Steel Lintels
Discussion in 'Home Repair' started by m Ransley, Apr 29, 2006.
  1. m Ransley
    m Ransley Guest
    How big a job is it, hours required, to replace Steel Lintels apx 3 ft
    wide on a brick building. Ive gotten a price of 500 a lintel.
  2. m Ransley
    DanG Guest
    Are these lintels on an existing building with a load imposed?
    What is above the lintels (how much weight, how many feet
    high)?Why are you replacing them?
    Without more information, to take on the liability of pinning a
    structure, resupporting a load, shoring, etc I can't imagine
    touching the job for $500 each. Are you the type to sue or refuse
    to pay if there is any cracking of the masonry overhead?
    ______________________________
    Keep the whole world singing . . . .
    DanG (remove the sevens)
    "m Ransley" <> wrote in message
    > apx 3 ft
    DanG, Apr 29, 2006
  3. m Ransley
    SQLit Guest
    3 feet wide, sure is a thick wall. How long is it?
    SQLit, Apr 29, 2006
  4. "SQLit" <> wrote in message
    news:_dN4g.15$...
    > news:...
    Reminds me of the (insert favorite nationality here) joke about landing on a
    runway at an airport the pilot has never been to. They aborted the first
    landing because the runway was too short. After extreme braking measures on
    the second attempt they manage to stop the plane just in time. Pilot says
    "this is a very short runway" and the co-pilot responds "but it sure is
    wide".
    Edwin Pawlowski, Apr 29, 2006
  5. m Ransley
    mm Guest
    On Sat, 29 Apr 2006 17:01:47 GMT, "Art"
    <> wrote:
    >Is it around a door or window or just an opening? Make sure it is long enuf
    >and correct thickness and flashed and at least primed. Usually a good mason
    >is going to charge at least half a day no matter what. Plus he has to saw
    >out old brick with diamond blade. It sounds high. But he also has to order
    >the lentil and that involves driving time. I would think $300 in NC market
    Be sure to order dry lentils. I tried to do this job with soaked
    lentils and it didn't work well at all.
    >but if he has reversed full day
    No comment <big grin from anotehr bad tpiyst.>
    > for complications, $500 might be right if he
    >is good and reliable.
    >news:...
    mm, Apr 30, 2006
  1. Lydiate \(Remove trousers to reply\)
    Rusty Window Lintels
    Lydiate \(Remove trousers to reply\), Nov 9, 2003, in forum: Misc DIY
    1,463
  2. Rich
    door and window lintels
    Rich, Dec 18, 2003, in forum: Misc DIY
    1,643
    Lobster
    Dec 22, 2003
  3. Niel A. Farrow
    which lintels for job?
    Niel A. Farrow, Jan 14, 2004, in forum: UK DIY
    813
    BigWallop
    Jan 15, 2004
  4. DIY Novice
    2,551
    warwick
    Aug 24, 2004
  5. BigWallop
    Re: Steel lintels - how to cover ?
    BigWallop, Sep 1, 2003, in forum: UK Home Improvement
    1,216
    BigWallop
    Sep 1, 2003
