Standing Seam vs. Lap Seam
Discussion in 'Building Construction' started by ecarecar, Oct 25, 2006.
  1. ecarecar
    ecarecar Guest
    I have a small, low-slope metal roof of about 300 square feet.
    What are the advantages and disadvantages of a standing seam
    roof versus a lap seam?
  2. ecarecar
    Bob Morrison Guest
    In a previous post ecarecar wrote...
    Standing seam has no exposed fasteners and should be considered a
    permanent roof if properly installed. Laps seams have gasketed fasteners
    that can leak over time and this causes rusting of the steel sheets.
    Go with standing seam!
    Bob Morrison, PE, SE
    R L Morrison Engineering Co
    Structural & Civil Engineering
    Poulsbo WA
    bob at rlmorrisonengr dot com
    Bob Morrison, Oct 25, 2006
  3. ecarecar
    ecarecar Guest
    You can use non-gasketed fasteners and solder them over.
    What about wicking around the seams of the standing seams?
    ecarecar, Oct 26, 2006
  4. ecarecar
    Bob Morrison Guest
    The idea of soldering the top hundreds of fasteners doesn't seem very
    practical. Also, the soldering process will most likely damage the baked-
    on finish.
    Never heard of it happening, especially if it is a field rolled seam. But
    even snap-lok type standing seam roofs work pretty well.
    Poulsbo WA
    Bob Morrison, Oct 26, 2006
  5. ecarecar
    Dan Deckert Guest
    Standing seam if you can afford it.
    NO SOLDERING ON EXPOSED
    FASTENERS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Dan
    "ecarecar" <> wrote in message
    Dan Deckert, Oct 28, 2006
  6. ecarecar
    Tim Mulvey Guest
    I've installed panels from American Buildings, Metallic, and Pac-Clad. The
    female has a bead of factory applied butyl sealant that prevents wicking at
    the seams. Panels from American can be installed and warrantied on slopes as
    low as 1/2" : 12".
    Tim Mulvey
    Tim Mulvey, Oct 28, 2006
  7. ecarecar
    Bob Morrison Guest
    In a previous post Dan Deckert wrote...
    Dan:
    I agree absolutely! Soldering of fasteners does not seem like one of the
    better thought out ideas.
    Poulsbo WA
    Bob Morrison, Oct 30, 2006
  8. ecarecar
    Dan Deckert Guest
    "Bob Morrison" <> wrote in message
    > Dan:
    > Poulsbo WA
    The OP made some mention of soldering. I've NEVER HEARD OF SUCH in 30 yrs.
    of putting on metal roofs. I 'suppose' it might apply to 'some type' of
    copper roof but it seems wierd to me. The new Kynar paints over galvalume
    substrate would never allow adhesion anyway much less with the Kynar painted
    zinc chromate srews with neoprene washers.
    The newer SSR's with factory installed mastic will prevent wicking if the
    SSR is applied correctly. Even better are SSR's with a mechanical seamer run
    down them to roll & fold the seam. Damn near bullet proof. I have, however,
    installed an SSR roof with a seamer and had leaks. It was because the
    factory had failed to apply enough mastic to seal the lap. Interestingly
    enough it was a Butler Bldg. of whose product (roofs anyway) I consider one
    of the best.
    Dan
    Dan Deckert, Oct 31, 2006
  9. ecarecar
    RicodJour Guest
    It is possible to directly solder copper nails on a copper roof, but
    it's a bit of a hack. The preferred way to achieve that end is to nail
    through a copper clip, fold the clip over the top of the nail and
    solder the perimeter of the clip.
    RicodJour, Oct 31, 2006
  10. ecarecar
    ecarecar Guest
    >Dan:
    Well, you should think about it.
    ecarecar, Nov 1, 2006
  11. ecarecar
    ecarecar Guest
    >news:...
    >>Dan:
    >>Poulsbo WA
    There's your problem. If you had 60 years of putting on metal roof, you
    would
    have heard of it.
