timber house extension
Discussion in 'UK DIY' started by Telfmann, Sep 14, 2004.
  1. Telfmann
    Telfmann Guest
    I am hoping to one day build a small bedroom at the rear of our
    house. And was wondering if anyone else has built or is considering a
    extension made out of timber. My house is of conventional
    construction, bricks walls, tiles on the roof ect, and i would like to
    build a one storey extension aprrox 8 x 12', just enough to fit a
    single bed at the far end. I have read about walter segal buildings
    and this seems like a cost effective method, using 4x4 posts, and stud
    walls sheathed in 3/4" plywood. If anyone has any ideas about how to
    add a extra room to there house then please respond to this post.
    Information on structual insulated panels (i.e. can i just buy them
    off the shelf), flat roofing (using a rubber membrane), or foundations
    (would concrete pads be better than a sill plate) would be most
    appreciated.
    > appreciated.
    I have seen this done round here extesnively - and teh usual method is
    to build brick /block up to about a foot above damp coure, and do the
    stud/timber frame above that.
    The exterir ply can be carried over down to damp lebvel; and drip beaded
    there.
    Internally unless you use massive wall thickness, there will be a ledge
    below teh sill plate, but hey, its all 'feature'
    You could take the timber down to damp level, but I would be nervous of
    that.
    In my house we used 7" thick walls and filled em with rockwool. 4" for
    internal walls only.
    Breathable membrane over the ply, battens running vertically and metal
    lath rendered over, on top. Airgap between render/lath and ply.
    To tie into existing brickwork is just a question of strapping or even
    screwing to it., Damp proof between studs and existing brick probably a
    good idea.
    Don't like flat rooves meself. Make sure the flashing where it butts
    existing wall is done properly - lead keyed into courses, and laid over
    roofing membrane which should run up wall behind lead etc.
    I am not an architect. Suggest you consult one.
    The Natural Philosopher, Sep 14, 2004
  3. Telfmann
    John Rumm Guest
    > appreciated.
    No reason why you can't build out of studwork. You can meet the required
    insulation values stipulated in the building regs with thinner walls as
    well.
    You would need foundations just as you would for a blockwork extension.
    The main structure would typically be built with 4x2" on 400mm centres.
    Probably 6x2" for roof timbers (assuming a flat roof). Insulation would
    be with urethane or polyisocyanurate (PIR) foam which is readilly
    available from a variety of sources (common brands include Celotex,
    Kingspan, Ecotherm, Rubberoid etc).
    The outside walls could be 1/2" or 3/4" ply. You could render over the
    top of that.
    Cheers,
    John.
    | Internode Ltd - http://www.internode.co.uk |
    | John Rumm - john(at)internode(dot)co(dot)uk |
    John Rumm, Sep 14, 2004
  4. Telfmann
    IMM Guest
    "Telfmann" <> wrote in message
    > appreciated.
    Get the book "Out of the Woods" about the Segal method. Very good, and
    gives the technique in detail. The problem is that you will need a
    structural engineer to do the timber frame calcs for you. Some may do it on
    the side as it is only a small extension. Insulate the floor and walls very
    well. Seal up with silicon.
    SIP panels:
    Look at this book:
    Building with Strucutural Insulated Panels (SIPs): Strength and Energy
    Efficiency Through Structural Panel Construction
    By Michael Morley
    ISBN: 1561583510
    Synopsis
    Structural insulated panels are sandwiches of foam insulation between two
    sheets of fibreboard or plywood, and are used to build walls, roofs and
    floors in all kinds of modern buildings: instead of three components - a
    frame, insulation and sheathing - SIP panels are all three things and come
    ready to install. SIP- constructed buildings are vastly more efficient,
    quicker to build, stronger, quieter and more draught-free than older
    post-war building systems. Taps into a huge and growing self-build market
    which is generally only served by technical books.; Tips and information on
    this highly efficient building material from an expert builder who
    specialises in structural insulated panel construction. Packed with 180
    colour photographs and 40 drawings.; Takes the reader through the entire
    process of building a panel-constructed house, from planning and estimating,
    ordering, storage and handling to construction.
    Some SIP companies:
    http://www.bpac.co.uk
    http://www.sipltd.com
    http://www.vencel.co.uk
    http://www.tekhaus.kingspan.com
    http://www.opstalan.nl
    http://www.redex.nl
    http://www.isobouw.nl
    Look at "I" beams:
    http://www.masonite-beams.se
    When you have absorbed much of this come back with more questions. This
    will do for now.
    IMM, Sep 15, 2004
  5. Telfmann
    IMM Guest
    "John Rumm" <> wrote in message
    news:4147775d$0$62131$...
    > > appreciated.
