Toothbrush charger sockets?
Discussion in 'UK DIY' started by Andy Dingley, Sep 21, 2010.
  1. Andy Dingley
    Andy Dingley Guest
    How do I charge a toothbrush in the bathroom? It fits a shaver
    socket, and I'm allowed a shaver socket within the relevant zones, but
    all the shaver sockets I've seen (which admittedly isn't that many)
    have a tendency to hum when something is plugged into them.
    Does anyone make a silent socket?
  2. Andy Dingley
    Pete Zahut Guest
    Unless you intend to sleep in the bathroom it shouldn't be a problem. We
    have a toothbrush permanently plugged into the shaver socket in our ensuite
    bathroom and yes, it hums, but after about two minutes you become oblivious
    to it.
    Pete Zahut, Sep 21, 2010
  3. Andy Dingley
    Jeff Gaines Guest
    On 21/09/2010 in message
    <> Andy
    I had a hummer - I loosened the screws slightly and wiggled it about until
    it stopped humming, worked quite well.
    Jeff Gaines Dorset UK
    There is no reason anyone would want a computer in their home.
    (Ken Olson, president Digital Equipment, 1977)
    Jeff Gaines, Sep 21, 2010
  4. In article <>,
    "Pete Zahut" <> writes:
    > to it.
    Buy a good make? I haven't noticed a hum from MK ones I've fitted
    over the last decade.
    Fit a non-isolating one in the bedroom with the toothbrush
    permanently plugged in there, and then lift it off as you go
    into the bathroom, returning it afterwards.
    Another point about isolating ones when using chargers with them...
    They are allowed to output up to 270V off-load, and most chargers
    draw so little they are going to see nearly the off-load voltage.
    If the charger is a wide voltage range one, it's probably better
    for it to be running on the 120V socket.
    Andrew Gabriel
    [email address is not usable -- followup in the newsgroup]
    Andrew Gabriel, Sep 21, 2010
  5. Andy Dingley
    OG Guest
    "Andy Dingley" <> wrote in message
    Electric toothbrushes don't need charging more than once or twice a week, so
    we have a charger on the landing.
    OG, Sep 21, 2010
  6. Andy Dingley
    Part timer Guest
    On Sep 21, 12:37 pm, (Andrew Gabriel)
    I cut the shaver plug off my Braun and fitted a normal 3A fused plug,
    keep it outside the bathroom and put the toothbrush back on charge
    after use.
    Part timer, Sep 21, 2010
  7. Andy Dingley
    geoff Guest
    In message
    Andy Dingley <> writes
    Is it important ?
    The only time I sleep in the bathroom is when I'm pissed and fall asleep
    on the bog - in which case, I'm beyond caring
    geoff
    geoff, Sep 21, 2010
  8. Andy Dingley
    therustyone Guest
    > news:...
    > Electric toothbrushes don't need charging more than once or twice a week,so
    Battery life will be drastically shortened if it is continuously
    charged on a typical dumb charger.
    therustyone, Sep 22, 2010
  9. Mark BR wrote:
    >"Part timer" <> wrote in message
    >news:...
    >after use.
    >I wonder how many people do as I did? Put a 13amp socket sort of out of
    >reach in the bathroom.
    Simply plug a two-pin adaptor into the socket on the landing (1).
    Minimal expense, no electrical work.
    (1) Or wherever you find convenient.
    Chris
    Chris J Dixon Nottingham UK
    Have dancing shoes, will ceilidh.
    Chris J Dixon, Sep 22, 2010
  10. Andy Dingley
    Tim Streater Guest
    In article
    > > news:...
    You referring to the one supplied by the vendor? Mine is on charge 24x7
    (except when I'm using it, of course, or away).
    Mine doesn't hum, although I had to replace it when we moved into this
    house as the installed one only worked when the light was turned on - a
    dead loss. The new one doesn't hum either.
    And it would be an even bigger PITB if I had to carry the TB in and out
    of the bathroom every time I used it.
    Tim
    "That excessive bail ought not to be required, nor excessive fines imposed,
    nor cruel and unusual punishments inflicted" -- Bill of Rights 1689
    Tim Streater, Sep 22, 2010
  11. Andy Dingley
    Adrian Guest
    Tim Streater <> gurgled happily, sounding much
    like they were saying:
    We tend to leave ours in the bathroom, only putting it on the charger
    (outside the bathroom) when it needs charging - about once a week with
    two of us using it.
    Adrian, Sep 22, 2010
    #11
  12. Andy Dingley
    Tim Streater Guest
    In article <>,
    > two of us using it.
    OK - so whose job is that then? :)
    I happiest when I'm busy doing nothing, so I tend to optimise such
    things away.
    Tim
    #12
  13. Andy Dingley
    John Guest
    "geoff" <> wrote in message
    > In message
    > <>, Andy
    > Dingley <> writes
    > Is it important ?
    > geoff
    I got annoyed with Braun when they altered the hole in the toothbrush body
    so that it no longer fitted the wall mounted charger that they used to
    supply.
