Telling the difference
Discussion in 'UK DIY' started by David White, Dec 11, 2004.
  1. David White
    David White Guest
    How do you tell the difference between an oil-stone and a wet-stone?
    David.
    Unless this is a riddle that's gone over my head, the obvious answer is
    "You don't, since the latter's a "whet" stone, and you use oil on it".
    (Or so I was led to believe.)
    Cheers,
    Harvey
    Harvey Van Sickle, Dec 11, 2004
  3. Set Square
    Set Square Guest
    > David.
    This may not be a cast iron definition, but . . .
    An oil stone is usually brick-shaped and grey in colour - and you sharpen
    chisels and plane blades on it, lubricated by oil.
    A wet stone is lighter in colour, and often circular - and rotates in a
    trough of water as you turn a handle. It's used for sharpening knives. The
    butcher in the village where I was brought up used to use one.
    Cheers,
    Set Square
    ______
    Please reply to newsgroup. Reply address is invalid.
    Set Square, Dec 11, 2004
  4. Rob Morley
    Rob Morley Guest
    In article <Xns95BCE7663EBC2whhvans@194.168.222.121>, "Harvey Van
    Sickle" says...
    I suspect whetstone is a general term, covering any bit of stone-like
    stuff used for sharpening blades, so could be applied to one using
    water, oil or nothing at all as a lubricant/coolant.
    Rob Morley, Dec 12, 2004
  5. David White
    David White Guest
    "raden" <> wrote in message
    > In message <cpfssp$m5d$>, David White
    > <> writes
    > >David.
    > To whet - to sharpen by rubbing or to make more acute
    > That's English, that is ...
    > geoff
    Thanks for the English lesson, Goeff!
    David
    David White, Dec 13, 2004
  1. Charlie
    12
    721
    Charlie
    Apr 17, 2005
  2. Arcury
    What is duct telling?
    Arcury, Jun 23, 2003, in forum: Home Repair
    322
    CBHvac
    Jun 23, 2003
  3. Eigenvector
    27
    504
    Tater
    Oct 9, 2006
  4. What they're not telling us
    , May 25, 2011, in forum: Home Repair
    10
    321
  5. MM
    86
    664
Share This Page
