Skimming over old plaster.
Discussion in 'Misc DIY' started by Andy Hide, Feb 24, 2004.
  1. Andy Hide
    Andy Hide Guest
    Anyone have any tips for skimming onto old plaster? Managed an almost
    perfect skim onto plasterboard but finding that old walls are much
    more difficult. Any slight lumps and bumps mean that the you are more
    likely to miss bits when trying to get a good finish.
    I primed the surface first with PVA which I think helped to increase
    the working time. Total thickness of the skim was about 2-3mm. Can you
    go thicker than this on old walls to help cover up any imperfections ?
    Applied in two coats, the second applied just as the first was
    begining to set.
    Also found that there were a few grit marks. Badly mixed plaster ?
    When ironing out the trowel marks as the plaster is setting does
    anyone have any tips on which way to work across the wall. Should you
    go top to bottom or left to right? Are long sweeps, short sweeps
    better ?
    Any help much appreciated.
    Andy.
  2. Andy Hide
    Jet Guest
    "Andy Hide" <> wrote in message
    <<snip>>
    > begining to set.
    Done this also, but waited for the first coat of plaster to dry out. Not
    always possible but it stops the second skim coat being "pushed" into the
    first skim, if that makes sense.
    Maybe a dirty bucket containing left-overs from a previous mix? It pays to
    keep *all* equipment including buckets / mixing paddles spotless. I used to
    use a piece of 2x2 but invested in a paddle to mix the wet stuff as its
    easier to keep clean.
    > better ?
    Whatever is the comfiest. I find that at first the sweeps are longer with
    greater pressure, gradually diminishing as the bumps and curves get flatter.
    HOT TIP: Stellas Law :- I *NEVER* skim without at least 1 can down my neck,
    then I got something to blame when SWMBO spots a flaw ;))
    hth
    Jet
    all plastering done when the sun is over the yard-arm ;)
    Jet, Feb 24, 2004
  3. Andy Hide
    Grouch Guest
    > begining to set.
    > better ?
    > Andy.
    There's no golden rule to Plastering if you feel comfy the way You apply it
    then settle for that.
    One tip I can give instead of having a large pasting brush in hand to dampen
    plaster as your Polishing it, use a spray bottle.
    Grouch
    Grouch, Feb 24, 2004
  4. Andy Hide
    Andy Hide Guest
    Thanks for these tips. Another question though. If you are skimming a
    largish wall e.g. a hallway or stairs is it possible to split the job
    into two sections ? Skim dries out quite quickly and I don't think I
    could get a 4m wall done in time. Is there a standard technique to get
    a good join between the two or is it time to call in a pro who can
    work at a decent speed ?
    "Grouch" <> wrote in message news:<GVE_b.5400$>...
    > news:...
    > > begining to set.
    > > better ?
    > > Andy.
    > Grouch
    Andy Hide, Feb 26, 2004
  5. Andy Hide
    JW Guest
    It is a bit tricky to skim a large wall. Make a slightly sloppier mix to
    give yourself a bit more time.
    If you start at one end & as you work across, you'll find you're skimming
    one area whilst polishing another. You'll need someone to mix as you will be
    quite busy working the plaster.
    Give it a try. If it ends up a mess, you can always get a plasterer in to
    skim over it.
    As Grouch said, use a spray bottle. The 1 ltr garden sprays are ideal.
    JW
    JW, Feb 27, 2004
  6. Andy Hide
    Grouch Guest
    Get your Missus to do the mixing. :eek:( this will give you an edge over
    covering the wall in one fell swoop, make sure the Mix is sloppy try to get
    in the knack of sweeping the Plaster in large sweeps, either up the wall or
    across.
    I'm no Master plasterer and have to Mix the stuff & apply it. Two of my
    walls are ten foot high by twelve feet across when I first started I thought
    Jesus! I'll have to work lig a pig but when I actually got into the swing of
    it they where both done in no time. pant! :eek:)
    I'm only 5 foot 2 inchs/9 stone. But got the stamina to tackle and finish.
    Grouch
    Outgoing mail is certified Crap Free.
    Version: 6.0.593 / Virus Database: 376 - Release Date: 20/02/2004
    Grouch, Feb 27, 2004
  7. In article <>,
    (Andy Hide) writes:
    > into two sections ?
    Yes. Pick a join line, plaster slightly over it, and before the
    plaster has gone fully off, cut back the edge to a clean step, and
    not feathered, as you can't feather in a join. If you know where the
    join is, you will always be able to see it on the finished work, but
    a good join won't notice unless you look for it. On many houses, you
    will spot a join on the wall where the staircase is, as the plasterer
    probably didn't do it in one go.
    Hum -- skim normally takes a day to dry out IME, much longer than it
    takes to go off (set).
    Remove any obvious lumps above the surface.
