Washing Machine noise
Discussion in 'Misc DIY' started by cmcdonald@valornet.com, Apr 23, 2005.
  1. Guest
    Hello.
    I have a kitchenaid washing machine. Recently it began making a
    buzzing noise before a cycle or before the spin cycle. It happens when
    the water is filling into the machine.
    Thinking that my fill hoses were old (approx 4 years), I replaced them.
    After replacing, the noise remained.
    If the noise starts, I can stop the washer and restart and the noise
    will end.
    The noise sounds similar to the sound you get when you release air from
    a balloon (high pitched).
    Any ideas?
    thanks
    , Apr 23, 2005
  2. <> wrote in message
    > Hello.
    > will end.
    > Any ideas?
    Sounds like a magnetic solenoid valve. Washing machines have electronically
    controlled valves that use a magnet to open them. Sometimes they buzz.
    Doles it do it all the time or only on the hot/warm wash cycle? If it does
    it on the cold cycle only it is probably the one controlling the cold water.
    Check out www.repairclinic.com and you may find more information
    Ed
    http://pages.cthome.net/edhome/
    Edwin Pawlowski, Apr 23, 2005
  3. wrote:
    > Hello.
    when
    them.
    > will end.
    from
    > Any ideas?
    > thanks
    Model#?
    http://www.applianceaid.com/model.html
    Some model# helps.
    when
    Definetly have a listen to the area where the hot and cold hoses are
    attached to the washer, if the noise is in that area the fill valve is
    common for making a buzz/hummmm type of an noise.
    But, there could be other trouble area's....dispensor solenoids/etc
    depending on the model#/style.
    jeff.
    Appliance Repair Aid
    Appliance Repair Aid, Apr 23, 2005
  4. chuck Guest
    Jeff,
    Thank you for the advise.
    The Model number is KAWS677EQ0. The noise appears to be coming from
    where the cold hose attached to the machine. I have tighnened the hose
    to see if it was loose, but it did not appear to help. If I stop the
    cycle and restart, the buzzing will stop.
    Chuck
    chuck, Apr 23, 2005
  5. "chuck" <> wrote in message
    > Chuck
    Still goes back to the solenoid valve. Could be a weak magnet, could be a
    bad connection, could be a seal wearing out.
  6. chuck wrote:
    > Jeff,
    hose
    > Chuck
    I checked the parts breakdown, found no extra/other dispensor solenoids
    or such that might give us problems :D
    New fill valve time is likely.
    Fill valve for your model...
    http://www.pcappliancerepair.com/cg...cgi?affiliate_id=AppAid&item=285805&brand=WPL
    Access helps to get at the fill valve...
    http://www.applianceaid.com/procedures.html
    jeff.
  7. chuck Guest
    I replaced the fill valve and it fixed the problem.
    Thanks for everyone's help.
    Chuck
    chuck, Apr 30, 2005
    > Chuck
    Thankx for the update! :)
    jeff.
    Appliance Repair Aid, Apr 30, 2005
  1. James Onslow
    5,557
    N. Thornton
    May 6, 2004
  2. Ron
    568
    Codswallop
    Oct 8, 2006
  3. Bho
    404
    Red Neckerson
    Jan 11, 2006
  4. George R Ahearn
    Maytag Washing Machine noise
    George R Ahearn, May 28, 2006, in forum: Misc DIY
    345
    mutsuko ochi
    May 31, 2007
  5. Replies:
    1,026
    Tom The Great
    Nov 27, 2006
