Water damaged ceiling - brown marks
Discussion in 'UK DIY' started by Gioconda, Aug 23, 2005.
  1. Gioconda
    Gioconda Guest
    Does anybody know how to paint over the marks left by a water drip on
    ceiling? I've been told to paint it silver first and then white....i
    this a known technique?
    Gioconda
    > Thanks.
    Hi you can get some stain block, I think it is made by polycell!
    Ensure the plaster is completely dry and paint stain block on, i
    should stop the stain from showing through. It worked on my walls whe
    the shower was leaking! Then paint over the stain block( once it ha
    dried) with your chosen paint.
    Good luc
    weekendwarrior
    weekendwarrior, Aug 23, 2005
  3. Gioconda
    Set Square Guest
    weekendwarrior <> wrote:
    >> on a ceiling? I've been told to paint it silver first and then
    >> white....is this a known technique?
    >> Thanks.
    > Ensure the plaster is completely dry and paint stain block on, it
    > should stop the stain from showing through. It worked on my walls when
    > the shower was leaking! Then paint over the stain block( once it has
    > Good luck
    Or any oil-based paint works just as well. I use white oil-based undercoat,
    and then finish with emulsion when dry.
    Cheers,
    Set Square
    ______
    Please reply to newsgroup. Reply address is invalid.
    Set Square, Aug 23, 2005
  4. Gioconda
    zaax Guest
    > > Thanks.
    > Good luck
    Surely if it's staining after re-painting with emulsion it's still wet
    zaax
    zaax, Aug 24, 2005
  5. Gioconda
    Set Square Guest
    >>> Thanks.
    >> when the shower was leaking! Then paint over the stain block( once
    >> it has dried) with your chosen paint.
    >> Good luck
    No. Stain will show through emulsion - long after the leak has been cured -
    if not blocked with oil paint or stain block.
    Cheers,
    Set Square
    ______
    Set Square, Aug 24, 2005
  1. jacquieg
    brown marks on marble back panel
    jacquieg, May 13, 2006, in forum: UK DIY
    300
    jacquieg
    May 13, 2006
  2. Replies:
    10
    1,418
    belto
    Sep 20, 2006
  3. Replies:
    261
    radire
    Nov 26, 2007
  4. Replies:
    637
    The Grim Reaper
    Sep 15, 2006
  5. Geoff Pearson
    Brown Paint round brown plastic windows?
    Geoff Pearson, Jul 24, 2012, in forum: UK DIY
    499
    Geoff Pearson
    Jul 26, 2012
