Washer fills, agitates but won't empty or spin
Discussion in 'UK DIY' started by JayLene, Oct 10, 2004.
  1. JayLene
    JayLene Guest
    I read through all the links but still can't isolate my problem. I
    have a Whirlpool Model LA 7680XK which I bought used a few years back.
    As a handywoman I have made many appliance repairs myself. Amazing
    how simple some fixes are is you know how to approach it.
    As I said in the subject line, the washer will fill and agitate but
    even when I move the timer through the cycles it will not empty or
    spin despite the fact that the motor is running.
    I lowered the drain hose close to the floor and the water immediately
    ran out. I then tried again to get the washer to spin by putting the
    timer near the spin cycle and waiting. It tick, tick, ticked (timer
    working ok?) but it continued to the stop position without spinning.
    My washer normally continues to agitate when the lid is up so I don't
    know if the problem has to do with the lid switch but it makes a
    clicking noise when depressed so I don't think that this is the
    problem.
    I noted that when I put the load in that the piece of wood that I had
    under one corner to balance it out had slipped out of place. No doubt
    my last load was seriously unbalanced. Thought I might note this
    since I suppose the jarring could also cause problems.
    I fear from reading posts that I will have to replace the pump but
    before going any further I wanted to make sure that there weren't any
    other options.
    Thanks in advance for any assistance. I sure love the fact that I can
    go online and get information.
    JayLene - handywoman by necessity
  2. JayLene
    Brian Reay Guest
    "JayLene" <> wrote in message
    I'd suspect a blocked (or partially blocked) drain system in the machine
    and/or a blockage in the level sensing system.
    The latter works by having a level sensor (2.5" dia. disk, a couple of
    wires, and a thin, usually clear pipe to the drain system). If there is a
    blockage, it thinks the machine is still full and prevents spinning etc.
    Sometimes leaving the machine allows the pressure to equalise and the
    program will continue.
    Chances are it is all gunged up with a grey paste - a mix of detergent,
    bodyfat, and muck. Yuk.
    Brian Reay
    www.g8osn.org.uk
    www.amateurradiotraining.org.uk
    FP#898
    Brian Reay, Oct 10, 2004
  1. tkarig
    Maytag washer won't spin
    tkarig, Mar 7, 2004, in forum: Home Repair
    285
  2. paul
    399
  3. paul
    504
  4. jehma
    13
    489
    zephyr
    Jan 3, 2006
  5. badaddidude
    washing machine won't empty or spin
    badaddidude, Jun 7, 2008, in forum: Misc DIY
    9
    914
    hr(bob)
    Jun 8, 2008
