Small engine help
Discussion in 'Home Repair' started by Sacramento Dave, Mar 25, 2006.
  1. the engine on my lawn edger has started pulsating. the RPM's go high and
    low. It has been sitting for awhile, but I do put gas saver in my gas before
    winter. The edger is about a year old, If I hold the throttle linkage it
    runs smooth, the linkage move when running. Any suggestions?
  2. Pop
    Pop Guest
    Start with a good external cleaning of everything that moves,
    especially the linkage. Look for things rubbing, sticky, etc..
    WD40 is good for cleaning. Air hose helps some too.
    "Sacramento Dave" <> wrote in message
    news:YieVf.59146$...
    > high and low. It has been sitting for awhile, but I do put gas
    > saver in my gas before winter. The edger is about a year old,
    > If I hold the throttle linkage it runs smooth, the linkage move
    Pop, Mar 25, 2006
  3. Guest
    On Sat, 25 Mar 2006 16:35:04 GMT, "Sacramento Dave"
    Check the governor linkage. That is the flapper under the cowl and the
    skinny spring to the carb. There may also be an adjusting screw.
    , Mar 25, 2006
  4. "Sacramento Dave" <> wrote in message
    > before winter. The edger is about a year old, If I hold the throttle
    > linkage it runs smooth, the linkage move when running. Any suggestions?
    check your air filter..sometimes when they get dirty they will do that.
    Is it a briggs and stratton engine with the carb mounted to the fuel tank???
    If it is sometimes the carb base will warp and it will suck air between the
    carb and the tank and get the same effect.
    digitalmaster, Mar 26, 2006
  5. WConner
    WConner Guest
    Well you have gotten several good suggestions. If nothing is apparent right
    off, I would put some SeaFoam or similar product in the gasoline per
    instructions. You may have developed a little varnish, moisture or other
    contaminant in the carb over the winter. Sounds like it is lean.
    Walt Conner
    WConner, Mar 26, 2006
  6. I'm not familiar with "Sea Foam". What is it and where can it be obtained?
    "WConner" <> wrote in message
    news:sqzVf.2208$qm2.667@trnddc03...
    > right off, I would put some SeaFoam or similar product in the gasoline per
    > Walt Conner
    John Lawrence, Mar 26, 2006
  7. WConner
    WConner Guest
    SeaFoam is the latest rage of gasoline additives similar to "Gumout" for
    cutting carburator deposits, carbon in combustion chamber, pick up moisture
    from fuel, etc. I have little experience with it but several on a small
    engines list I monitor have good things to say about it. Our local Farm
    Supply Store has it, I would expect most Auto Parts Stores and perhaps,
    Wal-Mart. $5 - $6 per can.
    Walt Conner
    WConner, Mar 27, 2006
  1. robgraham
    Small petrol engine air cleaner
    robgraham, Mar 19, 2007, in forum: UK DIY
    387
    Thomas Prufer
    Mar 20, 2007
  2. Brian
    small engine repair
    Brian, Jun 28, 2003, in forum: Home Repair
    455
    Brian
    Jul 3, 2003
  3. Plumbers Crappy Problem
    Help Help Help - Plumbing problem + small asbestos question
    Plumbers Crappy Problem, Nov 13, 2004, in forum: Misc DIY
    575
    Inspector D
    Nov 15, 2004
  4. Replies:
    353
    MikeB
    Dec 31, 2006
  5. coloradotrout
    1,646
    coloradotrout
    Jan 20, 2009
