Smoking Woodburner
Discussion in 'UK Home Improvement' started by puffernutter, Jan 3, 2010.
  1. puffernutter
    puffernutter Guest
    We have had a woodburner for about 4 years now, but in the last few days
    we have had a problem with smoke coming back from the burner.
    The flue was swept at the end of October and the fire has been in daily
    use since. We burn compressed rape seed husks that have given us no
    problems in the past.
    There is a vent at the top (to keep the glass clear), two dampers at the
    bottom front of the fire and a flue damper.
    Generally we start with all dampers open, when it is going well we shut
    the bottom dampers and can control it on the flue damper. The top vent
    always stays open.
    BUT, in the last few days whenever we start the fire, or in fact at any
    time that it is lit, if the bottom dampers are opened, copious
    quantities of smoke come out the top vents. This means that to have the
    fire on (and to breathe!) we need to have all the dampers shut, which
    leads to a "sulky" fire, not a lot of heat and as this is also the back
    boiler for the radiators, a cold house.
    I have looked inside the fire and there is nothing obvious blocking
    anywhere (including the flue damper).
    We originally thought it may be to do with the weather, high pressure
    and very still, but I am now wondering if we have a partial blockage of
    the flue (there is some smoke coming out of the top of the chimney).
    Before I call a sweep out, is there anything obvious that I have missed?
    Cheers
    Peter
    Train set at www.lmandwr.co.uk
    Dogs at www.whissgig.co.uk
  2. A _L_ P
    A _L_ P Guest
    > always stays open.
    If you were in New Zealand I'd say starlings had built a nest in your
    chimney. Helpful, ain't I?
    A L P
    A _L_ P, Jan 4, 2010
  3. puffernutter
    puffernutter Guest
    Leveled wrote:
    > "puffernutter" <> wrote in message
    > news:Zc80n.54199$2...
    >> always stays open.
    >> time that it is lit, if the bottom dampers are opened, copious quantities
    >> of smoke come out the top vents. This means that to have the fire on (and
    >> to breathe!) we need to have all the dampers shut, which leads to a
    >> "sulky" fire, not a lot of heat and as this is also the back boiler for
    >> We originally thought it may be to do with the weather, high pressure and
    >> very still, but I am now wondering if we have a partial blockage of the
    >> Cheers
    >> Peter
    > Well if you open all the dampers and slides you should have a big fire to
    > flame away. Try some nice dry kindling wood and if it still smokes you must
    > have a blockage in the flue
    Turned out to be a totally clogged cowl.
    Chimney sweep came out tonight and sorted it.
    Burning like a good-un now!
    Cheers
    Peter
    puffernutter, Jan 4, 2010
  1. drlurch
    lubricating a woodburner
    drlurch, Jul 26, 2003, in forum: UK DIY
    436
    John Flax
    Jul 26, 2003
  2. alex
    Smoking living Fire
    alex, Sep 24, 2003, in forum: UK DIY
    315
    Ed Sirett
    Sep 24, 2003
  3. Rick Dipper
    998
    Owain
    Oct 29, 2003
  4. Stu
    Woodburner Installation
    Stu, Jul 5, 2005, in forum: UK DIY
    577
    Andy Dingley
    Jul 9, 2005
  5. marcb
    More smoking advice pls
    marcb, Aug 13, 2005, in forum: UK DIY
    16
    523
    raden
    Aug 22, 2005
Share This Page
