washbasin waste seal leaking !
Discussion in 'UK DIY' started by Neil Catley, Nov 5, 2003.
  1. Neil Catley
    Neil Catley Guest
    All,
    Just fitted new washbasin in the bathroom. I have screwed in the waste
    fitting and connected up the waste pipes. All looks ok, until I turn the
    tap on.... it appears as though as soon as the over-flow chamber gets
    full (as the chrome plug /basin seal is obviously not water tight and
    water leaks into the overflow chamber surrounding the plug hole fitting
    even at low flow) the seal where the waste screws starts to leak. It
    appears as though the large rubber washer between the waste screw and
    nut isn't doing its job. HELP !!
    I have tried all variations on tightness of this screw fitting but with
    no luck. Any tips ?? What am I doing wrong ?!
  2. Neil Catley
    Lee Blaver Guest
    Neil Catley wrote:
    > All,
    Try using silicone (Fernox LS-X is good) or maybe plumbers mait.
    Some suggest ditching the washer entirely and just silicone it, I
    usually leave the washer and silicone both sides of it myself though,
    seems to work well enough.
    Remember to give the silicone time to set before putting water down the
    waste ;)
    Lee
    To reply use lee.blaver and ntlworld.com
    Lee Blaver, Nov 6, 2003
  3. Neil Catley
    BigWallop Guest
    "Neil Catley" <> wrote in message
    > All,
    Lift the whole waste outlet back out of the sink and smear some sealant
    around the underside of the grating section. Lay it back in the hole but
    don't squeeze it down.
    Take the rubber washer and look at both sides of it. One side should have
    ribs running around it and the other side should be smooth.
    Smear some sealant around the ribbed side and place it over the tail of the
    grating with the sealant on the upper side toward the basin.
    Put the nut on the tail and, holding the grating gently with one hand, start
    to tighten the nut on to the tail.
    When the washer touches the basin, press down gently on the grating and then
    line it up with the centre of the hole before tightening the whole thing up.
    Don't use any wrenches on the fitting at all, as these waste outlets are
    best just taken to hand tightness and no more. Then leave the whole lot for
    a couple of hours, until the surface of the sealant has skinned over, before
    running water through it.
    BigWallop, Nov 6, 2003
  4. Neil Catley
    Neil Catley Guest
    > news:...
    > > All,
    Thanks for the tips - I'll give it a shot tonight.
    Neil Catley, Nov 6, 2003
  5. Neil Catley
    robgraham Guest
    Isn't there a rubber washer that goes between the waste and the sink,
    i.e.above the sink?
    Rob Graham
    robgraham, Nov 6, 2003
  6. Neil Catley
    Neil Catley Guest
    > i.e.above the sink?
    > Rob Graham
    nope. and its not on the diagram so I haven't just lost it ! If you think
    about it, you dont need one as the chamber around waste beneath the grill
    is designed to fill with water when the sink overflow has to kick in.
  7. Neil Catley
    Roger Mills Guest
    > > i.e.above the sink?
    > > Rob Graham
    I don't accept that!
    If the flange of the waste fitting doesn't seal to the basin, what stops the
    water running out - by seeping round the flange into the chamber you
    mention - when the plug is in?
    Roger
    Roger Mills, Nov 6, 2003
  8. Neil Catley
    Neil Catley Guest
    > news:...
    > > > i.e.above the sink?
    > > > Rob Graham
    > Roger
    I dont know - but there isnt one !
  9. Neil Catley
    Mark S. Guest
    On Thu, 06 Nov 2003 18:07:39 +0000, Neil Catley <> wrote:
    >> news:...
    >> > > i.e.above the sink?
    >> > > Rob Graham
    >> Roger
    Had the same problem myself.
    Did the smear of silicone under the waste itself and then reassembled
    all the bits with ptfe tape on every thread whether it looked to need
    it or not and not leaked since. :)
    Mark S.
    Mark S., Nov 6, 2003
  10. Neil Catley
    robgraham Guest
    Well, the lack of provision of one doesn't stop the laws of physics. I can't
    see what's to stop water seeping around the waste if there is no seal above
    the sink and under the waste flange.
    Rob
    robgraham, Nov 7, 2003
  11. In article <>,
    Neil Catley <> writes:
    > All,
    I just did the same, and had the same problem.
    The rubber washer was profiled and not symmetrical, but no hint
    which way round it went. I took it apart and turned it the other
    way up, and that fixed it.
    In article <>,
    >> i.e.above the sink?
    >> Rob Graham
    Mine came with a foam washer for this purpose, which squashes
    to just about nothing when you fit it. Without that, the sink
    would slowly empty when the plug was in.
    Andrew Gabriel
    Andrew Gabriel, Nov 7, 2003
    #11
  12. Neil Catley
    Neil Catley Guest
    Andrew Gabriel wrote:
    > In article <>,
    > > All,
    > In article <>,
    > >> i.e.above the sink?
    > >> Rob Graham
    > Andrew Gabriel
    Always the simple things eh ?! I'll try this first before getting the silicon
    gun out. Thanks for the tip.
    Neil Catley, Nov 7, 2003
    #12
  1. Tony
    571
  2. Keith Dunbar
    Waste from bathroom washbasin
    Keith Dunbar, Aug 22, 2007, in forum: UK DIY
    398
    Pete C
    Aug 22, 2007
  3. blueman
    10
    592
    sealandshine
    Jul 31, 2006
  4. djay
    338
    Jennifer
    Aug 9, 2005
  5. johnny
    new Roper Rhodes washbasin leaking!
    johnny, Jan 26, 2004, in forum: UK Home Improvement
    547
    johnny
    Jan 27, 2004
