spirit based gloss over water based primer ok ?
Discussion in 'UK Home Improvement' started by Steve, May 16, 2008.
  1. Steve
    Steve Guest
    Two tins of Berger paint.
    Both called pure brilliant white
    both ok for interior and exterior use.
    Quick dry primer undercoat , clean brushes with water.
    Liquid gloss (clean brushes with proprietary brush cleaner)
    Is it ok to use the gloss over the primer if primer allowed to dry (2hr
    touch dry, 4 hr before overcoating it says on primer)
    considering the fact that primer is water based and gloss is not ?
    To cover plywood shelf.
    Cheers
    Steve
    Steve, May 16, 2008
  2. Steve
    Steve Guest
    Cheers, will do.
    Steve
    "TonyB" <> wrote in message
    > "Steve" <> wrote in message
    > news:uOjXj.4540$...
    >> Hi,
    >> Cheers
    >> Steve
    > It should be fine but just to be safe I would try a bit of gash wood
    > forst.
    > TonyB
    Steve, May 16, 2008
  3. Steve
    Tanner-'op Guest
    Steve wrote:
    > Hi,
    > (2hr touch dry, 4 hr before overcoating it says on primer)
    > Cheers
    > Steve
    Steve,
    No problems with that system internally (as per your question), but I would
    advise against using a water-based primer/undercoat under an oil-based gloss
    paint for external decoration as there is a possibility of it prematurely
    breaking down.
    Tanner-'op
    Tanner-'op, May 16, 2008
  4. Steve
    Steve Guest
    Cheers tanner-'op'
    Well and truly noted. Wish these manufacturers would say so on tins.
    Steve
    "Tanner-'op" <tannerop@i......nvalid.com> wrote in message
    > Steve wrote:
    >> Hi,
    >> Cheers
    >> Steve
    > Steve,
    > would advise against using a water-based primer/undercoat under an
    > oil-based gloss paint for external decoration as there is a possibility of
    > it prematurely breaking down.
    > Tanner-'op
    Steve, Jun 13, 2008
  5. Steve
    Keith W Guest
    But then you could have a go if it didn't work as they said. Ouch, my
    cynical nerve is twitching again.
    Keith W
    Sunbury on Thames
    (If you can't laugh at life, it ain't worth living)
    news:zgi4k.8283$...
    > Cheers tanner-'op'
    > Steve
    > news:...
    >> Steve wrote:
    >>> Hi,
    >>> Cheers
    >>> Steve
    >> Steve,
    >> of it prematurely breaking down.
    >> Tanner-'op
    Keith W, Jun 14, 2008
  1. DavidM
    761
    DavidM
    Jun 28, 2007
  2. wendi
    10
    1,514
    Baron
    Jul 9, 2004
  3. Tube Audio
    495
    dadiOH
    Oct 15, 2007
  4. Andy
    Oil based Gloss over Water based Gloss
    Andy, Jul 25, 2004, in forum: UK Home Improvement
    813
  5. sm_jamieson
    paint - water / spirit based
    sm_jamieson, Aug 27, 2013, in forum: UK DIY
    10
    439
    stuart noble
    Aug 30, 2013
