storm doors; pella vs. larson?
Discussion in 'Misc DIY' started by z, Jul 21, 2007.
  1. z
    z Guest
    OK, in this corner, going for $190: Larson Oxford storm door; wood
    core, "dura tech" surface, brass expander (i.e. sweep, I assume),
    "heavy duty" weatherstripping; also retractable screen and lock, but I
    don't care about those.
    And in the other corner, going for $196: Pella Olympia storm door, "1
    inch thick solid core", concealed screws, "heavy duty" hinges, brass
    sweep, 2 closers, "lifetime storm door protection plan", and or course
    retractable screen and lock with lifetime finish guarantee.
    So, which one would you buy?
    If it makes a difference, I'm gonna make a stab at installing it
    myself, since how hard can it be? I've posted the story of the last
    time when I had the Sears crew install a storm door, and they sawed up
    pieces of the door molding to shim out the oart of the latch that is
    on the frame, to make up for the fact that they installed the handle
    about an inch inboard of where it should go on the door, so I figure I
    can do that well myself. So with sadness I note that the Pella is not
    one of theirs with "express install" that "cuts installation time in
    half".
    z, Jul 21, 2007
  2. z
    Joe Guest
    > half".
    Both are quality doors, but I can only comment on Larson based on
    experience. Over the years I have installed, made minor repairs and
    fixed screens on many Larson doors. Even now, I have another one
    waiting installation. Getting them installed and functional is a
    breeze. Definitely within the competence scope of any DIYer, just read
    the directions slowly and carefully before you start.
    If you like the looks of the Pella better, buy it. Installations
    likely aren't all that different. FWIW, I have used Pella windows
    before (and probably will again) as their quality is top notch and
    their doors are probably on a par with Larson. Good luck.
    Joe
    Joe, Jul 21, 2007
  3. "z" <> wrote in message
    The one that looked the best to me.
    > half".
    I've probably hung over 100 doors. Some are easier than others, but if you
    read the instructions, use care in measuring, you can do it. Take your
    time, especially before cutting anything.
    Edwin Pawlowski, Jul 21, 2007
  1. Jim Becker
    Larson Storm Door
    Jim Becker, Apr 24, 2004, in forum: Misc DIY
    333
    Jim Becker
    Apr 24, 2004
  2. mmclaurin2
    Install Pella Storm Door
    mmclaurin2, Nov 19, 2005, in forum: Misc DIY
    1,057
    calhoun
    Nov 20, 2005
  3. hr(bob)
    Larson Storm Door PRoblems
    hr(bob) , Sep 12, 2009, in forum: Misc DIY
    1,269
    hr(bob)
    Sep 13, 2009
  4. Default User
    Larson 349-20 security glass storm doors
    Default User, Apr 16, 2006, in forum: Building Construction
    963
    Al Bundy
    Apr 16, 2006
  5. Default User
    Storm windows for Pella Proline ?
    Default User, Sep 26, 2006, in forum: Building Construction
    676
    Default User
    Sep 26, 2006
