew and
    the insulation on the inside of the unit is filthy.
    Can someone please let me know how I should proceed with this
    situation? I really need an expert's opinion.
    , Jul 7, 2006
  2. Guest
    If the drain is working then it is normal. Pour a little bleach into
    the drain pan every now and then to kill microbes etc. That should
    take care of the problem.
    > Thanks
    , Jul 7, 2006
  3. Answer B is correct. The condensate is (supposed to) evaporate off the
    condensor, and carry away more heat.
    Christopher A. Young
    You can't shout down a troll.
    You have to starve them.
    "Dave M." <> wrote in message
    news:Xns97F99B0998454DaveM@216.196.97.131...
    wrote in news:1152286803.229811.87100@
    75g2000cwc.googlegroups.com:
    condensate
    pan
    and
    > Thanks
    If you have a window unit, many collect water under the edge of the
    condensor cooling fan. The spinning fan agitates the water and blows
    it
    through the condensor coil and out the back of the unit. I got tired
    of the
    noise from the swishing water in my A/C and drilled a hole in the
    bottom of
    the pan under the fan to dain the water.
    I guess the purpose of the water spray is to prevent dripping under
    the
    unit and/or further cooling of the condensor.
    Dave M.
    Stormin Mormon, Jul 8, 2006
  4. "Stormin Mormon" <cayoung61-&spamblock*> wrote in message
    news:NqCrg.46107$...
    WRONG !!!
    Some of the condensate is sposed to just sit there and collect spores so
    that mold can form.
    SVL
    PrecisionMachinisT, Jul 8, 2006
  5. That must be the Legionaire's model of AC?
    "PrecisionMachinisT" <> wrote in message
    news:e8mtgv$1dhc$...
    WRONG !!!
    so
    that mold can form.
    SVL
  6. Guest
    >Thanks
    your system was installed by morons. tell them to come back and
    re-level your ac unit so that the unit slopes towards the drain such
    that ALL the water drains from the drain pan.
    Have your attorney threaten the installing contractor with Mold
    Litigation if necessary to get corrective action. A few digital
    pictures really helps.
    , Jul 8, 2006
  7. B-Hate-Me Guest
    <.p.jm@see_my_sig_for_address.com> wrote in message
    >>I got tired of the
    >>noise from the swishing water in my A/C and drilled a hole in the bottom
    >>of
    >> I guess the purpose of the water spray is to prevent dripping under the
    >>Dave M.
    > Seeing as you don't even understand the question, don't try to
    > answer it.
    Ya but how the hell's he gonna dain the water?
    B-Hate-Me, Jul 8, 2006
  8. Bubba Guest
    >>Thanks
    Christ Fish! Take a fuckin pill. Read the Ops post again and think!
    Look what he is telling you.
    First he lives in an Apartment. We all know what kind of maintenance
    happens at an apt complex.
    Next, notice the term "lip" and where/how he uses it. He's talking
    about how the condensate drain connection cannot be made completely to
    the bottom of the tray (just like every other drain pan). If he wants
    all the water to drain from the pan he needs to drill a hole in the
    bottom of the pan and the top of his head. This will let the water out
    and the noxious gasses from his head.
    Lastly, the Op tosses in terms about "mildew", "filthy insulation",
    "expert" and "how to proceed with this situation".
    He's practically crying out "I wanna sue, I wanna be rich, I dont
    wanna work, Im a low-life apt dweller and I wanna live off someone
    else's money".
    Im ashamed of you Fish. "You've been here how long? :)
    Look for UPS. I'll be sending you that crystal ball.
    Bubba
    Bubba, Jul 8, 2006
  9. Guest
    Some water will remain in pan due to fitting drain connects to. You
    should not get mold because condensate is formed and drains leaving new
    behind. Sometimes a funky slime forms in pans due to dust etc. You can
    buy tablets to place in the pan to help with this. If you can
    reach..you could always shim the back of the pan so more drains out. I
    don't think it's anything to worry about. Maybe water is leaking around
    unit causing mold, or you have no trap and odors are coming up the
    drain??
    As for the guy with the window unit. The water is spashed around and
    cools the condensor which increases your sub-cooling thus efficiency.
    , Jul 9, 2006
  10. Guest
    On Sat, 08 Jul 2006 14:24:27 -0400, Bubba <>
    >>>Thanks
    >else's money".
    >Bubba
    hot damn! I havent hooked a big mouthed Bubba in such a long time I
    thought I forgot how to bass fish !!
    hey speaking of such......
    http://www.signonsandiego.com/sports/outdoors/20060320-1251-bn20bass.html
    , Jul 9, 2006
  11. Bubba Guest
    >>>>Thanks
    >>else's money".
