Size for wood rails for fence
Discussion in 'UK DIY' started by ss, May 4, 2013.
  1. ss
    ss Guest
    Would 3" x 1" inch rails be sufficient for a fence.
    Or should I use 3 x 2 inch?
    Vertical slats with a slight gap between the slats.
    Max height 6 feet. Posts 6 feet apart.
    thanks
    ss, May 4, 2013
  2. Bob Minchin
    Bob Minchin Guest
    > thanks
    ex 3" arris rails would be stiffer and the conventional approach.
    Self draining too
    Bob Minchin, May 4, 2013
  3. harry
    harry Guest
    It depends on the purpose of the fence.
    If it is ornamental, it can be as light as you like.
    If it is to keep something/one in/out, it needs to be stronger.
    Also depends on how windy it is.
    harry, May 4, 2013
  4. ss
    ss Guest
    Just to improve privacy, I have a hedge at the back of the fence but
    foliage disappears in Winter, and a road beyond that. Wind factor
    normally is ok except when we get any storms (Scotland). Crime rate low
    so I dont expect intruders.
    ss, May 4, 2013
  1. peter
    8
    534
  2. Replies:
    503
    willshak
    Jun 7, 2007
  3. mike
    Fence Rails: 2 or 3?
    mike, May 11, 2009, in forum: Home Repair
    12
    940
  4. David WE Roberts
    6,237
    David WE Roberts
    Aug 25, 2009
  5. David WE Roberts
    20
    1,043
    David WE Roberts
    Sep 10, 2009
Share This Page
