Seeking round toilet bowl for Flushometer
Discussion in 'Home Repair' started by Don Wiss, May 25, 2012.
  1. Don Wiss
    Don Wiss Guest
    I have a small closet where I want to install a toilet and small sink.
    Finding a small sink is easy. Finding a US toilet that doesn't stick out
    very far is hard. Most waste space with the tank behind. A few have tanks
    on the wall, but those stick out just as much. The wall tank is solely for
    an antique effect.
    On a house tour I came across a neighbor that has a round toilet bowl with
    a Flushometer. For those not familiar with the word, these are the values
    you see in public places that don't use a tank. The bowl was the shortest
    I've seen. There was no name on the bowl. I called their contractor and it
    was so long ago he no longer remembers what make the bowl is.
    I tried searching. Every bowl I found for a Flushometer value was
    elongated. I could not find a way to search to pull up a round bowl.
    Has anyone seen such a toilet bowl?
    Don. www.donwiss.com (e-mail link at home page bottom).
  2. Evan
    Evan Guest
    > an antique effect.
    > Don.www.donwiss.com(e-mail link at home page bottom).
    Elongated bowl toilets are required by building code for
    commercial restrooms... It sounds like the toilet you
    have seen was installed long ago before that requirement
    came to be...
    Most residential plumbing systems can not support
    toilets equipped with flushometer type valves as
    they use 1.25" feed lines to the valve and when
    cycled open and close "hard" which could create
    a water-hammer effect...
    It sounds as if your closet is too small to fit a
    properly equipped bathroom inside of it...
    Unless you are willing to get creative and
    consider a one-piece solution in the form
    of a combined sink/toilet unit of the type
    found in Japanese urban living units or inside
    of prisoner cells in correctional facilities...
    Good luck...
    Evan, May 25, 2012
  3. Don Wiss
    Don Wiss Guest
    >came to be...
    It was installed in 1995 or 1996. I wonder when that code change came?
    I can run whatever pipe is needed. This would be a new installation and I
    have a direct run to the cellar, where I have to run the pipe anyhow to get
    water.
    I was trying to get a toilet from The Netherlands. One with a wall tank and
    little wasted space behind the bowl. But I was not able to find anyone
    willing to ship one to the US.
    I can fit a regular toilet, but it would be tight. I want to have as much
    space as possible between the toilet and sink.
  4. dadiOH
    dadiOH Guest
    > out very far is hard. Most waste space with the tank behind. A few
    > have tanks on the wall, but those stick out just as much. The wall
    > tank is solely for an antique effect.
    > with a Flushometer. For those not familiar with the word, these are
    > the values you see in public places that don't use a tank. The bowl
    > was the shortest I've seen. There was no name on the bowl. I called
    > their contractor and it was so long ago he no longer remembers what
    > make the bowl is.
    Any reason why you can't use a plain-jane round front toilet and put a Sloan
    valve on it?
    dadiOH
    ____________________________
    dadiOH's dandies v3.06...
    ....a help file of info about MP3s, recording from
    LP/cassette and tips & tricks on this and that.
    Get it at http://mysite.verizon.net/xico
    dadiOH, May 25, 2012
  5. Dan Espen
    Dan Espen Guest
    Don Wiss <donwiss@no_spam.com> writes:
    > water.
    You'd need 1.25 from the street.
    That would be a pretty big water feed in a residence.
    Dan Espen
    Dan Espen, May 25, 2012
  6. Evan
    Evan Guest
    > >came to be...
    > water.
    Your toilet from the Netherlands would cause you more
    trouble than not, you would have to prove to the plumbing
    inspector's satisfaction that said fixture complies with
    all applicable building and plumbing codes enforced in
    your area...
    This is sounding like an open and shut case of what
    you want to do won't fit where you want to put it...
    Evan, May 25, 2012
  7. Don Wiss
    Don Wiss Guest
    That is what I have from the street. But then it gets reduced to 1" before
    the water meter, and remains 1" after the meter.
  8. Evan
    Evan Guest
    > > I can run whatever pipe is needed. This would be a new installation andI
    > > have a direct run to the cellar, where I have to run the pipe anyhow toget
    > > water.
    > Dan Espen
    Yeah, it would, but watch him do it anyway without
    the proper sized main feed and post again baffled by
    all the odd noises which start happening in his other
    fixtures as suction occurs in the undersized lines...
