Washing machine belt tension
Discussion in 'Misc DIY' started by Chris, Jun 29, 2005.
  1. Chris
    Chris Guest
    Just managed to source a replacement belt for my Hoover washing machine,
    and was wondering how tight it needs to be fitted?
    When fitted, how far should I be able to move the belt in and out at a
    point half way between the pulleys, or is it just a case of tight as
    possible?
    Cheers
    Chris
    Cut along the dotted line to reply
    Chris, Jun 29, 2005
  2. In article <42c26236$0$30814$>,
    Chris <-online.co.uk> writes:
    Rule of thumb for alternator belts it about half an inch.
    If you get any slip, tighten it up a bit more.
    > or is it just a case of tight as possible?
    No -- that will more rapidly wear the motor bearings.
    Andrew Gabriel
    Andrew Gabriel, Jun 29, 2005
  3. Chris
    fred Guest
    In article <42c300c6$0$41913$>,
    >Thanks Andrew - I didn't think 'tight as possible' was a good idea, but
    >wasn't sure what to aim for.
    I've never been any good at guessing the tension of V-belts - is that 10mm
    or is that 15? The tip I got was that you can judge the tension by the
    amount you can rotate the belt, IIRC if you can rotate it by about
    90degrees then it was about right. Only works for V-belts tho.
    fred
    fred, Jun 29, 2005
  1. Jim
    8
    892
    N. Thornton
    Jun 17, 2004
  2. Bingo
    386
    Peter
    Mar 12, 2005
  3. Piers Finlayson
    Washing Machine - belt going?
    Piers Finlayson, Sep 8, 2006, in forum: Misc DIY
    374
    Matty F
    Sep 9, 2006
  4. normanwisdom
    belt sander drive belt
    normanwisdom, Sep 14, 2006, in forum: UK DIY
    12
    957
    The3rd Earl Of Derby
    Sep 14, 2006
  5. Carl
    Washing machine not washing
    Carl, Mar 3, 2004, in forum: Misc DIY
    637
    spacekase
    Mar 6, 2004
