UPVC patio door hinge adjustment
Discussion in 'Misc DIY' started by IJH, Feb 28, 2007.
  1. IJH
    IJH Guest
    i have a set of regular opening upvc patio doors atthe rear of my house
    and it appears that the hinges need some adjustment.
    Looking from the inside you can see the door isn't hanging level and
    there is a pronounced gap around the top adge where you can see daylight
    at the right angle.
    Looking at the hinges from the outside they appear to have a 4mm hex key
    adjusting screw of some sort, i've tried winding it in somewhat with a
    little sucess.
    Is there any method to this adjustment? and is there any further
    adjusting i can do with them?
    Tia.
    Ian.
    IJH, Feb 28, 2007
  2. IJH
    Guest
    On 28 Feb, 17:55, IJH <> wrote:
    > Hi,
    > at the right angle.
    > little sucess.
    > Tia.
    > Ian.
    If theyre like the last ones I did, the hinge covers pop off revealing
    all the adjustments inside.
    NT
    , Feb 28, 2007
  3. IJH
    Roger Mills Guest
    IJH <> wrote:
    > Hi,
    > house and it appears that the hinges need some adjustment.
    > daylight at the right angle.
    > key adjusting screw of some sort, i've tried winding it in somewhat
    > with a little sucess.
    > Tia.
    > Ian.
    I've got a door which has 2 adjusters on each hinge - requiring different
    sized Allen keys, just for good measure.
    One (at the top) appears to rotate the hinge pin in an eccentric fashion -
    so turning it moves the door both parallel to and perpendicular to the door
    opening. The other one (at the side) just moves the door towards or away
    from the frame (parallel to the opening).
    I found that I needed to set the top adjuster first, to move the door in and
    out to the correct position relative to the frame flange - without worrying
    about what it did in the other plane. And *then* use the other adjuster to
    get an even vertical gap between door and frame.
    Hope this makes some sort of sense, if your door is like mine - it's easier
    to do than to explain!
    Cheers,
    Roger
    ______
    Email address maintained for newsgroup use only, and not regularly
    monitored.. Messages sent to it may not be read for several weeks.
    PLEASE REPLY TO NEWSGROUP!
    Roger Mills, Feb 28, 2007
  4. IJH
    jack Guest
    On Wed, 28 Feb 2007 17:55:50 +0000, IJH
    <> wrote:
    >Hi,
    >at the right angle.
    >little sucess.
    >Tia.
    >Ian.
    check to see if the jambs are plumb and the head is level
    if the door is not square it wont fit properly in a square opening
    obviously
    if the door is out of square you may have to adjust the shims around
    the glass
    jake
    jack, Feb 28, 2007
  5. IJH
    DIY Guest
    "IJH" wrote:
    > Hi,
    > Looking from the inside you can see the door isn't hanging level and there
    > is a pronounced gap around the top adge where you can see daylight at the
    > right angle.
    > little sucess.
    > Is there any method to this adjustment? and is there any further adjusting
    > i can do with them?
    If it's not the hinges it might be that the frame is out of alignment and in
    need of toeing and heeling. See
    http://www.doubleglazing.com/diy_toeing_heeling.htm
    DIY, Feb 28, 2007
  1. Darren
    Upvc Door Adjustment
    Darren, Mar 9, 2006, in forum: Misc DIY
    2,388
    Darren
    Mar 9, 2006
  2. Peabody
    872
    Peabody
    May 13, 2006
  3. Joe J.
    453
    Noahbuddy
    Jul 28, 2008
  4. Cindy Hamilton
    left hinge door, right hinge storm
    Cindy Hamilton, Jun 17, 2010, in forum: Home Repair
    21
    1,328
    chaniarts
    Jun 18, 2010
  5. ruffy
    Hinge Adjustment of IKEA Cabinet Door
    ruffy, Feb 3, 2012, in forum: Home Repair
    1,394
    ruffy
    Feb 3, 2012