    The first skim coat goes on normally as thin as you can but should
    leave the plaster level with the most proud bumps remaining on the wall.
    i.e. you tend to scrape the trowl edge over the rough surface, but it
    should leave you with a flat surface. The reason for the second coat is
    that you can't polish this first coat because of the background coming
    to the surface in places. So the second coat is then put on ~2mm thick
    to give you clearance over the most proud bumps on the background, and
    that's enough to enable you to polish the surface.
    Yes. The issue is that plaster finish coat shrinks when it sets. A thin
    coat shrinks by getting slightly thinner which doesn't notice, but a
    thick coat may crack.
    >> > begining to set.
    Possibly. Check you aren't leaving unmixed plaster up the sides of
    the bucket, only to fall in when you pour the plaster out. Other
    sources of grit are from the wall (PVA should have stopped that)
    or from adjacent walls/ceilings. I had fun plastering a wall up to
    a ceiling artexed with small stalactites. The trowl edge would keep
    breaking them off and dragging them into my plasterwork ;-)
    >> > better ?
    Generally inwards from all the edges. Keeping the edge of the trowl
    parallel to the wall edge, start the sweep along the edge but in a
    circular motion which sweeps out and ends a quarter turn later in a
    direction perpendicular to the edge, but without turning the trowl.
    When you aren't near an edge, it doesn't matter.
    Andrew Gabriel
    Andrew Gabriel, Feb 27, 2004
  8. Andy Hide
    Andy Hide Guest
    Thanks for the tips. Do you complete the whole wall with the first
    coat following this method and then the second coat or are you
    applying the second coat on the earlier sections as they begin to set
    as you work along the wall ?
    Put another way - do you have to follow the second coat quickly after
    the first as you are moving along the wall or can you complete the
    whole wall 1st coat and then go back and do the 2nd coat.
    Hope I have made myself clear here.
    Andy.
    "JW" <> wrote in message news:<c1mc96$btf$>...
    > news:...
    > skim over it.
    > JW
    Andy Hide, Mar 4, 2004
  9. Andy Hide
    Andy Hide Guest
    Thanks for these tips. One thing I have noticed is that you polish up
    the plaster and think you've done a great job. However, when the
    plaster dries out and goes a lighter colour you see small areas (no
    bigger than 10 pence piece in the worst places max) where it looks
    like the plaster has not been polished up properly. I have seen this
    to a lesser extent in pro's work too and can't figure how why this
    happens.
    This never happens to me on plaster board so I can only guess that
    maybe the wall I am going over is not perfectly flat. As you polish up
    with the float you are missing tiny dimples in the wall as the float
    is passing over them. Anyone else come across this ? Anyone got a fix?
    Andy.
    (Andrew Gabriel) wrote in message news:<c1o480$1sj$>...
    > In article <>,
    > (Andy Hide) writes:
    > > into two sections ?
    > >> > begining to set.
    > >> > better ?
  10. Andy Hide
    Grouch Guest
    || happens.
    || up
    || fix?
    || Andy.
    ||| In article <>,
    ||| (Andy Hide) writes:
    |||| skimming a largish wall e.g. a hallway or stairs is it possible to
    |||| split the job into two sections ?
    ||| plasterer probably didn't do it in one go.
    |||||| almost perfect skim onto plasterboard but finding that old walls
    |||||| are much more difficult. Any slight lumps and bumps mean that
    |||||| the you are more likely to miss bits when trying to get a good
    |||||| finish.
    ||| wall. i.e. you tend to scrape the trowl edge over the rough
    ||| surface, but it should leave you with a flat surface. The reason
    ||| for the second coat is that you can't polish this first coat
    ||| because of the background coming to the surface in places. So the
    ||| second coat is then put on ~2mm thick to give you clearance over
    ||| the most proud bumps on the background, and that's enough to enable
    |||||| increase the working time. Total thickness of the skim was about
    |||||| 2-3mm. Can you go thicker than this on old walls to help cover
    ||| thin coat shrinks by getting slightly thinner which doesn't notice,
    ||| but a thick coat may crack.
    |||||| begining to set.
    |||||| Should you go top to bottom or left to right? Are long sweeps,
    |||||| short sweeps better ?
    Bet you can't do a ceiling. lol. After the plasters dried coat the wall with
    a thin mix of PVA, it helps a great deal if your Wallpapering over it.
    Grouch
    Grouch, Mar 4, 2004
  1. Zymurgy
    1,404
    BillR
    Aug 27, 2003
  2. jerrybuilt
    915
    Zymurgy
    Aug 28, 2003
  3. Replies:
    8
    717
    David W.E. Roberts
    May 19, 2004
  4. ddd
    5,732
    James
    Jul 22, 2004
  5. bill
    skimming over old walls
    bill, Feb 22, 2005, in forum: Misc DIY
    727
    chris French
    Feb 22, 2005
