Snow thrower wheel drive problem
Discussion in 'Home Repair' started by Jim, Feb 27, 2005.
  1. Jim
    Jim Guest
    I have a fairly new Sears Craftsman (Murray) snow blower. The unit
    itself works fine, but I am having trouble with pin that unlocks the
    right wheel for easier maneuvering on dry ground and locks it for both
    wheel drive.
    According to the directions the "klick pin" can be moved to the outer
    hole to unlock the right wheel so it is free wheeling. In the inner
    hole, the wheel is connected to the drive axle so that it is driven
    together with the left wheel.
    This worked great for a few times. Now I have the pin in the free wheel
    (outer) hole and would like to put it back in the drive (inner) hole.
    Unfortunately I can only see the exterior part of the hole. I can no
    longer see all the way through the hole, that goes through the axle.
    The pin must go all the way through this and something appars to be
    blocking it.
    Has anybody had this problem? How do I fix it and get everything to
    line up? Thanks.
    [ Sears Craftsman Murray snow blower snow thrower klik pin click pin
    klick pin 881750 536.881750]
    Jim, Feb 27, 2005
  2. Brian V
    Brian V Guest
    "Jim" <> wrote in message news:...
    > wheel drive.
    > blocking it.
    > line up? Thanks.
    Hi Jim,
    I did it yesterday during our storm. The outside hole is 90deg from the
    internal hole. I had a hunk of ice in mine. Blasted it with a heat gun,
    budda-bing, was cleared in about 30 seconds.
    outside
    ------- inside
    -Brian
    Brian V, Feb 27, 2005
  3. Jim
    Jim Guest
    > > wheel drive.
    > > blocking it.
    > > line up? Thanks.
    > Hi Jim,
    > outside
    > ------- inside
    > -Brian
    Hi Brian, thanks for the tip re: the 90 degrees. I didn't notice that when I
    could see the hole. My problem isn't ice though, my unit is warm and dry in
    the garage and the inside (axle) part of the inner hole is obscured by
    something. Is there any chance a bushing or something has slid in the way?
    I'm reluctant to take the wheel off and I'm not sure the retainer ring could
    be used again.
    Jim, Feb 27, 2005
  4. arf
    arf Guest
    I had this exact same problem.
    There is a nylon bushing inside the wheel 'hub' that has slid
    out of place. It acts as the bearing between the wheel rim and
    the axel.
    Prop that side of the blower up and pull the wheel right off. (Mine
    had a star shapped clip I had to pry off with a screwdriver
    before I could get the wheel off.)
    The nylon tube may stay on the axel shaft or you may have to
    push it out of the wheel.
    Put the bushing back in the wheel, aligning the holes and drop the
    pin in so they stay ligned up. Put the wheel back on the axel
    untill the pin hits. Pull the pin almost all the way out and put the
    wheel on. You want the pin through one half of the wheel and
    and one half of the bushing so the holes stay lined up or you'll
    be pulling the wheel off again.
    The wheel slides on and off real easy. I did this on a
    Sears 536.887752.. There are no bearings or other pieces
    that could fall out. I see this as a design flaw and I leave the wheel
    locked all the time.
    Good Luck
    arf, Feb 27, 2005
  5. Jim
    Jim Guest
    > the axel.
    I was able to fix the problem by taking the wheel off. That was simple,
    but getting the retainer ring (clip) off before the wheel was a real pain,
    even with a screw driver. My bushing doesn't have holes in it, it sounds
    like yours does? I just moved the bushing farther down the axle so it
    isn't covering the 2 wheel drive hole anymore. I need one wheel drive to
    store the machine in the garage, but I'll be sure not to use it other than
    moving the blower in and out.
    I was trying to think of a way to keep that bushing from moving, perhaps a
    small screw (extending no further than the thickness of the bushing) in
    the axle will do it. I don't have a drill press available to do that
    though, so I'll just hope it doesn't wander around again. Thanks to all
    who responded!
    Jim, Mar 2, 2005
  1. SJ
    Gonna buy a snow thrower
    SJ, Sep 13, 2003, in forum: Home Repair
    393
  2. jb
    snow thrower advice
    jb, Nov 7, 2003, in forum: Home Repair
    15
    490
    Jim Strand
    Nov 12, 2003
  3. Billy
    How to Buy a Snow Thrower?
    Billy, Dec 7, 2003, in forum: Home Repair
    445
    Jay Chan
    Dec 9, 2003
  4. Lawrence M. Seldin, CMC, CPC
    Toro 521 Snow Thrower has problem starting up
    Lawrence M. Seldin, CMC, CPC, Feb 25, 2005, in forum: Home Repair
    911
    Feb 27, 2005
  5. tomkanpa
    449
