Varnished Floor Brush Marks
Discussion in 'Misc DIY' started by Bob, Jul 18, 2003.
  1. Bob
    Bob Guest
    I've been trying to varnish our new bathroom floor (solid bamboo
    strip), but the brush marks are far to obvious for my liking.
    Is there a trick to getting a smoother finish? I'm using Dulux
    Diamond Tough Satin Floor Varnish with a soft 2" brush.
    Perhaps I should be sealing the floor with something else entirely?
    Also, should a varnished floor be wax polished afterwards?
    Bob
    Bob, Jul 18, 2003
  2. Bob
    andrewpreece Guest
    "Bob" <> wrote in message
    Are you talking about brush marks or start-of-brushing-marks?
    When I did my floor with acrylic varnish I had trouble with
    marks showing up where the brush first made contact during a
    brush-stroke. I think I was using too much varnish in the brush.
    I was using Wickes Super Tough Floor Varnish, but can't say
    I had any problems with mid-stroke brush-marks. Maybe your
    varnish neeeds a little thinners added?
    AFAIK there is no requirement for his, though I can't say it would
    do any harm. I hear wax floor finishes are easily damaged though.
    Andy.
    > Thanks
    > Bob
    andrewpreece, Jul 18, 2003
  3. Bob
    Andy Dingley Guest
    What's the solvent in that stuff ? In this heat you need to use a
    water-based varnish, or the stuff is like treacle as soon as it leaves
    the brush.
    I've had to re-formulate my shellac this week - I'm now using 50:50
    isopropanol and ethanol, rather than my usual plain ethanol.
    Andy Dingley, Jul 19, 2003
  4. Bob
    Scott Mills Guest
    I varnished a parquet floor a few months back and I'd say brush marks were
    reasonably minimal. I used a 6inch brush from Wickes for the job and made
    sure as I built the coats up (4 in total) that they were always in a
    different direction. I seem to remember washing with white sprits between
    coat, if not then definitly before the first coat.
    Scott
    Scott Mills, Jul 19, 2003
  5. Bob
    Capitol Guest
    Personally, I always use "Bourne Seal" . I don't know what it is, but it's
    as hard as hell when it dries and survives most disasters. I believe all
    schools use it on their wood block flooring. You can also use it as an
    indoor varnish on woodwork.
    Regards
    Capitol
    Bob wrote in message ...
    >Thanks
    >Bob
    Capitol, Jul 19, 2003
  6. Bob
    parish Guest
    Norm always seems to use foam brushes for varnish. Available in the UK
    from Axminster. Comments in this group about them suggest that they work
    well.
    http://www.axminster.co.uk/default.asp?type=i&submit=Search&searchwhat=foam brushes
    > Thanks
    > Bob
    parish, Jul 20, 2003
  7. Bob
    Max Bone Guest
    I'm assuming that this is a 'water-borne' satin varnish for floors, in
    which case as mentioned by an earlier poster, the temperatures we are
    experiencing at the moment will probably contribute to the patchy finish
    you are seeing.
    I'd also guess that the bamboo flooring which you are coating is quite
    varied in it's porosity, and thus some areas will suck the moisture
    straight out the coating quicker than other areas leading to different
    finishes and contributing to your problems.
    As this is a water-borne coating, you are best not to use a pure bristle
    brush. A Synthetic SRT filament brush will give better results as the
    filament won't absorb any water, unlike pure bristle which is hollow and
    absorbs water... swelling up to give a more scratchy finish. We're about
    to launch some excellent Synthetic SRT brushes this week which we've had
    on test for 4 months... and the feedback has been excellent.
    You could also try a foam brush, these are good with both solvent-borne
    and water-borne products and are a popular tried and tested applicator
    for varnishing projects where the surfaces you intend to coat are flat,
    and they certainly avoid brush marks.
    http://www.decoratingdirect.co.uk/viewprod/r/RODFBS3P/
    Between coats do denib the surfaces gently using a very fine grade wet
    and dry paper (used dry), and then tack rag gently to remove any dust,
    before applying the next coat. You should get a more acceptable finish
    on the application of further thin coats. Work quickly and try to keep
    your wet edges going, don't be tempted to brush over areas which have
    just been applied, get the material on and leave it alone... water-
    bornes don't like being played around with.
    Regards
    Max Bone Decorating Direct Ltd
    hundreds of products - secure online ordering - delivered to your door
    Max Bone, Jul 20, 2003
  8. Bob
    Bob Guest
    Max Bone <> wrote in message news:<QidWCVADKsG$>...
    > you are seeing.
    > Regards
    It probably was the high temperatures - the varnish was dry to the
    touch within an hour (the tin said 8 hours!).
    Luckily I've only done the bit where the bath is going (I've been
    doing this project with the cast iron bath still in the room - it's
    too big and heavy to put anywhere else!). I'll definitely give the
    foam brushes a try though.
    Cheers
    Bob
    Bob, Jul 21, 2003
  9. Bob
    Bob Guest
    "andrewpreece" <> wrote in message news:<3f1881ff@212.67.96.135>...
    > news:...
    Bit of both really - the marks were much more obvious than I'd
    expected. As others have pointed out, it may have been the high
    temperatures last week causing the varnish to dry to quickly. I have
    more to do this week - hopefully now it's a bit cooler it will work
    better
    Bob
    Bob, Jul 21, 2003
  10. Bob
    Stephen Hull Guest
    In message <>
    (ian) wrote:
    >Use a Paint pad, alot easier to apply and no brush strokes, tried the
    >brush got the same problem that you did.
    Yep, Some paint finishes cannot be satisfactorily applied without
    brush-marks showing no matter how good a brush or the skilled person
    attempting to applying it is.
    Especially water based products that are recoatable in just two hours.
    Steve.
    Vehicle Painting Pointers: http://www.stephen.hull.btinternet.co.uk
    Coach painting tips and techniques + Land Rover colour codes
    StrongARM Powered Risc PC 600, 80Mb + 2MbVram, RISC OS 4
    Using a British RISC Operating System 100% immune to any Windows virus.
    Stephen Hull, Jul 22, 2003
  1. James Salisbury
    Painting and brush marks
    James Salisbury, Apr 3, 2004, in forum: Misc DIY
    670
    N. Thornton
    Apr 4, 2004
  2. Jan Wysocki
    1,543
    TonyK
    Sep 14, 2004
  3. brush marks - how to avoid
    , Jul 29, 2005, in forum: Home Repair
    10
    550
    nospambob
    Jul 30, 2005
  4. Jack Manfred
    Problems with Brush Marks
    Jack Manfred, May 27, 2010, in forum: UK DIY
    430
    The Natural Philosopher
    May 31, 2010
  5. SS
    708
    Mr Pounder
    Aug 20, 2011
