Tarnish resistant door hardware
Discussion in 'Misc DIY' started by PM, Oct 31, 2005.
  1. PM
    PM Guest
    Replacing exterior doors and would like your opinions on the best (or
    better) manufacturers of hardware that won't tarnish so fast. Has much
    changed over the past decade?
    Thanks,
    Phil
    PM, Oct 31, 2005
  2. Improver?
    Improver? Guest
    I know this, I bought a Kwickset lockset for a new front door, in
    polished brass, with the elongated handle, "trigger" style latch and a
    matching deadbolt. It came with a one-year warranty. Within 6 months
    (there's no storm door) the brass looked like pot metal.
    Whatever you decide on, make the purchase on a separate receipt, and
    save it along with the packing material, instructions, warranty and
    box.
    It seems even well-known, class-A hardware like Baldwin and Shlege get
    a bad lot every now and then.
    Improver?, Nov 1, 2005
  3. dadiOH
    dadiOH Guest
    > much changed over the past decade?
    Some manufacturers offer a "lifetime" guarantee against brass
    tarnishing. How they achive that I have no idea since there has to be a
    coating to prevent tarnishing and coatings wear away.
    There is always nickel...
    dadiOH
    ____________________________
    dadiOH's dandies v3.06...
    ....a help file of info about MP3s, recording from
    LP/cassette and tips & tricks on this and that.
    Get it at http://mysite.verizon.net/xico
    dadiOH, Nov 1, 2005
  4. "PM" <> wrote in message
    > Thanks,
    > Phil
    I'm no metallurgist but it seems to me that brass, copper etc... will
    tarnish. I suppose there might be stuff that looks like brass, etc...that
    might not tarnish. The easiest way to keep stuff from tarnishing is to
    coat it with lacquer. That's pretty much what most hardware mfg's do as
    far as I know.
    I actually purposely tarnished some brass hinges for a hutch that I made and
    then coated them with spray on lacquer. They haven't lost their tarnish
    and it hasn't gotten worse either.
    Cheers,
    cc
    James \Cubby\ Culbertson, Nov 1, 2005
  5. m Ransley
    m Ransley Guest
    There is a new process used by some that bonds the finish at the
    molecular level and those companies offer a lifetime warranty, usually
    you get a 1 year or lifetime, the 1 year process is going to fail fast.
    m Ransley, Nov 1, 2005
  6. PM
    PM Guest
    Thanks to all for the prompt replies. I'll check carefully before
    purchase. Again, I appreciate your help.
    Phil
    PM, Nov 3, 2005
  1. David Longley
    1,524
    Andrew Barnes
    Nov 28, 2003
  2. Vince
    384
    Vince
    Jul 15, 2005
  3. Morgan
    1,119
    Goedjn
    May 1, 2006
  4. Some One
    Using used door for pocket door? Hardware?
    Some One, Jul 25, 2003, in forum: Building Construction
    248
    Some One
    Jul 25, 2003
  5. Maxwell
    How to tarnish a shinny tin building
    Maxwell, Nov 7, 2007, in forum: Building Construction
    699
    Maxwell
    Nov 13, 2007
Share This Page
