Vermiculite to fill in the back of a fireback ?
Discussion in 'UK DIY' started by Graeme, Mar 28, 2005.
  1. Graeme
    Graeme Guest
    Ok So I am refitting a Victorian fireplace and have read that the fireback
    should be backfilled with a vermiculite mix (Sand cement and Vermiculite).
    My Local Builders merchants don't stock Vermiculite but I have seen it in
    Garden centres , Is this the same stuff?
    Does it matter?
    Should I just fill up the gap with old rubble as one web page suggests ?
    Any advice
    Many thanks
    Graeme
    > yes
    >>Does it matter?
    > I think so.
    > you could. some people put some corrugated cardboard behind the fireback
    > with a view to it burning away and leaving enough expansion gap to prevent
    > the fireback cracking (hmmm, right) then backfill with rubble.
    > I filled the void behind my fireback with plain vermiculite scrounged from
    > discarded packing material at partners place of work. I made a slurry of
    > cement and vermiculite /only/ for the flaunching/sloped back thingy. when
    > used and it's covered in soot it looks ok, hasn't cracked, very inexpensive.
    My fireback cracked anyway, even though it was just propped against the
    back of the inglenook.
    > RT
    The Natural Philosopher, Mar 28, 2005
    > Does it matter?
    B&Q used to sell a high-volume ready mixed concrete mix that used
    vermiculite instead of the more usual mixed aggregate. Can't find it on
    the website (no surprise there then), but it was only a couple of year
    back when I bought a bag of the stuff.
    Cheers
    Clive
    Clive Summerfield, Mar 28, 2005
  4. Graeme
    Andy Wade Guest
    Don't add sand. Just use a 1:6 (by volume!) mix of OP cement and
    vermiculite with an absolute minimum of water - just enough to get a
    workable grey gooey mass. Well that's what I did when I put my Baxi
    Burnall in a few years ago and it's been fine. I didn't use any
    cardboard - the weak vermiculite mix will allow a bit of movement. The
    cardboard backing is advised if you use the option of a more solid sand,
    cement and rubble infill.
    Andy
    Andy Wade, Mar 28, 2005
  5. In article <>,
    "Graeme" <> writes:
    I bought a sack of it from Travis Perkins. Their computer said they
    had 3 sacks, but it took half the staff searching the yard for about
    15 minutes before they could find it. Their computer told them they
    hadn't sold any in the previous 12 months, and no one (including me)
    had any idea what a sack of it looked like.
    I used it as a layer of insulation under the sand and cement base
    for a fireplace (a sheet of expanded polystyrene seemed like a
    distincly bad idea;-)
    Andrew Gabriel
    Andrew Gabriel, Mar 28, 2005
  6. Graeme
    Alan Guest
    Vermiculite is commonly used to insulate chimney flue liners.
    Try your local chimney company.
    Alan, Mar 29, 2005
  7. Graeme
    Graeme Guest
    "Tony Bryer" <> wrote in message
    > In article <>, Alan
    > Sold as Micafil
    > Tony Bryer SDA UK 'Software to build on' http://www.sda.co.uk
    > Free SEDBUK boiler database browser http://www.sda.co.uk/qsedbuk.htm
    Thanks for all the advice.
    I have found Vermiculite,
    10 Litre bags in B&Q about 4.50.
    Then a web serch found various sites selling 100L bags about 17.00 +
    Delivery (Mostly used for growing things indoors under lights without the
    aid of soil. Some of the sites offered '100% Confidential service'), Also a
    discusion on the magicmushroomforum.
    Then a phone call to a local Chimney company who gave me a name of a local
    company that do a 100L bag for 8.80 + Vat, and they have a trade counter and
    I can collect.
    Result !!
    Graeme.
    Graeme, Mar 30, 2005
  1. Replies:
    13
    1,639
  2. Housemartin
    428
    Mary Fisher
    Jul 3, 2008
  3. Vermiculite Insulation
    , Mar 14, 2005, in forum: Home Repair
    8
    1,301
    Doug Kanter
    Mar 15, 2005
  4. Joe D.
    8
    852
    Joe D.
    Dec 19, 2005
  5. Jim K
    To fill or not to fill?
    Jim K, Aug 21, 2013, in forum: UK DIY
    268
    Jim K
    Aug 21, 2013
