Tiling Narrow Hallway
Discussion in 'Misc DIY' started by Greg Esres, Mar 11, 2007.
  1. Greg Esres
    Greg Esres Guest
    Hallway is 41 inches across. Using 12" tiles leaves very narrow tiles
    on each side, which everyone agrees looks bad. Using 6" tiles *might*
    enable me to use full tiles all the way across, but the consensus
    seems to be that the smaller tiles create a "busy" look.
    Anyone have ideas on how to make the 12" tiles look better?
  2. Greg Esres
    DanG Guest
    Use the 12" tiles. Run a joint at center. A full and about an 8
    1/2 border.
    Run the tile on the 45, place diamond at center. Diagonal will be
    17, 12" border.
    ______________________________
    Keep the whole world singing . . . .
    DanG (remove the sevens)
    "Greg Esres" <> wrote in message
    > tiles
    > *might*
    > consensus
    > Thanks
    DanG, Mar 11, 2007
  3. "Greg Esres" <> wrote in message
    > Thanks
    Put the tiles point to point instead of flat end to flat end? I guess this
    would be called a diagonal pattern.
    John Grabowski, Mar 12, 2007
  4. Greg Esres
    Colbyt Guest
    "John Grabowski" <> wrote in message
    news:OB0Jh.537$...
    > news:...
    >> Thanks
    > this
    This will use about 20% more material but will make the hall look wider.
    The center line grout joint is also a acceptable option.
    Colbyt, Mar 12, 2007
  5. Greg Esres
    Greg Esres Guest
    <<Use the 12" tiles. Run a joint at center. A full and about an 8
    1/2 border.>>
    <head slap> I had considered that layout at the very first, but
    rejected it to try to use full tiles. For some reason, I never looked
    at that option again after the unacceptability of the thin tiles was
    apparent.
    That is the easiest solution.
    <<Run the tile on the 45, place diamond at center. Diagonal will be
    17, 12" border.>>
    You mean like so:
    http://www.boundvortex.com/images/tiles.png
    Thank you.
    Greg Esres, Mar 12, 2007
  6. Greg Esres
    Greg Esres Guest
    <<Put the tiles point to point instead of flat end to flat end? I
    guess this
    would be called a diagonal pattern. >>
    That would be a more intriguing pattern, but it looks more difficult
    to layout. I'll have to think about whether I want to attempt that on
    my first go-round.
    Thanks!
  7. Greg Esres
    charlie Guest
    > Thanks
    http://www.floorstransformed.com/patterns.html
    brickwork or hopscotch patterns?
    charlie, Mar 12, 2007
  8. Greg Esres
    Greg Esres Guest
    <<http://www.floorstransformed.com/patterns.html
    brickwork or hopscotch patterns?>>
    Great web page, thanks!
    I saw an example of the brickwork pattern today at a restaurant. I
    also noticed how they did the hallway to the restroom. Since it
    alternates, every other course had the thin tile problem near the
    wall. Perhaps with it alternating between thick, thin along the wall,
    it would look better than thin all the way down.
    The hopscotch looks challenging to implement. Some good ideas
    there, though. Thank you.
  1. Denise Anne Richards
    Extending a hallway, problems, problems...
    Denise Anne Richards, Oct 15, 2004, in forum: UK DIY
    1,222
    Oct 17, 2004
  2. Mortimer
    Laying Laminate flooring in hallway
    Mortimer, Feb 2, 2005, in forum: Misc DIY
    13
    1,411
    Set Square
    Feb 3, 2005
  3. Roger R
    655
    Steve Walker
    Apr 29, 2005
  4. Replies:
    385
    Andrew Gabriel
    Nov 11, 2005
  5. Staffbull
    Laminate in hallway
    Staffbull, Feb 9, 2007, in forum: UK DIY
    521
    Staffbull
    Feb 10, 2007