    > well.
    No you would not. The Segal method is post and beam with minimal
    foundations. The foundations consist of a 1 metre squ. hole by 1 metre deep
    filled with concrete with a paving slab on top. The post rests on this. Six
    of these is good enough for his extension.
    > top of that.
    See the book Out of The Woods which gives all the choices for Segal.
    http://www.segalselfbuild.co.uk/
    IMM, Sep 15, 2004
  6. Telfmann
    John Rumm Guest
    Erm, what exactly are you dissagreeing with? So these these segal blocks
    are not foundations then? Weather you have blocks as you describe, or
    strip/beam fill, you still need foundations!
    Something similar in design to those used on the rest of the property
    might be a good idea as well, if the new structure is to be fixed to the
    existing (the importance will depend on the local soil composition).
    Cheers,
    John.
    John Rumm, Sep 15, 2004
  7. Telfmann
    IMM Guest
    news:41478f29$0$62750$...
    A block work extension needs strip foundations. Find out how Segal do it.
    You don't say... Six small holes in the ground is very different to strip
    foundations, although strip foundations are a part of the Segal method, in
    its rawest and most basic form Segal has minimal foundations, that any DIYer
    can do, and the rest is none wet trades work making it easy for a good DIYer
    with common sense and power tools to tackle. Complete novices have built
    Segal homes, that is it's attraction. Some very attractive wooden framed
    Segal homes have been built. they are not all low cost homes for low income
    people.
    Where there is poor soil composition Segal scores. The odd deep hole here
    and there to support a post. is all you need. You can hire a drilling
    machine to drill quite deep onto a hard surface beneath the soil. Segal
    homes are mainly off the ground with any form of cladding you want to blend
    in with anything.
    The only negative aspect of the basic Segal method is elimination of cold
    bridging. Although this can be done at extra expense.
    IMM, Sep 15, 2004
    > people.
    However the cost is similar. Been through the calcs as to whether to use
    piled or strip foundations. Bugger all difference, but the trades to do
    strip are easier to find, and teh BCO doesn't purse his lips so much.
    Whatever the final answer, having timber work that can be splashed by
    rain is a Bad Idea.
    > in with anything.
    It doesn't actually. To the simple minded it looks cheaper, because its
    just less concrete, but the actual process of making the holes is far
    more complex than a JCB digging a trench.
    The Natural Philosopher, Sep 15, 2004
  9. Telfmann
    IMM Guest
    "The Natural Philosopher" <> wrote in message
    news:ci9973$ql4$1$...
    it.
    strip
    in
    DIYer
    DIYer
    built
    framed
    income
    > > people.
    If the soil is poor, piled is the only sensible answer.
    See the Segal site. Any problems with BCOs and they will intervene.
    > rain is a Bad Idea.
    You have large roof overhangs to reduce/eliminate rain on the building
    sides, or have jettied upper floors too. Theses were designed specifically
    to keep rain from the sides of wooden buildings many 100s of years ago.
    They look neat too. Having rain off the walls prevents the house from
    cooling. It also keeps the sun off in summer too.
    here
    blend
    > > in with anything.
    If the soil is fine, digging by hand, six 1m x 1m holes is not a big thing
    at all.
    cold
    IMM, Sep 15, 2004
  10. Telfmann
    John Rumm Guest
    You miss my point I believe... All I was saying to the OP is that you
    will need foundations of some sort. Just in case he was thinking along
    the lines that using studwork to build the extension was going to free
    him from that requirement. I was not suggesting that Segal or any other
    method was good or bad - each have pros and cons.
    Cheers,
    John.
  11. Telfmann
    Telfmann Guest
    Thanks to everyone who has viewed this post, and especially to the ppl
    who have responded.
    Out of the woods is a great little book, and packed full of
    information and useful ideas, but after weeks looking at the same 2D
    picture of a wall made with 4x4 posts and searching on the internet, i
    decided to buy some american books, which showed practical ways of
    doing things.
    'Timber framing for the rest of us' details exactly how to connect a
    sill plate to a foundation.
    'Practical pole building construction' shows how horizontal timber
    (girders) would attach to posts and allow sheathing to be fastened.
    Its true that most segal buildings you hear about are built on
    foundation pads, but in 'out of the woods' it also describes ataching
    a sill plate to a slab foundation (as mentioned in a post above). I do
    think however that the timber would be better off the ground by a few
    inches, as this would reduce the rain and mud splashing onto it.
    Although self build does not mean 'on the cheap', i hope there is a
    still a place for low income housing for low income families. As not
    everyone can afford or would want to live in a goldfish bowl in the
    middle of a forrest.
    And to increase my chance of getting planning permission, and building
    a sound structure, a architect would likley be needed.
