shower diverter valve is now hard to activate
Discussion in 'Misc DIY' started by Dmitri, Jan 19, 2005.
  1. Dmitri
    Dmitri Guest
    . . . after I replaced the showerhead with a showerholder with a metal hose
    and a handshower. I have one of those Delta tub faucets with a diverter
    actuator handle at the end of the tap: pull it up for the shower - down for
    the tub. With water at full pressure, it is now much harder (but still
    possible) to pull the handle up for the shower. I also need to apply more
    pressure to force it back into the tub position. With water at half the
    pressure - no problem. I suspect because of my shower installation, it is
    harder to force the water to shift from the tub to the shower position, but
    I do not understand why.
    I removed small o-ring mesh filter, check valve, and flow restricter from
    the shower unit. I think it got a bit better but not by much. I still need
    to see what happens if I disconnect the metal hose form the showerholder
    base - it is a bit tricky and I am not up to this challenge at the moment.
    I would appreciate an advice.
    Thanks.
    Dmitri
  1. Mathew J. Newton
    Shower failing to activate DHW (only recently)
    Mathew J. Newton, Aug 17, 2004, in forum: Misc DIY
    312
    Mathew J. Newton
    Aug 17, 2004
  2. dave
    9
    894
  3. alspix
    1,259
  4. Replies:
    792
  5. fishplate
    269
    fishplate
    Oct 2, 2006
Share This Page
