Sealing radiator leak?
Discussion in 'UK DIY' started by Steve, Dec 2, 2003.
  1. Steve
    Steve Guest
    We have a new radiator in our new kitchen, but its leaking where a valve
    screws into it. Can I use PTFE tape on the threads. or is there something
    more suitable?
    Thanks.
    Steve, Dec 2, 2003
  2. Andy Hall
    Andy Hall Guest
    On Tue, 2 Dec 2003 23:51:47 -0000, "Steve" <>
    >more suitable?
    >Thanks.
    That's fine/
    Make sure that you wrap 6-10 turns of tape onto the thread and in the
    correct direction. This should be so that the free end of the tape
    "points" anticlockwise as you look at the radiator. Then as you
    screw in the fitting, the tape will tend to tighten.
    Don't forget to add inhibitor when you refill the system.....
    ..andy
    To email, substitute .nospam with .gl
    Andy Hall, Dec 3, 2003
  3. PoP
    PoP Guest
    >more suitable?
    Are you sure the valve has been fully tightened onto the radiator?
    Might be worth putting a spanner on it to see if it can be tightened
    slightly (remember to use another spanner on the other side of the
    joint to counteract the tightening pressure - you wouldn't want to
    yank the valve off the pipework!).
    PoP
    PoP, Dec 3, 2003
  4. Colin M
    Colin M Guest
    The threaded section where the valve attaches to the radiator uses the
    conical face of the mating surfaces to seal, not the thread. Adding PTFE to
    the thread won't help much.
    Best to open it up and smear a bit of Boss White on the face of the joint
    and retighten.
    Colin M
    Colin M, Dec 3, 2003
  5. Andy Hall
    Andy Hall Guest
    On Wed, 3 Dec 2003 10:14:08 +0000 (UTC), "Colin M"
    >and retighten.
    >Colin M
    I think that you are confusing two things here, Colin.
    The threaded connection, which is the problem the OP describes, if
    leaking, would benefit from being re-done with PTFE tape.
    The conical joint between the tail and the valve *should* seal on a
    metal to metal contact if it is clean . Sometimes they don't and no
    matter how much they are tightened there can be a tiny seepage. In
    this case, some sealant such as Boss White or a specific PTFE liquid
    sealant usually does the trick.
    ..andy
  6. Colin M
    Colin M Guest
    On Wed, 03 Dec 2003 11:21:15 +0000, Andy Hall <>
    >.andy
    Andy
    I assumed because the OP wrote "radiator ... it's leaking where a
    valve screws into it" that he meant the valve to rad coupling which
    relies on the mating surfaces rather than the pipe to valve which
    relies on an olive. The only joint I found PTFE tape helps seal is the
    threaded section into the rad itself.
    Colin M
    Reply to group, or if email required, replace the abuse with broxie
  7. Andy Hall
    Andy Hall Guest
    On Wed, 3 Dec 2003 17:29:13 +0000 (UTC), Colin M
    >>.andy
    >Andy
    >Colin M
    Agreed. Definitely PTFE tape is not useful for the valve to tail
    joint, and I realised that that was what you meant.
    ..andy
  8. NJF
    NJF Guest
    > .andy
    Depends on the rad, one of the guys here got some cast rads that have
    parallel threads and PTFE was useless, ended up using locktite 577.
    Niel.
    NJF, Dec 3, 2003
  9. NJF
    NJF Guest
    > .andy
    Niel.
    NJF, Dec 3, 2003
  10. Roger Mills
    Roger Mills Guest
    "Steve" <> wrote in message
    news:bqj8ih$22j6ov$-berlin.de...
    > more suitable?
    > Thanks.
    PTFE tape is fine - but it should already have some on it! You will have to
    drain the radiator to fit (more) tape - but you needn't drain the whole
    system - just turn off both valves on that particular rad - and then undo
    one of the unions between the 2 halves of one of the valves to drain it
    (protecting the flooring from any 'orrible black sludge you may spill in the
    process!) It helps to loosen the bleed screw too, to let some air in at the
    top as the water runs out at the bottom.
    The radiator tail (the bit which screws into the rad) just may have an
    external square on it - in which case you could try tightening it with a
    spanner rather than draining and dismantling it. [It it doesn't have a
    square - and not many do - you will have to take it apart in order to
    tighten it with an internal allen key].
    Roger
    Roger Mills, Dec 3, 2003
  11. Steve
    Steve Guest
    "Colin M" <> wrote in message
    Yes thats what I meant.
    >which
    Thanks to all for your help.
    Steve, Dec 3, 2003
    #11
  12. Steve
    Steve Guest
    "Roger Mills" <news@spam_me_not37.fslife.co.uk> wrote in message
    news:bqlddd$rvv$...
    to
    the
    the
    Cheers Roger. I think I needed a bit of advice about taking it all apart.
    Its a brand new radiator, fitted by the buiilder who did our building mods
    and fitted the new kitchen. Having got his money, we haven't seen him since,
    and the radiator is just one of several unfinished or bodged jobs we have
    found.
    Steve, Dec 3, 2003
    #12
  1. BillR
    Re: Radiator leak sealant
    BillR, Oct 13, 2003, in forum: UK DIY
    743
    BillR
    Oct 13, 2003
  2. Nige
    radiator leak
    Nige, Jan 28, 2004, in forum: UK DIY
    412
    Andy Hall
    Jan 29, 2004
  3. JCT
    sealing plumbing leak
    JCT, Nov 25, 2004, in forum: Misc DIY
    517
  4. Leak or no leak?
    , Aug 5, 2008, in forum: HVAC
    537
    Don Ocean
    Aug 8, 2008
  5. Ben Dover
    help with sealing threaded pvc leak
    Ben Dover, Dec 28, 2003, in forum: Plumbing
    317
    hall.kimberly
    Jan 23, 2004