    >>Bubba
    Well........................, we all gotta have fun somehow. :)
    Bubba
    Bubba, Jul 10, 2006
    #11
  12. Guest
    Actually I just want to get it fixed since I am sensitive to these sort
    of things. I want an expert's opinion so I can get it fixed correctly.
    I just moved here and I want to be comfortable. I already have a good
    job and work for a living (but thanks for the stereo type).
    > >>Thanks
    > else's money".
    > Bubba
    , Jul 10, 2006
    #12
  13. Guest
    Thanks this was the kind of advice I was looking for. What kind of
    tablets do you recommend? The maintenance guy put some fast acting
    ones in that disolved really quickly, so I was hoping for something a
    bit more long term. The bottom of the cooling portion sits in a
    plastic tray. Do I need to be concerned about damaging the unit if I
    use a tablet that is bleach based?
    As to your question, the drain looks trapped and I dont think the odors
    are coming up from there and I havent spotted any leaks. Over the
    weekend I flushed out the pan with some water and cleaned up all the
    bits of grime out from it, then poured some bleach/water mixture into
    the pan to hopefully address anything else.
    The maintenace guy shim'd the back of the unit a bit and it seems like
    its got a smaller amount sitting in the tray now but there is still a
    bit.
    They have some duct cleaners scheduled to come out this morning,
    hopefully they will go over the inside insulation with a good
    detergent.
    Any other ideas?
    Thanks!
    > drain??
    , Jul 10, 2006
    #13
  14. Guest
    Nah,
    Sounds like you got it covered. Spray a bleach solution on anything
    that looks like mold. Add about a cup of bleach a month to your pan
    and that will help keep the drain lines from cloggin and help kill
    bacteria.
    You can buy the tablets or just spend the $1 on a big bottle of bleach.
    > bit.
    > detergent.
    > Any other ideas?
    > Thanks!
    > > drain??
    , Jul 10, 2006
    #14
  15. Guest
    Take the cover off. Clean the inside of the unit with compress air.
    Use a small brush to lossen the rust and debris that have been
    collected inside the unit. Clean with compress air again. After the
    debris have been removed, wipe the inside surfaces with a bleach
    solution.
    If the evaporator is dirty, clean it with a water spray. Do it
    carefully so that the water doesn't get into the electrical parts.
    I am amazed how dirty window air conditioners are and why people don't
    get sick from the air they put out.
    wrote:
    > Nah,
    > bacteria.
    > > bit.
    > > detergent.
    > > Any other ideas?
    > > Thanks!
    > > > drain??
    , Jul 10, 2006
    #15
  16. Guest
    aka-SBM wrote:
    > <> wrote in message
    > news:...
    > > solution.
    > Actually, it would be better to clean the coil properly.
    > No bleach should be used on a unit. Ever. Have you looked up how corrosive
    > it is?
    A weak solution is not very corrosive. One washes clothes with it and
    people swim in it.
    > Again, it would be better to do it properly.
    What is the proper procedure?
    > Cause....the air they put out is the same air that goes into them?
    > If the shits in the unit, its not in the air?
    The air passes through the evaporator. The bottom inch of the
    evaporator can have an accumulation of mold and rust. The evaporator
    can also be coated with grease and grim. Grease and grim also
    accumulate on the fan surface and the inside surfaces of the air outlet
    chamber.
    > > wrote:
    > >> Nah,
    > >> bacteria.
    > >> > bit.
    > >> > detergent.
    > >> > Any other ideas?
    > >> > Thanks!
    > >> > > new
    > >> > > can
    > >> > > I
    > >> > > around
    > >> > > drain??
    , Jul 10, 2006
    #16
  17. Re: Water in AC condensate pan / cleaning unit
    corrosive
    > it is?
    people swim in it.
    CY: And even a weak solution will reduce mold and mildew. 10% of the
    original strength is about right.
    CY: Assortment of different techniques. I've never cleaned an
    evaporator while it was still mounted in an air handler, so I can't
    comment.
    don't
    outlet
    chamber.
    CY: Also, some window AC have mold and mildew. And brown film if a
    smoker owned the unit. As to window AC, I know that non-acid coil
    cleaner removes the smokers smell quite effectively.
    Stormin Mormon, Jul 10, 2006
    #17
  18. ~^Johnny^~ Guest
    Microbes?
    Mold is a fungus.
    -john
    wide-open at throttle dot info
    ~^Johnny^~, Jul 11, 2006
    #18
  1. trader-of-some-jacks
    364
    Terry
    Dec 15, 2003
  2. Replies:
    9
    348
    Edwin Pawlowski
    Jul 8, 2006
  3. Aaron
    840
    Aaron
    Oct 6, 2007
  4. Condensate pump pan?
    , May 9, 2011, in forum: Home Repair
    15
    682
  5. Replies:
    14
    1,263
    bud--
    Dec 27, 2011
