Using vinyl floor adhesive with self-stick tiles
Discussion in 'Home Repair' started by Mikepier, Dec 21, 2010.
  1. Mikepier
    Mikepier Guest
    In the past I have put down regular vinyl tile (non self stick) with
    floor adhesive with no problem. Is there any harm in using it with
    self-stick vinyl tile? I wanted to put floor adhesive to prevent the
    self-stick tiles from popping up plus to give it some added strength
    to adhere to the floor.
  2. Mikepier
    Hell Toupee Guest
    That's what I did in 1983. The kitchen floor is still intact and in
    pretty darned good shape, considering its age.
    Hell Toupee, Dec 21, 2010
  3. Mikepier
    EXT Guest
    "Hell Toupee" <> wrote in message
    news:ieqnnn$d3o$...
    > That's what I did in 1983. The kitchen floor is still intact and in pretty
    Some tiles recommend using an adhesive that sets to a sticky surface, so it
    is like putting two pieces of duct tape together sticky side to sticky side.
    Then try to get it apart. My laundry room floor used this method, nothing
    has moved in 25 years.
    EXT, Dec 23, 2010
  4. Mikepier
    Evan Guest
    > news:ieqnnn$d3o$...
    Yeah... Amazing... It is called "contact cement" it is the same
    magical
    glue that is used to attach laminate surfaces to the substrate which
    is
    supporting it...
    ~~ Evan
    Evan, Dec 24, 2010
  1. Clive Long,UK
    Purchasing self-adhesive cork floor tiles
    Clive Long,UK, Nov 30, 2003, in forum: Misc DIY
    765
    Clive Long,UK
    Nov 30, 2003
  2. vinyl self stick tiles
    , Aug 31, 2006, in forum: Misc DIY
    368
    Ether Jones
    Sep 3, 2006
  3. Mike
    13
    874
  4. Clive
    2,623
  5. Jim K
    377
