Sediment Filter: Well Water
Discussion in 'Home Repair' started by Pavel314, Sep 18, 2005.
  1. Pavel314
    Pavel314 Guest
    We have a 125' well with a submersible pump. Occasionally, we get some fine
    silt in the water, either white or rusty, but not enough to cause any
    problems.
    The old pump died last weekend after 25 years of service so we had a new one
    put in. Unfortunately, this stirred up all sorts of sediment in the lines
    and we've had frequent spells of orange or murky water. I've been thinking
    of putting in some sort of filter on the main inlet and found several
    options on the web through a Google search.
    What I'd like is some sort of tank where the water goes through a filter,
    allowing fine particles to be trapped and sink to the bottom. It should be
    large enough so that I only have to change or clean the filter every month
    or so. A filter that can be cleaned and re-used would be preferable to a
    disposable.
    Has anyone had experience with this sort of thing? Any advice or
    recommendations would be appreciated.
    Paul
  2. Pavel314
    SQLit Guest
    "Pavel314" <> wrote in message
    fine
    > problems.
    one
    > disposable.
    > Paul
    Sand or diatomatious earth comes to mind, both can be used as a swimming
    pool filter.
    Sand would might be less hassle for ya, depending on the amount and pressure
    your pump can develop. Back washing takes volume and pressure to remove the
    water.
    I used a paper filter as a whole house water cleaner. Changed the paper once
    every 6 months. It cleaned all of the water I used even the pool and
    sprinklers.
    SQLit, Sep 18, 2005
  3. Pavel314
    Jeff Guest
    > fine silt in the water, either white or rusty, but not enough to cause any
    > problems.
    > one put in. Unfortunately, this stirred up all sorts of sediment in the
    > lines and we've had frequent spells of orange or murky water. I've been
    > thinking of putting in some sort of filter on the main inlet and found
    > several options on the web through a Google search.
    > disposable.
    > Paul
    I had a black sediment in my well water and got sick of using the
    prototypical whole house filter. It was difficult to remove, I had numerous
    resealing problems and I was running through a fair number of filters
    annually. Finally ended up with this product.
    http://www.water-filters-purifiers-softeners.com/a/ppf/id/1195/pt/NT100 Sand Separator/shopexd.asp
    On the first one I tried the mesh was too fine and required back flushing
    ever other day. I order one with a 250 mesh and it did the trick for my
    situation. I back flush every 3 or 4 weeks. The unit bottom valve opens
    and the swirling action of the water removes sediment. I find this doesn't
    always do the trick, especially for more clayish type substantaces, so
    periodically, I will turn the water off, remove the filter, brush it, and
    then reinsert. It will probably pay for itself in a couple of years,
    depending on the type and how fast you use filters in a typical whole house
    filter system.
    If you have copious amounts of sediment, then you may want to put two of
    these, with different size mesh, in line.
    One final note, the sediment will end up clogging and corroding filters in
    home applicances (washing machines, refrigerator water dispensors, etc.) so
    it would probably be best to eliminate the problem before it moves on down
    the line.
    Regards
    Jeff, Sep 18, 2005
  4. Pavel314
    Goedjn Guest
    On Sun, 18 Sep 2005 12:19:07 -0400, "Pavel314"
    >problems.
    >disposable.
    Get the well-water tested in a lab to find out exactly what
    the contamination is, before investing more than a few dollars
    in filters that might be addressing the wrong problem.
    I'd stick two of those cheap cannister filters from home
    depot on in series, and not drink the water until the
    results of the lab-test come back.
    I'm .. well, not surprised, but dissapointed, that the
    people who replaced the pump didn't make this part
    of the routine. Any time you mess with a well,
    you should do a water test shortly thereafter.
    --Goedjn
    Goedjn, Sep 19, 2005
  5. Pavel314
    Pavel314 Guest
    "Goedjn" <> wrote in message
    >>fine
    >>problems.
    >>one
    >>disposable.
    > --Goedjn
    Thanks for the suggestion; I picked up the filter at Home Depot. The guys
    who put the pump in gave it an overdose of chlorine to kill any bacteria
    they may have introduced and said we should get a water test within a week,
    which I intend to do.
    Paul
    Pavel314, Sep 21, 2005
  1. Sediment Filter
    , Aug 8, 2005, in forum: Home Repair
    417
  2. Replies:
    297
    Michael Strickland
    Dec 3, 2006
  3. franz frippl
    sediment filter housing
    franz frippl, Aug 21, 2007, in forum: Home Repair
    298
    Edwin Pawlowski
    Aug 22, 2007
  4. Davej
    Culligan HF-360 water sediment filter
    Davej, Dec 1, 2010, in forum: Home Repair
    345
    Frank
    Dec 1, 2010
  5. Replies:
    780
    Jim Elbrecht
    Oct 26, 2011
