Trimming Wooden Blinds
Discussion in 'UK DIY' started by Ed_Zep, Aug 19, 2007.
  1. Ed_Zep
    Ed_Zep Guest
    Can anyone recommend a way of getting a professional finish? I need to
    take 6.5cm of each side. Even taping them together and using a Bosch
    jigsaw doesn't look great.
    I don't mind paying a few quid extra by getting them done by someone
    else. I heard that B&Q do a blind cutting service, for instance.
    Thanks a lot. Ed.
  2. "Ed_Zep" <> wrote in message
    > Thanks a lot. Ed.
    Presuming you mean 'Venetian blinds' with wooden slats?
    I needed to this for eleven blinds!
    I firstly laid the blinds on a solid surface and banged the ends flush with
    a batten then clamped the slats together. The operation was a bit iterative,
    clamp- align- clamp- align until it was to my satisfaction.
    Then I scribed the 'line' with a set-square and a 'Stanley' knife; trimmed
    off the ends with a hand Japanese Pull-Saw; which I find easier to cut
    'straight' than a conventional hand saw.
    The old adage; Measure twice , cut once; works 'cos you can't add a bit
    back!
    Brian
    Brian Sharrock, Aug 19, 2007
  3. Ed_Zep
    Ed_Zep Guest
    > news:...
    > > Thanks a lot. Ed.
    > back!
    > Brian
    Thanks Brian.
  4. Ed_Zep
    Pete C Guest
    If you have a variable speed jigsaw try a decent fine tooth blade like
    a Bosch T101A0.
    cheers,
    Pete.
    Pete C, Aug 19, 2007
  5. Ed_Zep
    Ed_Zep Guest
    On Aug 19, 11:53 pm, Pete C <> wrote:
    > Hi,
    > a Bosch T101A0.
    > cheers,
    > Pete.
    Thanks Pete. I think I have got one of those. Will try that as well.
    Ed_Zep, Aug 20, 2007
  6. Ed_Zep
    Dave Gordon Guest
    "Brian Sharrock" <> wrote in message
    news:CyZxi.8120$...
    > news:...
    >> Thanks a lot. Ed.
    > I firstly laid the blinds on a solid surface and banged the ends flush with a batten then clamped
    > the slats together. The operation was a bit iterative, clamp- align- clamp- align until it was to my
    > satisfaction.
    > Then I scribed the 'line' with a set-square and a 'Stanley' knife; trimmed off the ends with a hand
    > Japanese Pull-Saw; which I find easier to cut 'straight' than a conventional hand saw.
    So lots of teeth and not much kerf, to minimise splintering.
    Dave Gordon, Sep 15, 2007
  1. A.
    980
    Sneezy
    Feb 17, 2004
  2. stockdam
    Wooden Floor Trimming
    stockdam, Nov 26, 2005, in forum: Misc DIY
    286
    stockdam
    Nov 27, 2005
  3. Replies:
    1,171
    John Rumm
    Dec 3, 2005
  4. Replies:
    612
  5. Paul Pollock
    Wooden curtain rings stick on wooden rail - what can I do?
    Paul Pollock, Oct 14, 2006, in forum: UK Home Improvement
    1,485
    Paul Pollock
    Oct 16, 2006