    #11
  12. ecarecar
    Dan Deckert Guest
    Seems as though ecarecar is in severe contrast to our opinions and
    experience, not to mention ADVERSLY CONTRASTED.................LOL Ya
    suppose a 78 yr old guy is ticked off here? 60 yrs. of roofing and 18 yrs.
    to be old enuf 2 do the work????
    Dan
    "RicodJour" <> wrote in message
    yrs.
    > R
    Dan Deckert, Nov 1, 2006
    #12
  13. ecarecar
    RicodJour Guest
    Which makes this more curious:
    http://tinyurl.com/yzjgce
    I'd like to hear his reasoning and procedure for directly soldering the
    fastener.
    RicodJour, Nov 1, 2006
    #13
  14. ecarecar
    Bob Morrison Guest
    Okay, I thought about it for about 5 seconds and have come to the
    conclusion that soldering roofing fasteners on a steel roof is one of the
    dumbest ideas I have ever heard of.
    Poulsbo WA
    Bob Morrison, Nov 1, 2006
    #14
  15. ecarecar
    ecarecar Guest
    No. That's all wrong.
    The process comprises soldering sheet stainless steel together then driving
    nails in to hold it in place and soldering the nails. It produces an
    excellent
    roof.
    #15
  16. ecarecar
    Bob Morrison Guest
    > excellent
    > roof.
    That may be, but one doesn't need to go to that much work to get an
    excellent roof. Not to mention, most steel roofs these days have a baked
    on finish that would make soldering them together virtually impossible
    without ruining the finish.
    A standing seam roof is only marginally more expensive (25% or so) than a
    conventional lap seam roof. This seems like a small price to pay for what
    is essentially a permanent roof.
    As others have pointed out, a field rolled seam is usually best, but snap
    lock seams work pretty well too for residential applications over a solid
    sheathing substrate.
    Poulsbo WA
    #16
  17. ecarecar
    RicodJour Guest
    > excellent roof.
    Okay, now you've lost me. I've done a fair bit of copper and
    lead-coated copper roofing. When sections are seamed and soldered, all
    of the nails and copper clips/cleats are concealed. There are few if
    any exposed fasteners. Why would you have exposed fasteners,
    essentially creating a new metal roofing technique, when the existing
    copper roofing techniques have centuries of performance standing behind
    them? You obviously could do the same thing with stainless steel.
    The concealed clips/cleats are what allows the metal roofing to move
    with thermal expansion/contraction. By nailing it down directly you're
    just building in weak points in the roofing. If your soldering job is
    impeccable and the solder doesn't fail, the thermal expansion cycle
    will elongate the nail hole and the nail will lose a significant amount
    of its holding power. This is a critical flaw in high wind areas. The
    roof will fail at those points, it's just a question of when.
    The fact that in your experience you haven't had any failures doesn't
    mean much in this instance. A stainless or lead-coated copper roof
    should outlast you, your children and their children if done correctly.
    It's like being in the fiberglass roofing business and saying that
    you've been installing them for 4 years, so there's no problem with
    your installation. Doesn't fly.
    #17
  18. ecarecar
    RicodJour Guest
    It's our own fault. I didn't keep track of the posting history. I
    thought he was weighint in with some expertise on the OP's question, so
    I replied. I hadn't noticed that he is the OP.
    Gee, maybe we were "set up" - maybe he's checking to see if we know
    what we're talking about. So either he's a troll, has trollish
    tendencies, or, from the comments, has no basis to determine if we do
    know what we are talking about or not.
    #18
  1. Ian White
    Ship-lap cladding for greenhouse?
    Ian White, Aug 29, 2004, in forum: UK DIY
    446
    Ian White
    Aug 29, 2004
  2. Andrew Welham
    pergola and lap joints
    Andrew Welham, Apr 1, 2005, in forum: UK DIY
    10
    890
    Rob Morley
    Apr 4, 2005
  3. Replies:
    816
  4. Michael
    Standing Seam Metal Roof Problems
    Michael, Jan 7, 2004, in forum: Building Construction
    322
    Michael
    Jan 7, 2004
  5. Replies:
    324
    YouRepair.com
    Nov 15, 2005
