Training a Virginia creeper
Discussion in 'UK DIY' started by Tim Downie, Jul 7, 2009.
  1. Tim Downie
    Tim Downie Guest
    Having sweated blood in removing a common ivy that was growing up the gable
    of our house, I'd now like to train a Virginia creeper up there instead.
    There's been a VC growing by the gable end for some time but it's never been
    able to get a good enough grip on the painted pebbledash to gain any height.
    What's the best thing to train it up? Trellis, plastic mesh, vine eyes &
    wire or something else?
  2. In message <>, John
    <> writes
    >"Tim Downie" <> wrote in message
    >news:...
    >> gable of our house, I'd now like to train a Virginia creeper up there
    >> instead.
    >> been able to get a good enough grip on the painted pebbledash to gain any
    >> height. What's the best thing to train it up? Trellis, plastic mesh, vine
    >> eyes & wire or something else?
    >We have a VC on our (brick) gable end, it has been there for approx 12
    >years. I don't actually 'train it' but I get my ladders out 2 or 3 times a
    >year and cut off all the new growth to leave a neat square about 15 feet
    >wide and 20 foot high. This action also encourages the VC to fill in all
    >the gaps in the square, so at present I have a very full covering and in the
    >autumn it is absolutely beautiful when it changes colour. It is a right
    >PITA picking up all the leaves when they drop off!!! The amount of grab
    >that the 'attachers' on ours have I am surprised yours cannot get a grip on
    >the pebbledash.
    There a plant called the false Virginia creeper which looks very like a
    Virginia creeper, but which needs something more than a surface to climb
    (it's a tendril climber).
    >I am in no way a gardener so this advice is worth the amount of money you
    >paid for it, but I pass a VC every day that the owners do not 'train' and it
    >is now covering the roof!
    >HTH
    >John
    Stewart Robert Hinsley
    Stewart Robert Hinsley, Jul 7, 2009
    Our house is engulfed inside several virginia creepers. We didn't so
    much buy a house as a plant ;-). It self clings to the stone walls and
    doesn't need any support or training. Like you I used to get the ladder
    out and trim it off high because it fouls the guttering. However, my
    policy now is just to use a pair of steps and cut it off every spring
    just above the ground floor windows. By the end of the year it is up to
    the guttering again! I don't know how old the plants are but they have
    trunks at the base two or three inches diameter. Looks lovely in Autumn
    as the leaves all turns red.
    David in Normandy.
    To e-mail you must include the password FROG on the
    subject line, or it will be automatically deleted
    by a filter and not reach my inbox.
    David in Normandy, Jul 7, 2009
  4. Tim Downie
    NT Guest
    On Jul 7, 3:55 pm, "Tim Downie" <>
    > What's the best thing to train it up?  Trellis, plastic mesh, vine eyes&
    For climbers generally, vine eyes are traditional. A wire hanging from
    the loft soffits also works and is less work to fit, but best attach
    to the loft joists rather than the soffit.
    Rampant climbers can be kept withn the bounds of sanity by just
    cutting through the main stems where wanted, and not pulling anything
    off.
    NT
    NT, Jul 7, 2009
  5. On Jul 7, 7:03 pm, David in Normandy <>
    > David in Normandy.
    I have a self adhesive one with little suckers! Vetchi something or
    other????
    Judith
    Judith in France, Jul 7, 2009
    > other????
    > Judith
    Mine has little suckers too where the tendrils attach to the wall. I
    don't know the variety though.
    David in Normandy.
  7. In article <>,
    says...
    If you have true Virginia creeper (parthenocissus quinquefolia) then it
    will require some help to stay up there as it becomes woody and heavy and
    will rip off the wall, a few wires and vine eyes should be enough. If
    however you have what is often called wrongly virginia creeper in the
    UK but is what the americans call Bostan Ivy (Parthenocissus
    tricuspidata) then it should stay up on its own. They are easy to tell
    apart and the clue is in the latin names quinquefolia = 5 leafleted
    leaves, tricuspidata 3 lobed leaves. other than that they do similar
    autumn colour
    Charlie Pridham, Gardening in Cornwall
    www.roselandhouse.co.uk
    Holders of national collections of Clematis viticella cultivars and
    Lapageria rosea
    Charlie Pridham, Jul 8, 2009
  8. Tim Downie
    Tim Downie Guest
    Charlie Pridham wrote:
    > In article <>,
    > says...
    >> the gable of our house, I'd now like to train a Virginia creeper up
    >> there instead.
    >> never been able to get a good enough grip on the painted pebbledash
    >> to gain any height. What's the best thing to train it up? Trellis,
    >> plastic mesh, vine eyes & wire or something else?
    > it will require some help to stay up there as it becomes woody and
    > heavy and will rip off the wall, a few wires and vine eyes should be
    > enough. If however you have what is often called wrongly virginia
    > creeper in the
    > autumn colour
    Hmm.. I think mine must be the quinquefolia. The wall has been newly
    cleaned & painted and I suppose there's no harm in waiting to see if it will
    get a grip on the new surface but if mine is the true VC then from what
    you've said, I will need wires.
