Wall & ceiling prep before applying texture (orange peel)
Discussion in 'Building Construction' started by Ernesto, Aug 20, 2004.
  1. Ernesto
    Ernesto Guest
    What preparation is necessary on the walls & ceilings before applying
    an orange peel texture?
    Walls: they currently have a painted knock-down texture. My contractor
    wants to spray an orange peel texture directly on it, but I'm
    concerned that it may not hide the old texture well. Will it work?
    Should I have him apply a skim coat of compound on the walls first? Is
    a primer needed before texturing?
    Ceiling: after removing the old popcorn texture from the ceiling, it's
    left with bare wallboards (unprimed, unpainted). Again, my contractor
    wants to spray the o.p. texture directly on it. Is a skim coat
    required before texturing? How about primer?
    Bullnose: my contractor bullnosed the wall corners, and his job left a
    lot of metal exposed. He wants to spray the o.p. texture on it
    directly. Will it stick? If not, what goes on the metal before
    spraying texture?
    Thanks!
    -Ernesto
  1. Ernesto
    282
    Ernesto
    Aug 20, 2004
  2. Liz
    Wall prep before painting
    Liz, Feb 25, 2005, in forum: Misc DIY
    8
    534
    xrongor
    Feb 26, 2005
  3. Carlos
    Matching orange peel texture
    Carlos, Apr 17, 2006, in forum: Home Repair
    359
    Chuck B.
    Apr 17, 2006
  4. RickC
    314
    RickC
    Jan 14, 2008
  5. Ted
    Orange Peel texture on the ceiling?
    Ted, Nov 23, 2003, in forum: Building Construction
    406
    Mach Twain
    Nov 24, 2003