    John, Sep 22, 2010
    #13
  14. Andy Dingley
    John Guest
    "dennis@home" <-ass.net> wrote in message
    news:i7csf5$dbn$...
    > "John" <> wrote in message
    > news:fSkmo.851$2...
    >> body so that it no longer fitted the wall mounted charger that they used
    >> to supply.
    > That would be because the old one wouldn't work properly with the new one.
    > I bet you would have been just as annoyed when something broke if they
    > left it the same.
    Yes (if that was the case - but I guess it was cost reduction) - but I wish
    they had continued with a wall mountable one.
    John, Sep 22, 2010
    #14
    This is one of the things I /do/ like about Germany wiring regs as
    opposed to British. You are perfectly free to install a 16A socket
    (and a normal light switch) in a bathroom. (Although I was slightly
    surprised about the electric socket directly /under/ the tap in the
    wall where the washing machine screws in, in our shower-room).
    Note that British regs /do/ allow switches and sockets in the kitchen.
    Martin Bonner, Sep 22, 2010
    #15
  16. Andy Dingley
    therustyone Guest
    On 22 Sep, 10:02, Tim Streater <> wrote:
    > In article
    > > >news:....
    > Tim
    > nor cruel and unusual punishments inflicted"  --  Bill of Rights 1689- Hide quoted text -
    > - Show quoted text -
    Unscientific observation, based on my cordless phones, the batteries
    only seem to last a year on continuous charge when run warm. My Braun
    toothbrush battery is now getting a tad weaker after 8 years, and is
    charged only when flat.
    rusty
    #16
  17. Andy Dingley
    GAP Guest
    > news:i7csf5$dbn$...
    > >news:fSkmo.851$2...
    > >> to supply.
    > > left it the same.
    You can still get a wall mountable charger, although it's a big b****d
    with space for storing brushes. We bought a combination pack of wall
    mounted charger and two motors, which seems a bit dumb to me as you
    don't have anywhere to put the one that's not on charge, it was a good
    deal though. I haven't yet found a small wall mountable one like we
    had with the old style Braun brushes, the website listing the various
    models is less than clear...
    As a previous poster noted, I'm presuming that the new motors have a
    different type of battery and hence the charger is different and hence
    it's sensible that the old brushes won't go on the new charger and
    vice versa. What really annoys me is that there are actually at least
    two *different* types of "new" chatger, and if you buy the wrong brush
    it still won't fit/work with the other type!
    Graham
    GAP, Sep 22, 2010
    #17
  18. Andy Dingley
    OG Guest
    "Frank Erskine" <> wrote in message
    > On Wed, 22 Sep 2010 14:51:36 -0700 (PDT), therustyone
    > That's my experience too. My toothbrush is also several years old, and
    > lasts two or three weeks (at least) on a charge.
    > The charger generally lives either downstairs on the kitchen table or
    > on the landing outside the bathroom.
    > Out of interest, is it possible to replace the battery? Indeed, what
    > sort of battery is used in 'em? My Braun 3D "pulsating toothbrush" is
    > marked "NH Accu" on the back.
    Tabbed C cells were in our -1 Braun toothbrush. Couldn't tell you what
    chemistry though.
    OG, Sep 22, 2010
    #18
  19. Andy Dingley
    OG Guest
    news:i7e14q$uim$...
    > news:...
    > The base has a slot to allow it to be removed but its to recycle the
    > battery.
    > It breaks the coil which is also in the base.
    Can only comment on my -1th Braun that needed a little TLC and a bit more
    DIY after a tumble into the bathtub.
    Opening the base gave access to the cells and the circuit board. Solder
    fixed the damage to the latter and it re-charged fine for a coouple more
    years.
    A replacement was bought only when the cost of the replacement + 4 heads was
    not much more than the cost of 4 heads by themselves.
    OG, Sep 23, 2010
    #19
  20. Andy Dingley
    John Guest
    "Andy Burns" <> wrote in message
    > Mine has a large slot in the base where you can insert and twist e.g a 10p
    > coin to remove the battery for re-cycling ... it DOES warn that making use
    > of this slot apparently cracks the whole toothbrush case into two
    > rendering it useless.
    Push the spindle in as you twist the base - it releases a bayonet.
    John, Sep 23, 2010
    #20
  1. Mark
    Ultrasonex toothbrush
    Mark, Dec 27, 2003, in forum: UK DIY
    17
    1,281
    Chris J Dixon
    Dec 31, 2003
  2. Dave
    2,284
    Chris J Dixon
    Jul 21, 2004
  3. Pete C
    1,888
    Pete C
    Jan 21, 2005
  4. TWEEZER
    electric toothbrush
    TWEEZER, Dec 24, 2007, in forum: Misc DIY
    9
    673
  5. Moonraker
    Oral-B Toothbrush charger problem
    Moonraker, Jul 31, 2012, in forum: UK DIY
    623