    Of course the idea of just building a shed (a shed you could call
    home) and using that as a play room has also occured to me.
    Telfmann, Sep 15, 2004
    #11
  12. Telfmann
    Telfmann Guest
    "IMM" <> wrote in message news:<>...
    > news:...
    > > appreciated.
    > SIP panels:
    > Look at this book:
    > By Michael Morley
    > ISBN: 1561583510
    > Synopsis
    > Some SIP companies:
    > http://www.redex.nl
    > Look at "I" beams:
    > will do for now.
    Its alot to take it, im working my way through your websites. I agree
    insulating the floor is very important, expecially if it off the
    ground with wind whistling underneath. Role on the day when you can
    buy SIP's from Wickes.
    #12
  13. Telfmann
    IMM Guest
    > who have responded.
    > doing things.
    I have seen a few Segal houses and theyn look good. They look eco.
    > As not
    For a single floor extension? They just want simple drawings and stress
    calcs.
    God ones cost 12K, best build Segal.
    IMM, Sep 16, 2004
    #13
  14. Telfmann
    IMM Guest
    news:<>...
    > > news:...
    > > > appreciated.
    on
    very
    > > SIP panels:
    > > Look at this book:
    > > By Michael Morley
    > > ISBN: 1561583510
    > > Synopsis
    two
    come
    market
    on
    estimating,
    > > Some SIP companies:
    > > http://www.redex.nl
    > > Look at "I" beams:
    > > will do for now.
    In the US you can. They have catalogues of various sizes of panels with
    doors windows already cut in. Just pick and fix and a weatherproof shell up
    in days. AS most of their houses are bungalows and you don't need scaffold
    around the house (exspensive) a couple of men can put the SIPs up in a few
    days, even the roof. SIPs is the way forward without doubt. Total
    elimination of thermal bridging.
    IMM, Sep 16, 2004
    #14
  15. Telfmann
    IMM Guest
    > who have responded.
    > doing things.
    Do these books go into TJI "I" beams?
    IMM, Sep 16, 2004
    #15
    No, just bookcases, John, just bookcases...
    The Natural Philosopher, Sep 16, 2004
    #16
  17. Telfmann
    IMM Guest
    news:cibijj$ln$1$...
    A mentalist enters.....
    Sad isn't it.
    IMM, Sep 16, 2004
    #17
  18. Telfmann
    Telfmann Guest
    The Natural Philosopher <> wrote in message news:<cibijj$ln$1$>...
    they also go into I-beams, as there is a handy shelf provided in the
    middle of them, along the lines of the handy pop out beverage holder
    that comes with a pc.
    Unfortuanalty they don't discuss I-beams within the book, 'practcal
    pole construction' is from the 80's, but does have great info on
    loading poles, how to increaase loading on a post from 3 tons to 16
    tons, by using spiked connectors instead on nail (nails, lol) or bolts
    (6 tons). Although the book deals with telephone poles ect stuck into
    the ground, alot of the other info is relevant for hanging walls off
    posts.
    'Timber framing for the rest of us' is a 2004 book but is mainly about
    connecting large dimensional lumber (8"x8") with joist hangers and
    toe-screwing, to sill plates and posts on a dpc. Such large timbers
    are used because the aurthor likes turf roofs, but he also mentions
    'out of the woods'. I-beams would be a great alternative to using
    large timber in this situation, but does not mention it in this book,
    however there are very detailed step by step guides and span charts.
    Telfmann, Sep 17, 2004
    #18
  19. Telfmann
    IMM Guest
    > posts.
    There must a book out there that covers TJI "I" beams and normal cut timber.
    TJI's are now even common in the UK. Five years ago people scorned these as
    ticky tacky. Now they are mainstream. The Brits are slow learners.
    Maybe the TJI makers can recommend a book.
    IMM, Sep 17, 2004
    #19
  20. Telfmann
    Telfmann Guest
    > news:...
    > > posts.
    Its true that the british never seem to take up a good idea quickly,
    the bluestreak rocket, tilting trains, the digital computer (or
    mechanical for that matter), but alot of american households don't
    have a electic kettle, how do they manage.
    #20
  1. Mike Mitchell
    673
    Mike Mitchell
    Dec 27, 2003
  2. Tom
    1,165
    tarquinlinbin
    Jun 26, 2004
  3. Replies:
    413
    Dave Plowman (News)
    Oct 22, 2005
  4. Replies:
    28
    2,305
    Stuart Noble
    Oct 12, 2007
  5. Painters10
    Timber frame extension bricks and roof
    Painters10, Jul 21, 2009, in forum: Misc DIY
    764
    Painters10
    Jul 21, 2009