    Thanks for the info.
    Tim
    Tim Downie, Jul 8, 2009
  9. In message <>, Charlie
    Pridham <> writes
    >In article <>,
    > says...
    >autumn colour
    From the failure to climb I suspect that he has Parthenocissus vitacea,
    which differs from Parthenocissus quinquefolia in lacking the adhesive
    disks.
    Stewart Robert Hinsley, Jul 8, 2009
  10. In article <>, {$news$}@meden.demon.co.uk
    says...
    > Pridham <> writes
    > >In article <>,
    > > says...
    > >autumn colour
    > disks.
    Does that have a synonym Stewart? its not a name I have every come
    across, although Parthenocissus quinquefolia falling off smooth walls I
    hear about all the time!
    Lapageria rosea
  11. In article <>,
    says...
    > "Charlie Pridham" <> wrote in message
    > news:...
    > > autumn colour
    > I have just been to look at my plant, it does indeed have three pointed
    > leaves. As I said in my original reply I am not a gardener. Somebody told
    > me years ago that it was a VC. The same person also told me it will not do
    > any harm to my brickwork, is this also incorrect? I can only describe the
    > 'attachers' as like very tiny hands with fat ended fingers.
    > Cheers
    > John
    You have by the sound of it Parthenocissus tricuspidata AKA Bostan Ivy,
    the tendrills have adesive pads on the ends, they only work once though
    so only new growth will attach, secure all the old growth so its weight
    in the wind will not dislodge the new stuff as it starts to attach, it
    wont take it long and it forms a good cover.
    It will not harm brick work, and so long as you prevent it getting under
    the roof is well behaved
    Lapageria rosea
    #11
  12. In message <>, Charlie
    Pridham <> writes
    >says...
    >> Pridham <> writes
    >> >In article <>,
    >> > says...
    >> >>the gable
    >> >>never been
    >> >>any height.
    >> >autumn colour
    >> disks.
    Parthenocissus vitacea syn inserta
    http://en.wikipedia.org/wiki/Parthenocissus_vitacea
    But we now know that he has P. tricuspidata.
    #12
  13. Tim Downie
    Tim Downie Guest
    > Pridham <> writes
    >> In article <>,
    >> says...
    >>> there instead. There's been a VC growing by the gable end for some time
    >>> but it's
    >> creeper in the UK but is what the americans call Bostan Ivy
    >> (Parthenocissus
    >> tell apart and the clue is in the latin names quinquefolia = 5
    >> leafleted leaves, tricuspidata 3 lobed leaves. other than that they
    >> do similar autumn colour
    > vitacea, which differs from Parthenocissus quinquefolia in lacking
    > the adhesive disks.
    No, it has the adhesive disks, they just didn't seem to either stick well or
    be able to bear the weight of the foliage.
    Tim
    #13
  14. In article <>, {$news$}@meden.demon.co.uk
    says...
    > Pridham <> writes
    > >says...
    > >> Pridham <> writes
    > >> >In article <>,
    > >> > says...
    > >> >>the gable
    > >> >>never been
    > >> >>any height.
    > >> >autumn colour
    > >> disks.
    True, but the other plant is more interesting cos I have never seen
    one!!!
    Lapageria rosea
    #14
  15. In message <>, Charlie
    Pridham <> writes
    >says...
    >> Pridham <> writes
    >> >says...
    >> >> Pridham <> writes
    >> >> >In article <>,
    >> >> > says...
    >> >> >>the gable
    >> >> >>instead.
    >> >> >>never been
    >> >> >>any height.
    >> >> >>eyes &
    >> >> >autumn colour
    >> >> disks.
    >one!!!
    There appear to be more records of false Virginia creeper from the wild
    in the UK than of Virginia creeper. There may be one half a mile away
    from me - but I haven't got an undoubted Virginia creeper to compare it
    with.
    #15
    > instead.
    Gripfill.
    Dave - The Medway Handyman
    www.medwayhandyman.co.uk
    The Medway Handyman, Jul 8, 2009
    #16
  17. Tim Downie
    Huge Guest
    On 2009-07-08, Charlie Pridham <> wrote:
    > In article <>,
    > says...
    > autumn colour
    Thank you! Now I know why when we bought 'another' VC, it looked different and
    climbed nothing like as well as what we thought was VC that we already
    had. Because what we already had is BI, not VC...
    http://hyperangry.blogspot.com/
    [email me, if you must, at huge {at} huge (dot) org <dot> uk]
    Huge, Jul 9, 2009
    #17
  1. -
    413
    Weatherlawyer
    Mar 4, 2006
  2. All From Wood
    Furniture Repair - Northern Virginia
    All From Wood, May 7, 2004, in forum: Home Repair
    549
    All From Wood
    May 7, 2004
  3. 1924fixer
    17
    527
    Joe Doe
    May 21, 2004
  4. boondoggle
    483
    Goedjn
    Apr 24, 2007
  5. Jabs
    10
    539
    hvacman
    Dec 18, 2003
