Screed to concrete floor
Discussion in 'Misc DIY' started by PJ, Apr 21, 2004.
  1. PJ
    PJ Guest
    Anyone know what mix should be used for sand/cement floor screed?
    Also, does the screed simply go on top of the concrete or should the
    concrete be treated with anything first?
    PJ, Apr 21, 2004
  2. PJ
    Kalico Guest
    On Wed, 21 Apr 2004 08:41:45 +0100, "PJ"
    Make sure the concrete floor is nice and wet before you start and use
    a VERY dry mix of about 5 sand, 1cement, with no lime etc. Hardly any
    water in it, AFAIK.
    Rob
    Kalico, Apr 21, 2004
  3. PJ
    PJ Guest
    "Kalico" <> wrote in message
    > water in it, AFAIK.
    > Rob
    I was going to make the mix sloppy so it found it's own level. If I do a dry
    mix I'll have to float it smooth & level and having never done this before I
    may cock up.
    PJ, Apr 21, 2004
  4. PJ
    Stuart Guest
    "PJ" <> wrote in message
    news:c65otq$2i0$...
    > news:...
    > > water in it, AFAIK.
    > > Rob
    dry
    I
    > may cock up.
    Depends on the thickness, if its about 10mm or less then a self levelling
    flooring compound that you pour on and it will create a thin hardwearing
    level surface. If your screed is needing to be a couple of inches thick then
    it does need to be a very dry mix (4:1 min) and levelled with a wooden
    float. If you make a wet and sloppy sand cement screed, it will be weak and
    dusty!
    Stuart, Apr 21, 2004
  5. PJ
    PJ Guest
    then
    and
    > dusty!
    Right. See your point. I need a 65mm screed so it's quite thick. Self
    leveller is no good because it tends to flake off (this is a garage and so
    will take some stick).
    PJ, Apr 21, 2004
  6. PJ
    Mike Taylor Guest
    "Normal screeds are above 50mm thickness up to about 75mm
    You lay them on top of the existing clean concrete.
    1st "prime the concrete with a slurry of neat cement. Just mix some cement
    with water to a sloppy creamy consistency and brush with a broom onto the
    floor
    The screed is normally 3 parts river washed sand to 1 part cement mixed
    quite dry.
    Mike Taylor, Apr 21, 2004
  7. PJ
    PJ Guest
    "Mike Taylor" <MikeT@(Removethis)tylershill.freeserve.co.uk> wrote in
    message news:c662ul$h83$...
    > floor
    > quite dry.
    Please excuse my ignorance but what is river washed sand?
    PJ, Apr 21, 2004
  8. PJ
    Stuart Guest
    news:c66b4p$2r1$...
    cement
    the
    > > floor
    > > quite dry.
    It is widley known as "Sharp Sand", don't use Building Sand (often called
    Soft Sand) it will give a dusty finnish.
  9. PJ has brought this to us :
    > may cock up.
    From my memory of the last time I saw it done professionally, they laid
    a matrix of 2x2 level timber to act as a guide at a spacing of about 4
    feet. As the screed starts to set, they lift the timber and fill in the
    gaps with more screed then float it smooth. They used sheets of ply on
    top of the screed to stand upon.
    Regards,
    Harry (M1BYT) (L)
    http://www.ukradioamateur.org
    Harry Bloomfield, Apr 21, 2004
  10. PJ
    Guest
    In article <c66b4p$2r1$>, PJ <
    ..org.uk.me.etc.com> writes
    >> floor
    >> quite dry.
    It should be "washed river sand"
    David
    , Apr 21, 2004
  11. PJ
    Mike Taylor Guest
    correct washed river sand instead of river washed sand, Slip of the old
    computer fingers when trying to type fast
    Mike Taylor, Apr 22, 2004
    #11
  12. PJ
    PJ Guest
    message news:c67n3p$qkb$...
    Oh dear. And here's me with a ton of red building sand left over which I was
    going to use for the screed!
    PJ, Apr 22, 2004
    #12
  1. dog-man
    573
    Michael Chare
    Nov 14, 2006
  2. Replies:
    2,335
  3. T. Sheehan
    Concrete screed removal
    T. Sheehan, Aug 31, 2007, in forum: Misc DIY
    708
    Andrew Gabriel
    Aug 31, 2007
  4. Jeff
    450
    Steve
    Jan 6, 2004
  5. Simeon_Osen@RonacreteLtd
    Laying a bonded screed on to a concrete floor
    Simeon_Osen@RonacreteLtd, Apr 10, 2007, in forum: Misc DIY
    1,681
    ryanb93
    Nov 17, 2011
