slow draining sink?
Discussion in 'Misc DIY' started by Lee Carkenord, Oct 9, 2004.
  1. I have a sloooow draining bathroom sink. In the past, I've been able
    to seal off the overflow and then apply a plunger, and that would fix
    it, at least for a while.
    This time, the plunger has no effect. I want to try one of the
    chemicals that you pour into the drain.
    I've looked at Drano and Liquid Plumber at the store. Which of those
    2 products might serve me best?
    Or maybe there is a better product, that's commonly available at Home
    Depot or Lowes or etc?
    Thank you Lee Carkenord
  2. Tony Hwang
    Tony Hwang Guest
    Disassemble stopper and P trap. Look at that dirty gunk
    build up!
    Tony
    Tony Hwang, Oct 9, 2004
  3. "Lee Carkenord" <> wrote in message
    A snake. Chemicals (corrosives) may help, may even clear it, but a snake
    removes the clog. You may want to open the trap and check it out to see if
    the clog is just a big hairball that you can pull out. I've take short cut,
    but nothing works better than a mechanical cleaning in the long run.
    Edwin Pawlowski, Oct 9, 2004
  4. "Edwin Pawlowski" <> wrote in
    news:xhU9d.12378$:
    > snake removes the clog. You may want to open the trap and check it
    > out to see if the clog is just a big hairball that you can pull out.
    > I've take short cut, but nothing works better than a mechanical
    I have sturdy metal pipes, so I used pressurized air in a can. I bought it
    at the hardware store for about $8. Just a couple of short bursts and the
    drain was clear. A plunger didn't work and neither did a snake.
    http://www.powerplumber.com/faqs.asp
    BE SURE YOUR PIPES CAN WITHSTAND THE PRESSURE.
    RobertPatrick, Oct 9, 2004
  1. Replies:
    456
    Scrump
    Jan 8, 2008
  2. JoeThomas
    Toilet slow, very slow to refill
    JoeThomas, Nov 23, 2003, in forum: Misc DIY
    8
    848
    luvr29
    Nov 28, 2006
  3. Dan
    770
    Michael Nickolas
    Apr 20, 2004
  4. Mal Travers
    Slow draining sink
    Mal Travers, Feb 17, 2012, in forum: UK Home Improvement
    343
    Mal Travers
    Feb 17, 2012
  5. DerbyDad03
    Slow Close Toilet Seat Too Slow
    DerbyDad03, Feb 19, 2013, in forum: Home Repair
    13
    375
    DerbyDad03
    Feb 21, 2013
Share This Page