    Evan, May 25, 2012
  9. EXT
    EXT Guest
    "Don Wiss" <donwiss@no_spam.com> wrote in message
    > an antique effect.
    Don:
    According to your name you are a male. Be aware that short round toilets can
    be very uncomfortable for males to use. When sitting down you may find that
    your "equipment" contacts the porcelain surface which does not feel good and
    could also pick up bacteria resulting in an urinary infection. Think about
    it.
    EXT, May 26, 2012
  10. Evan
    Evan Guest
    LOL...
    That means that you only have a 1" feed to your
    home...
    The size pipe from the street is ok but the meter
    and the piping after it throttle the flow to less than
    you would need for the one proposed toilet...
    Evan, May 26, 2012
  11. Don Wiss
    Don Wiss Guest
    >it.
    Despite my house having multiple toilets, one on each floor, I only use the
    one on the third floor. It is a standard round toilet. Just like what I'm
    seeking for the first floor (which is now located elsewhere on that floor
    and currently has a standard round bowl. I have never considered a round
    bowl to be a problem.
    I have noticed from my past couple posts that this newsgroup has become
    very negative.
    Don Wiss, May 26, 2012
    #11
  12. Home Guy
    Home Guy Guest
    > become very negative.
    Yea, I've noticed that too.
    Far too many negative people around here.
    Home Guy, May 26, 2012
    #12
  13. Guest
    Irony
    , May 26, 2012
    #13
    >> it.
    > very negative.
    It's them dang foreigners and outer space aliens. ^_^
    TDD
    The Daring Dufas, May 26, 2012
    #14
  15. Evan
    Evan Guest
    Ask a silly ass question that clearly shows you shouldn't
    get involved in home repairs beyond changing the light bulbs
    in your table lamps and using a phone book or the internet
    to locate someone who knows what they are doing and
    you get the responses you get...
    Simple as that...
    Evan, May 26, 2012
    #15
  16. Dan Espen
    Dan Espen Guest
    >>it.
    > very negative.
    Shame isn't it?
    Some people post here to share information and help others.
    I can't explain what goes on with the others.
    Dan Espen
    Dan Espen, May 26, 2012
    #16
  17. Don Wiss
    Don Wiss Guest
    And yet another negative post!!
    I got no useful information at all from this thread. But I was able to
    figure out the search terms to find what I wanted.
    First, I figured out that toilet bowl for a flushometer is called a "spud
    toilet bowl" and adding round to that finds that they do exist. Here's one:
    http://www.craneplumbing.com/productDetail.aspx?id=2892
    It is 24 5/8" deep. It requires 25 p.s.i. and 1" pipe. I can easily feed it
    1" pipe from the water meter. I spoke with the neighbor that has a
    flushometer. They have never had any water hammer. Their only problem was
    when the city was working on the water main dirt came in the pipe and it
    clogged up the value and they had to have a plumber clean it out.
    I then figured out the search term to use was "shortest projection toilet."
    And that found me a couple in the UK. Here's the shortest (22.8" deep):
    http://www.tradetaps.com/milton-ceramics-shortie-wc.html
    But shipping from the UK is prohibitive.
    I called Toto. Their shortest is 26 1/8" deep. I called American Standard.
    The woman that answered had no idea and told me to look at each one on
    their various websites. I left a voice mail for her supervisor. He called
    back with a 26 1/2" deep toilet that was their shortest. But I had also
    filled out their web form and asked. That came back with their shortest
    depth is 24 1/2". See:
    http://www.americanstandard-us.com/toilets/colony-fitright-round-toilet-10-inch-rough/
    It can be bought from Home Deport for $138 (no seat) and with free
    shipping:
    http://www.homedepot.com/h_d1/N-5yc1v/R-202499686/h_d2/ProductDisplay?catalogId=10053
    Don Wiss, Jun 2, 2012
    #17
  1. iain010100
    279
    SteveB
    Jul 24, 2008
  2. SH
    839
  3. meen
    flushometer v/s tank flush
    meen, Jun 28, 2008, in forum: Building Construction
    235
    Craig M
    Jun 28, 2008
  4. Charles Williams
    ADA ROUND BOWL
    Charles Williams, Feb 27, 2005, in forum: Plumbing
    272
    Blackbeard
    Feb 27, 2005
  5. Charles Williams
    NOT ADA BUT ROUND BOWL TOILET THAT IS HIGHER
    Charles Williams, Mar 3, 2005, in forum: Plumbing
    240
    Red Jacket
    May 31, 2005
